[Kernel][Yank555][Sammy 4.3 v4.1c][Sammy 4.1.2 v3.4f]
  • 8.834 Antworten
Hat jemand die Yank Settings bereit? Bin grad dabei Clean Install zumachen und bin im setup vom Yank, such die Settings^^
? EInfach weiter tippen. Die Default Werte sind Yanks. Sind auf jeden Fall sehr gut.
Kernel Update CM10.1 beta
Changelog CM10.1 v1.6e-beta10 (compared to v1.6d) :
  • added : Hardwarekeys light on screen touch switchable (Yank555.lu) (1)
  • added : GPU clock and voltage control (via temasek) (2)
  • fixed : GPU clock and voltage control - higest freq. step voltage not being initialized (Yank555.lu)
  • updated : GPU clock and voltage control - full freq. range voltage table added, automatic voltage update for all freq. steps (Yank555.lu)
  • updated : GPU clock and voltage control - revamped the whole interface, keeping the old legacy interface in place (Yank555.lu)
  • updated : GPU clock and voltage control - added a gpu_voltage_delta to be applied when voltage table is reset, allows to globally over-/underclock (Yank555.lu)
  • Forced Fast Charge v1.4a : return "invalid argument" when writing a wrong value in sysfs tunables
  • Touch Wake v1.1a : fixed proxy sensor detection (Yank555.lu) (3)
  • updated zzmoove to 0.6a : autodetect CPU freq. table sorting, not for exynos, but for other platforms (Yank555.lu) (4)
  • updated zzmoove to 0.6b : hotplugging revisited to reduce plugging (ZaneZam)
  • updated zzmoove to 0.7-beta1 : hotplugging freq. thresholds introduced (Yank555.lu)
  • zRam : changed compression fron snappy v3 to lz4 (Yank555.lu)
  • updated zzmoove yank battery profile
  • updated zzmoove yank extreme battery profile
  • wifi : reduced wakelock times (DerTeufel)
  • ramfs : included CM's no in-call sound workaround in ramfs, will work in any case, even without ROM support (Yank555.lu)
  • updated to Samsung Update 11 sources
  • updated to kernel.org Linux 3.0.89
    (1) I've also added that the h/w backlight stays off when turning device on if this is disabled, but on some rare occasions it still is lit, neet to give a second look to it.
    (2) no support will be given on issues if GPU is not set to stock when this happens ... I mean it ... really !!
    (3) Proxy detection never worked, in any kernel (look here)
    (4) change in zzmoove will make 0 difference in this kernel, the change is for portablility to other devices only but needed quite some code changing !
Reaktionen: topper8, Andii S, derOyabun und 7 andere
Hallo Leute.
Ich wollte mal fragen bevor ich den kernel installieren ob der auch für Galaxy note N7000 geeignet ist?
sorry gelöscht ....
Weiss jemand ob es einen ähnlich guten für das Galaxy note n7000 gibt?
Der ursprüngliche Beitrag von 20:56 Uhr wurde um 20:57 Uhr ergänzt:
Sorry bin ein ziemlicher no ob in diesen Sachen. Geht das jetzt oder nicht device?
Diesen Kernel kannst du nicht mit deinem Note verwenden.
hells
Nee, ich mach nur Kernel für Geräte die ich besitze, und hab keinen n7000.
Diesen Kernel solltest du auch auf keinen Fall verwenden, er ist nur für i9300 oder i9305 gedacht.
JP.
Yank ist die Beta 10 auch für cm10.2?
Nee, mach für CM10.2 noch keine regelmässigen Updates, ist eh nicht so'n grosser Unterschied.
CM10.2 ist für mich noch zu früh in der Entwicklung...
JP.
Reaktionen: 156436
Was ich jetzt nicht verstanden habe , gibts nen Kernel für Slim8 oder nicht:unsure:
Ja den 10.1 kernel
Reaktionen: ugur7495
Was beinhalten denn die samsung update 11 sourcen?
Genau diese Frage habe ich mir auch gestellt und einfach installiert :) ich vertraue da voll und ganz yank :D
DAS hier.
hells
Reaktionen: derOyabun und Lycidias
Ich versteh da nur Bahnhof :) ;)
@hellsgod ich versteh da nur Bahnhof xD
Na nix weltbewegendes, ist aber nun unter der Haube drin ;)
JP.
Reaktionen: Lycidias
Wieso versteht ihr den nur Bahnhof? Der Sourcecode wird von 10 auf 11 geupdatet *Punkt* :p
Oebbler
SiggiP
Oebbler
Borkse
Oebbler
SaschaKH
SaschaKH
