[Kernel][Yank555][Sammy 4.3 v4.1c][Sammy 4.1.2 v3.4f]
  • 8.834 Antworten
spevil schrieb:
hey JP, dein genialer kernel fehlt schon wirklich sehr auf dem s4!!!
Leider werde ich den S4 wohl sehr warscheinlich aussetzen, ausser diesen Google Edition, der könnt mir gefallen... wenn der erhältlich ist (oder dessen ROM auf nem üblichen i9505 läuft).
JP.
@jp hast du denn zzmoove 0,5 oder den 0,51b implementiert?
Changelog CM10.1 v1.6c-beta-public :
updated to kernel.org Linux 3.0.82
updated zzmoove to 0.5 :
Display frequency control (switch to 40Hz when load is low)
Fastscaling revamped (configurable in number of levels to skip, up and down !)
Early demand
Sampling down reintroduced
Sampling down momentum
extended fast scaling options for zzmoove in Aroma
added early suspend options for zzmoove in Aroma
fixed a bug in Aroma (dynamic fsync was always turned on)
added a new yank battery profile in Aroma with updated tunable settings for zzmoove 0.5 (don't use the old ones !!)
updated zram (Jiang Liu through faux123)
added Touch Wake (Ezekeel through AndiP)
bei sammy sieht das nicht ganz anders aus.
somit habt ihr noch den zzmoove 0.5
Reaktionen: EdgA und deviceX
Kernel Update CM10.1 i9300
Changelog CM10.1 v1.6c :
  • updated zzmoove to 0.5.1b
    • Display frequency control (switch to 40Hz when load is low)
    • Fastscaling revamped (configurable in number of levels to skip, up and down !)
    • Early demand
    • Sampling down reintroduced
    • Sampling down momentum
    • now really fixed the governor switching issues! (gotcha bitch! *g*)
    • again some changes in scaling logic from Yank555 (thx and credits)
    • simplified some tuneables by using already available stuff instead of using redundant code (thx Yank555)
    • reduced/optimised hotplug logic and preperation for automatic detection of available cores (maybe this fixes also the scaling/core stuck problems)
  • extended fast scaling options for zzmoove in Aroma
  • added early suspend options for zzmoove in Aroma
  • updated zram (Jiang Liu through faux123)
  • added Touch Wake (Ezekeel through AndiP)
  • fixed a bug in Aroma (dynamic fsync was always turned on)
  • removed all Aroma profiles except 'Full stock' and 'Yank'
  • added option in Aroma to just flash the kernel without changing settings (I highly recommend to not use this when changing kernel version, use at your very own risk !!!)
  • updated yank battery profile in Aroma for zzmoove 0.5
  • added a new yank battery 'extreme' profile in Aroma with updated tunable settings for zzmoove 0.5
  • updated ZaneZam's profiles to fit zzmoove v0.5
  • updated to kernel.org Linux 3.0.83
Der Sammy Kernel für i9300 kommt als nächstes, die anderen vielleicht noch heute, oder halt morgen abend, je nachdem wie ich weiter komme...
Reaktionen: sgs9000A, derlarswars, topper8 und 14 andere
Thx klingt nett mal schauen wie es nun läuft..
ich muss glaube mal öfters den changelog hier posten, wenn dann immer danach das update von yank kommt ;D
Reaktionen: KoKo 61, deviceX und Jenanga
Kernel Update Samsung i9300
Changelog v3.4c
    • Early demand
Reaktionen: YogiBaer78, ugur7495, deviceX und eine weitere Person
Hab mal ne frage, manche Benachrichtigungen kommen gar nicht oder total verzögert, Zb. Facebook gplus woran kann das liegen?? Auf der Stock Rom hatte ich das Problem nicht
Ok das ist mir auch schon aufgefallen
Das kann mit vielem zusammenhängen...
Welche ROM hast du denn nun im Einsatz ? Greenify ? Mods ?
JP.
Ich hab aktuell Fusion v6 dein Kernel mit den yank Einstellungen installiert (so wie Aroma es vor gibt)
vielen dank yank update geflasht und hast du ein paar kühlakkus dazu gelegt? Meine Temperatur ist direkt mal auf 29¤ gesunken:D
Ok, die ROM kenn ich gar nicht :(
JP.
mir kommt es so vor, als wenn das Display mit den zzmove länger aus dem deepsleep braucht als mit dem yankasusq (bei PA 3.6)
Schau mal auf wieviel die Screen off Freq begrenzt wird.
Alternativ wäre an anderen Screen off Parameter zu spielen (manuelles editieren des init.kernel.sh notwendig.
JP.
screen off touch boost habe ich aus wenn du das meinst
Touch boost greift nur bei screen on, würd ich auf jedenfall aktiv lassen, sonst gibt es mini Ruckler beim Scrollen.
Screen off max. Freq hast du auf wieviel stehen ? Meine Angaben liegen bei 600MHz, versuch das mal höher zu stellen.
Ich kann mit der 'Weckzeit' leben, insofern mag ich lieber bissel Saft sparen bei Screen off, daher niedriger ;)
JP.
Reaktionen: EdgA
Hey Yank, du nutzt SDS & Better Wifi oder?
Hab jetzt eine lange Zeit mit Greenpower rumprobiert, da ich dachte, das deckt alles ab. Funktioniert phasenweise auch sehr gut, leider kommt es aber manchmal vor das data/wifi nicht wieder aktiviert wird. Das nervt tierisch ^^
Muss da wohl Alternativen testen, wobei ich Juice-Defender von der UI & Co. ganz schlimm fand.
So ein ähnliches Problem hatte ich mit JD, WiFi war oft inaktiv :(
SDS und BWOF laufen toll zuwammen, optimal so wie es nun ist ;)
JP.
Reaktionen: iZz0s
Oebbler
SiggiP
Oebbler
Borkse
Oebbler
SaschaKH
SaschaKH
