[Kernel][Yank555][Sammy 4.3 v4.1c][Sammy 4.1.2 v3.4f]
  • 8.834 Antworten
cbernie schrieb:
habe cleaning script laufenlassen. habs gerade nochmal geflasht und gleiches problem. kann die dateien aber nicht hochladen hmmpf erhaltge jeweils die nachricht ungültige datei selbst wenn ich diese als rar hochlaen will :confused:
Und ein Copy/Paste als "code" hier ?
Nur mal die /data/kernel-boot.log ...
JP.
JP.
okla
Yank555.lu - execution of kernel options init script
2013-03-22 16:44:30 : Waiting for Android to start...
2013-03-22 16:44:43 : Android is starting up, let's wait another 10 seconds...
2013-03-22 16:44:55 : Starting kernel configuration...
2013-03-22 16:44:57 : Init.d script execution support disabled.
2013-03-22 16:44:57 : CPU governor set to YankasusQ.
2013-03-22 16:44:58 : CPU max. frequency set to 1.6GHz.
2013-03-22 16:45:00 : YankasusQ - CPU freq. max for 1 cores set to 1.6GHz.
2013-03-22 16:45:02 : YankasusQ - CPU freq. max for 2 cores set to 1.2GHz.
2013-03-22 16:45:02 : YankasusQ - CPU freq. max for 3 cores set to 1.4GHz.
2013-03-22 16:45:02 : YankasusQ - CPU freq. max for 4 cores set to 1.6GHz.
2013-03-22 16:45:02 : YankasusQ - CPU freq. threshold for 1 to 2 cores set to 1.2GHz.
2013-03-22 16:45:02 : YankasusQ - CPU freq. threshold for 2 to 3 cores set to 1.1GHz.
2013-03-22 16:45:02 : YankasusQ - CPU freq. threshold for 3 to 4 cores set to 1.2GHz.
2013-03-22 16:45:02 : YankasusQ - CPU freq. threshold for 4 to 3 cores set to 1.1GHz.
2013-03-22 16:45:02 : YankasusQ - CPU freq. threshold for 3 to 2 cores set to 1.0GHz.
2013-03-22 16:45:02 : YankasusQ - CPU freq. threshold for 2 to 1 cores set to 800MHz.
2013-03-22 16:45:02 : YankasusQ - CPU freq. max for standby set to 600MHz.
2013-03-22 16:45:02 : 100Mb Zram Support enabled.
2013-03-22 16:45:02 : Hardswap Support disabled.
2013-03-22 16:45:02 : Swappiness not set.
2013-03-22 16:45:02 : Fast Charge - Custom Current Mode enabled.
2013-03-22 16:45:02 : Fast Charge - USB charge level set to 800mA/h.
2013-03-22 16:45:02 : Fast Charge - AC charge level set to 1200mA/h.
2013-03-22 16:45:02 : Early Suspend Delay set to 0ms.
2013-03-22 16:45:02 : Boeffla Sound Engine not handled by kernel init script.
2013-03-22 16:45:02 : Dynamic Deferred File Sync enabled.
2013-03-22 16:45:02 : Notification LED set to fading mode with normal intensity.
2013-03-22 16:45:02 : CIFS kernel modules not loaded.
2013-03-22 16:45:02 : NFS kernel modules not loaded.
2013-03-22 16:45:02 : NTFS kernel module not loaded.
2013-03-22 16:45:02 : ISOFS kernel module not loaded.
2013-03-22 16:45:02 : UDF kernel module not loaded.
2013-03-22 16:45:02 : XBOX 360 gamepad support kernel module not loaded.
2013-03-22 16:45:02 : Waiting 60 seconds...
2013-03-22 16:46:02 : Internal and External MMC Readahead set to 512Kb.
2013-03-22 16:46:02 : Internal and External MMC scheduler set to ROW.
2013-03-22 16:46:02 : Android Low Memory Killer set to Stock SGS3.
2013-03-22 16:46:02 : Finished kernel configuration.
#!/system/bin/sh
# Yank555.lu - generated kernel options init script
log_file="/data/kernel-boot.log"
echo "----------------------------------------------------" >$log_file
echo "Yank555.lu - execution of kernel options init script" >>$log_file
echo "----------------------------------------------------" >>$log_file
echo `date +"%F %R:%S : Waiting for Android to start..."` >>$log_file
# Wait until we see some android processes to consider boot is more or less complete (credits to AndiP71)
while ! /sbin/pgrep com.android ; do
sleep 1
done
echo `date +"%F %R:%S : Android is starting up, let's wait another 10 seconds..."` >>$log_file
# Now that is checked, let's just wait another tiny little bit
sleep 10
echo `date +"%F %R:%S : Starting kernel configuration..."` >>$log_file
# Script generated on 22/03/2013 at 8:38
# - init.d support by kernel/ramdisk not installed
echo `date +"%F %R:%S : Init.d script execution support disabled."` >>$log_file
# - Set governor to yankasusq
echo "yankasusq" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo `date +"%F %R:%S : CPU governor set to YankasusQ."` >>$log_file
# - Set CPU max frequencies for all 4 cores
echo 1600000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
echo `date +"%F %R:%S : CPU max. frequency set to 1.6GHz."` >>$log_file
# - Set governor to yankasusq to 1.6GHz high
echo "1600000" > /sys/devices/system/cpu/cpufreq/yankasusq/cpu_max_freq_1
echo `date +"%F %R:%S : YankasusQ - CPU freq. max for 1 cores set to 1.6GHz."` >>$log_file
echo "1200000" > /sys/devices/system/cpu/cpufreq/yankasusq/cpu_max_freq_2
echo `date +"%F %R:%S : YankasusQ - CPU freq. max for 2 cores set to 1.2GHz."` >>$log_file
echo "1400000" > /sys/devices/system/cpu/cpufreq/yankasusq/cpu_max_freq_3
echo `date +"%F %R:%S : YankasusQ - CPU freq. max for 3 cores set to 1.4GHz."` >>$log_file
echo "1600000" > /sys/devices/system/cpu/cpufreq/yankasusq/cpu_max_freq_4
echo `date +"%F %R:%S : YankasusQ - CPU freq. max for 4 cores set to 1.6GHz."` >>$log_file
echo "1200000" > /sys/devices/system/cpu/cpufreq/yankasusq/hotplug_freq_1_1
echo `date +"%F %R:%S : YankasusQ - CPU freq. threshold for 1 to 2 cores set to 1.2GHz."` >>$log_file
echo "1100000" > /sys/devices/system/cpu/cpufreq/yankasusq/hotplug_freq_2_1
echo `date +"%F %R:%S : YankasusQ - CPU freq. threshold for 2 to 3 cores set to 1.1GHz."` >>$log_file
echo "1200000" > /sys/devices/system/cpu/cpufreq/yankasusq/hotplug_freq_3_1
echo `date +"%F %R:%S : YankasusQ - CPU freq. threshold for 3 to 4 cores set to 1.2GHz."` >>$log_file
echo "1100000" > /sys/devices/system/cpu/cpufreq/yankasusq/hotplug_freq_4_0
echo `date +"%F %R:%S : YankasusQ - CPU freq. threshold for 4 to 3 cores set to 1.1GHz."` >>$log_file
echo "1000000" > /sys/devices/system/cpu/cpufreq/yankasusq/hotplug_freq_3_0
echo `date +"%F %R:%S : YankasusQ - CPU freq. threshold for 3 to 2 cores set to 1.0GHz."` >>$log_file
echo "800000" > /sys/devices/system/cpu/cpufreq/yankasusq/hotplug_freq_2_0
echo `date +"%F %R:%S : YankasusQ - CPU freq. threshold for 2 to 1 cores set to 800MHz."` >>$log_file
# - Set CPU max frequency in standby
echo "600000" > /sys/devices/system/cpu/cpufreq/yankasusq/cpu_max_freq_stdby
echo `date +"%F %R:%S : YankasusQ - CPU freq. max for standby set to 600MHz."` >>$log_file
# - zRam activation - 100Mb
if [ -e /sys/block/zram0/disksize ] ; then
swapoff /dev/block/zram0
echo 1 > /sys/block/zram0/reset
echo 104857600 > /sys/block/zram0/disksize
echo 1 > /sys/block/zram0/initstate
swapon /dev/block/zram0
fi
echo `date +"%F %R:%S : 100Mb Zram Support enabled."` >>$log_file
# - Hardswap by Yank555.lu not installed
echo `date +"%F %R:%S : Hardswap Support disabled."` >>$log_file
# - swappiness not set here
echo `date +"%F %R:%S : Swappiness not set."` >>$log_file
# - Enable custom current forced fast charge
echo 2 > /sys/kernel/fast_charge/force_fast_charge
echo `date +"%F %R:%S : Fast Charge - Custom Current Mode enabled."` >>$log_file
echo 800 > /sys/kernel/fast_charge/usb_charge_level
echo `date +"%F %R:%S : Fast Charge - USB charge level set to 800mA/h."` >>$log_file
echo 1200 > /sys/kernel/fast_charge/ac_charge_level
echo `date +"%F %R:%S : Fast Charge - AC charge level set to 1200mA/h."` >>$log_file
# - Disable early suspend delay
# When turning off the screen, don't wait for any kind of CRT animation.
echo 0 > /sys/kernel/early_suspend/early_suspend_delay
echo `date +"%F %R:%S : Early Suspend Delay set to 0ms."` >>$log_file
# Don't set anything related to Boeffla Sound Engine by AndiP71 in this script, allows user scripts to set this in init.d
echo `date +"%F %R:%S : Boeffla Sound Engine not handled by kernel init script."` >>$log_file
# - Enable dynamic deferred file sync (by faux123)
# While screen is on, file sync is temporarily deferred, when screen
# is turned off, a flush is called to synchronize all outstanding writes.
echo 1 > /sys/kernel/dyn_fsync/Dyn_fsync_active
echo `date +"%F %R:%S : Dynamic Deferred File Sync enabled."` >>$log_file
# - Enable fading notification LEDs with normal intensity
echo 1 > /sys/class/sec/led/led_fade
echo `date +"%F %R:%S : Notification LED set to fading mode with normal intensity."` >>$log_file
# - Do not load CIFS kernel modules on boot
echo `date +"%F %R:%S : CIFS kernel modules not loaded."` >>$log_file
# - Do not load NFS kernel modules on boot
echo `date +"%F %R:%S : NFS kernel modules not loaded."` >>$log_file
# - Do not load ntfs kernel module on boot
echo `date +"%F %R:%S : NTFS kernel module not loaded."` >>$log_file
# - Do not load isofs kernel module on boot
echo `date +"%F %R:%S : ISOFS kernel module not loaded."` >>$log_file
# - Do not load UDF kernel module on boot
echo `date +"%F %R:%S : UDF kernel module not loaded."` >>$log_file
# - Do not load XBOX 360 gamepad kernel module on boot
echo `date +"%F %R:%S : XBOX 360 gamepad support kernel module not loaded."` >>$log_file
# - Set MMC readahead buffer size
# Wait for everything to become ready
echo `date +"%F %R:%S : Waiting 60 seconds..."` >>$log_file
sleep 60
# Internal MMC
echo 512 > /sys/block/mmcblk0/bdi/read_ahead_kb
# SD card
echo 512 > /sys/block/mmcblk1/bdi/read_ahead_kb
echo `date +"%F %R:%S : Internal and External MMC Readahead set to 512Kb."` >>$log_file
# - Set MMC I/O scheduler
# Internal MMC
echo "row" > /sys/block/mmcblk0/queue/scheduler
# SD card
echo "row" > /sys/block/mmcblk1/queue/scheduler
echo `date +"%F %R:%S : Internal and External MMC scheduler set to ROW."` >>$log_file
# - Set Android Low Memory Killer to Stock SGS3 (in number of pages of 4Kbytes)
# Forground apps : 8192 pages / 32Mb
# Visible apps : 10240 pages / 40Mb
# Secondary server : 12288 pages / 48Mb
# Hidden apps : 14336 pages / 56Mb
# Content providers : 16384 pages / 64Mb
# Emtpy apps : 18432 pages / 72Mb
chmod 664 /sys/module/lowmemorykiller/parameters/minfree
echo "8192,10240,12288,14336,16384,18432" > /sys/module/lowmemorykiller/parameters/minfree
echo `date +"%F %R:%S : Android Low Memory Killer set to Stock SGS3."` >>$log_file
echo `date +"%F %R:%S : Finished kernel configuration."` >>$log_file
chmod 644 $log_file
# End of generated script
@cbernie
könntest du vor und hinter dem Logtext folgende Tags setzen?
(spoiler) vor, und (/spoiler) hinter dem Logtext, die runden Klammern durch die eckigen Klammern (Alt Gr + 8/9) ersetzen.
Danke ;)
Reaktionen: blasen
Hi Leute,
Ich habe mir gerade den 1.5b geflasht, ist ja doch ein wenig komplexer als andere Kernles (habe ich das Gefühl). Was man da alles einstellen kann.
Ich war vorher mit Stock Kernel von der CM 10.1 Nightly vom 19.03. unterwegs, der war schon sehr Akkusaugend.
Ich wollte mal anfragen ob es überhaupt was bringt, wenn ich den Yank einfach so flashe wie er voreingestellt im Aroma vorhanden ist oder ob man sich bei diesem Kernel doch genauer mit den ganzen Einstellungen beschäfftigen sollte?
MfG
scarface2209
cbernie schrieb:
okla
Versuch diese Wert in Aroma weitaus höher zu setzen, z.B. 1.4GHz.
JP.
Sent from my Sotmax V15 / Yank555.lu SGS3 U8 kernel v3.3d-beta2 (Linux 3.0.70) powered Galaxy S3 i9300 using Tapatalk 2
JP.
Vielen Dank werde es morgen probieren - bei uns in China ist jetzt Abend, habe im Moment den Boeffla geflasht.
Bei mir ruckelt der Opera Browser (nicht mini) wie verrückt, kann ds einer bestätigen mit 4.2.2.?
Habe Opera 14.x drauf. Geht perfekt.
Ich version 12, woher hast du die 14?
die 14 ist Opera beta aus dem Playstore.
Swannika
Ich weiß ja nicht was Yank aus den Hut gezaubert hat,aber der 3.3c läuft so smooth und so rund ausgezeichnet.Der 3.3a lief ja schon nicht schlecht,der 3.3c ist wieder mal das maß aller dinge.:thumbsup:
Klasse:)
Ich hab mal mit CM10.1 und dem 1.5c einen längeren "Schlaftest" gemacht in Bezug auf WiFi wakelock...
Ich konnte das Problem nicht reproduzieren. Das S3 lage die ganze Zeit nur im Standby rum (also wie ne 44 stündige Nacht), hier das Resultat.
Scheint wohl doch am WiFi zu liegen, ob eben viele wlan_rx_wake kommen oder nicht.
JP.
Reaktionen: TheSpiritof69
Ich habe bei meiner Rom noch den DSP Manager drin, komplett deaktivieren für Boeffla Sound?
Der Sound über Kopfhörer ist nicht schlecht, aber bin leider besseres gewohnt mit den S3!
Und leider kann ich die Soundeinstellungen für den Lautsprecher nicht nutzen, es verändert sich nix!
Jupp, am Besten mit Titanium Backup einfrieren.
Mhmm, finde den Klang über die DSP App besser muss ich sagen, also was ich regulieren kann!
Und noch eine frage: Wie reaktiviere ich mein S3 wieder ausn Standby? Und was tut er genau?
Wenn dein Gerät nicht mehr aus dem Standby aufwacht, ist deine maximale Standby-Taktfrequenz zu niedrig.
Akku raus, ins Recovery booten, Kernel neu flashen (bzw. nur die Config) und im Aroma eine höhere Frequenz auswählen.
Wann wird man in dem Forum von Yank freigeschaltet? Würde gerne den Kernel flashen, aber die Anmeldung hindert mich daran! Früher ging es doch auch so! Warum dieser Weg?
Yank hat vor ein paar Seiten erklärt, warum er das jetzt so handhabt. Du wirst sicher bald freigeschaltet, wenn Yank dazu kommt.
Ich schicke dir die Direktlinks per PM.
Freischaltungen durchgeführt.
JP.
