[KERNEL] (Jelly Bean) GalaXsih v2.0 beta 7
  • 380 Antworten
"D"
Gast
thanks to yasser rizky for your banner
objective : good battery life
Not for AOSP / AOKP ROM
Download Here
(thanks to geistteufel for your ftp server, space and bandwith!)
Do not forget to donate to this forum XDA :
http://forum.xda-developers.com/donations.php
Stable Version change-log:
Incremental update from last version
GalaxSih Kernel Jelly Bean v1.3
Quote:
Thanks to Beta contributor:
  1. SETdown
  2. spencer1208
  3. Sad56
  4. samaxen
  5. netchow
  6. delgamarco
  7. hshah
  8. kwankl
  9. tupac19861013
  10. brunodu91
  11. ksr007
  12. mariosraptor
  13. AndiP
  14. Milchbeck
  15. Chillz88
  16. borjaag
  17. RuralGalaxy
  18. androb0t
  19. poppy9009
  20. Razertje
  21. jothi2lingam
  22. ph3nom
  23. Jmldsilva
  24. slimldj
  25. benc88
  26. currydude
  27. wtfshouldidonow
  28. fastcx
  • Update linux kernel from 3.0.31 to 3.0.36
  • Kernel optimizations - by VOKU
  • Resync to XXDLJ2 ramfs thx to andip for your stock boot.img
  • Revert : power: reduce regulator initializations to regulator minimal (this commit is not for i9300 - thanks to andreilux for your notice)
  • Revert: sensorhub: Fix firmware mislabeling and version checking (this commit is not for i9300 - thanks to andreilux for your notice)
  • Wakelock: use single threaded workqueueus
  • Switch do_fsync() to fget_light()
  • Staging: android: lowmemorykiller.c - Fix compiler warning about the type of the module parameter.
  • pegasusq (based on ondemand): cpuidle detection by Andrea Arcangeli
  • Android Logger as a module - thanks to andip for your idea.
  • Possibly car dock error have been fix..need your report to prove it., thanks to gokhanmoral
  • MTP fix for OSX user
Quote:
Big Thanks to 1.1 Beta contributor:
  • AbuYahya
  • JYJY
  • mkh@xda
  • ph3nom
  • ongchonghian
  • Sad56
  • x10i DauL
  • fastcx
  • jothi2lingam
  • raaghav2
  • tupac19861013
  • androb0t
  • samaxen
  • RuralGalaxy
  • fastcx
  • SETdown
  • poppy9009
GalaxSih Kernel Jelly Bean v1.1
Change log:
  • power: reduce regulator initializations to regulator minimal -AndreiLux
  • sensorhub: Fix firmware mislabeling and version checking
    Payloaded firmware version doesn't correspond labeling. This causes the kernel
    to reflash the firmware on every single boot thinking it has a newer firmware
    than listed on the device. - AndreiLux
  • max77686+max77693 revert: disable debugging - this will fix USB charge error.
  • android: lowmemorykiller: Change default debug_level to 1
  • cpufreq: pegasusq: instead of jumping around the frequencies leaving some unused we now jump from one to another by 100Mhz increments - franciscofranco
  • net: wireless: bcmdhd: sync with newer sources - gokhanmoral
  • merges with GT-I9300_SEA_JB_OpenSource.zip -gokhanmoral
  • re-enable touchbooster
  • mdnie: black crush fix. (Thanks to AndreiLux)
  • cpuidle: Change state properties - AndreiLux
  • fix front camera crash - (revert front camera block-space to default stock)
  • change cfq to deadline io scheduller as default io scheduller
    thanks to Sad56 for your idea.
    about Deadline:
    The scheduler helps organise reads and writes in the I/O queue to maximise performance. The default scheduler in the Linux kernel is CFQ (Completely Fair Queuing), which is designed with the rotational latencies of spinning platter drives in mind. So while it works well for standard hard drives, it doesn't work so well when it comes to SSDs.Fortunately, the kernel comes with some other schedulers to play with, and here the deadline and NOOP schedulers are ideal
  • Wifi: Reenable IPv6, disable multicast in suspend (entropy512)
    Why do they keep on reenabling that stupid "let dirty networks tank the battery" feature?I have yet to see an example of something that disablingmulticast in suspend breaks. Signed-off-by: entropy512
  • reapply bcmdhd: change packet filter settings to block multicast
  • bcmdhd: update wireless driver to 1.28.11.9 from Korean S3 (gokhanmoral)
  • mmc: Increase timeout - this tweak for some crappy cards (andreilux)
  • Revert:"disable GENTLE_FAIR_SLEEPERS"
  • reduce busfreq volt to -25mV
  • set sched_mc_power_savings to 1
Quote:
Big thanks to : V1.0 beta tester:
Milchbeck
skivnit
JYJY
ph3nom
poppy9009
6pudu5
jothi2lingam
kandem
ksr007
brunodu91
Sad56
samaxen
RuralGalaxy
JB-V1.0
Jelly Bean v1.0 Change Log:
  • Compile with linaro 4.7 2012.9
  • Triangle Away support.
  • ADB active while in recovery mode
  • Bigger RAM limit
  • USB faster charge (only effect with usb 3 port)
  • CFQ as default I/O Scheduler
  • Pegasusq as default I/O Scheduler
  • mms-ts: Disable touch booster
  • mali: reduce utilization sampling timeout
  • Add ARM cpu topology definition
  • pegasusq: add tweak from galaxsih ICS v3.9 pegasusq tweak
  • enable arch_power
  • disable GENTLE_FAIR_SLEEPERS
  • Proportional Rate Reduction for TCP.
  • Disable Various Debugging
  • Custom Voltage / U/V Interface control support (tested with voltage control & setcpu)
  • Undervolt GPU to -25mv for all frequency
  • Update wifi driver to 1.28.11.9
  • cpupower: update the cpu_power according to cpu load (thanks to andreilux to make it work)
for more detail change log goto:
https://github.com/harunjo/galaxsih-kernel-JB-S3
ICS Kernel Version
6.0
Quote:
beta tester:
  • deadsoullp
  • JYJY
  • jothi2lingam
  • apeiron6
  • N78006
  • samaxen
  • delgamarco
  • dladz
  • mobilevirus
  • CRBoy47
  • hieupham
  • RuralGalaxy
  • walda
  • Jekle_Ace
  • ongchonghian
  • mariosraptor
  • sunwee
  • ph3nom
  • telenger
thank for your help guys!
-Fix arm topology patch
-Fix broken sound with MHL adapter, edit: confirm its fixed with v6.0
-Disable touchbooster mali (disable again, i think (mali: reduce utilization sampling timeout) is enough for smoothness)
-Kernel patch from 3.0.42 to 3.0.43
-Bigger RAM - Changed memory mapped regions’ allocation sizes (by AndreiLux).
-Patch MTP driver to samsung source update 2
revert:
-Modify unicast filter and ignore IPv4 multicast except for mDNS
-mmc: increase read and write timeouts for bad SDHC cards
-modem_if: make modem driver silent
-revert HRTICK to 0
-kernel compression revert back to gzip
-pegasusq tweak back to 3.9 tweak
5.0
Quote:
beta tester:
  1. JYJY
  2. Milchbeck
  3. jothi2lingam
  4. hieupham
  5. CRBoy47
  6. MuertoKo
  7. marioh
  8. ph3nom
  9. samaxen
  10. 6pudu5
  11. apeiron6
  12. poppy9009
  13. N78006
  14. Simow.b
  15. ksr007
  16. Chillz88
  17. mariosraptor
thanks for your help guys!
credit: AndreiLux
-ARM: 7011/1: Add ARM cpu topology definition
The affinity between ARM processors is defined in the MPIDR register.
We can identify which processors are in the same cluster,
and which ones have performance interdependency. We can define the
cpu topology of ARM platform, that is then used by sched_mc and sched_smt.
Signed-off-by: Vincent Guittot
Reviewed-by: Amit Kucheria
Signed-off-by: Russell King
-Alternate wakelock stats labeled as "Discrete" instead of "Exclusive"
credit: Tungstwenty
gokhanmoral:
-pegasusq (based on ondemand): cpuidle detection
Signed-off-by: Andrea Arcangeli
ported by: gokhanmoral
-Linaro Compiler update to 2012.18
-disabling printks - hardcore
-sdcard sdhci: Remove Samsung's broken hack
Signed-off-by: Andrew Dodd
-sound Fix debug level
-max77686: Fix debug statements
4.0
Thanks to v4.0 Beta Tester:
Quote:
-ksr007
-ph3nom
-mariosraptor
-hieupham
-MuertoKo
-Jekle_Ace
-apeiron6
-Milchbeck
-Chillz88
-kenzolo
-pidz
-sunwee
-jothi2lingam
-samaxen
-poppy9009
-walda
-amaliapika
-spencer1208
-mkh@xda
-alerems
- Update kernel from 4.0.41 to 4.0.42
- Re-Enable Touchbooster
- Increase USB charging mAh to 800 so you can charge faster via usb3
- voltage control fix, compatible with most of undervolt application - tested with voltage control and setcpu
AndreiLux:
-Disabled the Kies daemon, I see no point in it and it uses up memory uselessly. Obviously Kies won't work any-more, if you want you can start the service yourselves manually.
-silence the touchscreen debug
-Decreased Mali utilization timeout to 100ms down from 1s which improves reaction time on instant GPU loads (Lock screen is best example).
-gokhanmoral:
-Fix media scanning problem with new clockworkmod
-add efs-backup script
-s3cfb: brightness curve mod
dorimanx:
- Shut Modem logs after new modem update.
- arm: smp: Wrap backtrace IPI with irq_enter/exit
This appears to be something that should also be wrapped. Also,
the backtraces experienced may be a cause and not a symptom -
instead of an RCU stall causing backtraces, backtraces
may be causing an RCU stall - which causes more backtraces
and then the system gets mental.
-lib/checksum.c: optimize do_csum a bit
Reduce the number of variables modified by the loop in do_csum() by 1,
which seems like a good idea. On Nios II (a RISC CPU with 3-operand
instruction set) it reduces the loop from 7 to 6 instructions, including
the conditional branch.
Signed-off-by: Ian Abbott
Signed-off-by: David S. Miller
-init/main.c: execute lockdep_init as early as possible
This patch removes the lockdep warning[1] on ARM platform.
The warning is caused by printk inside smp_setup_processor_id.
It is safe to do this because lockdep_init doesn't depend on
smp_setup_processor_id, so make printk can be called as early
as possible without lockdep complainment.
Signed-off-by: Ming Lei
!!ACHTUNG!!
NUR FÜR SAMMY JB ROMS!!!
QUELLE
Reaktionen: JasonMason, craP_cillA, sagi_t und 4 andere
Gleich mal testen, bisher hat mich noch kein CK überzeugt.
wo soll denn dieses init.d tweak und script sein? unter system/etc/init.d ist nichts.
ist bei euch auch von 200mHz-1200mHz als default eingestellt?
Bei mir lief der Kernel etwas instabil gerade bei Auslastung ... gab einige fc.
liegt vll eher an deiner baseband.... ich hab mit der turkbeyrom keine probleme bis jetzt
Das könnte sein, werde es nochmal in einer anderen Kombination testen.
ich weiß ja nicht in wie weit das samsung update 3 schon auf die BLG1 funkt...denn diese ist denke ich der LFB um einiges voraus
2.1 ist raus ... infos im ersten Post
Masta_Gee81 schrieb:
2.1
-modified post init script
Simone201:
post init tweak,init.d and clean script
using 600Mhz as TouchBooster freq saves some battery juice and has the same smoothness
wo soll man denn das finden???? ist bei mir nichts im init ordner drinnen.
Sorry ich hab den Kernel nicht drauf ... kann ich dir leider nicht sagen :o
Dank für die Nutzung meiner Kernel
mein Kernel nur init.d unterstützen, prüfen und erstellen / system / etc / init.d Ordner jedes Boot, so dass Sie Ihre init.d können zwicken setzen mit diesem Kernel auf / system / etc / init.d /
sori for my bad language..i was translate it using google translate :o
Reaktionen: akaebi
Der Kernel ist ja richtig sparsam und läuft gut
Wahnsin :)
Reaktionen: harunjo
Wahnsin :)
danke !
Ich freue mich Sie enyoy es.
V2.2 hochgeladen
Reaktionen: luschi-uschi und alf328
harunjo schrieb:
harunjo, dein init.d support des kernels geht nicht in verbindung mit dem external2interalsd mod
in english: your kernel doesnt work with the external 2 internal sd modification tweak. you say your kernel support init.d, but it seems not to work....
2.3
Mali Platform Rewrite from Andreilux
and also Thanks for your help to resolve compile error
init.d support geht trotzdem noch nicht
Ich sagte mein Kernel ist die Unterstützung init.d.
vielleicht ist dies, weil busybox? .. siyah Kernel haben eingebaute busybox in / sbin /
mein Kernel derzeit busybox darauf gebaut haben und nicht über Plan, um es an meinem Kernel aufnehmen,
Vielleicht möchtest Du busybox installieren müssen, wenn Ihr nicht über rom es auch, Play Download busybox Installateur bei Google und installieren Sie es.
Oder Sie MOD Die external2internalsd zu Ihrem System busybox Pfad verweisen.
Ich persönlich dont Verwendung external2interalsd mod ..., und auch mein Ziel, wenn beschlossen, einen eigenen Kernel ist Akkulaufzeit bauen .. so external2internalsd Modifikation ist nicht meine größte Sorge .. da läuft App von externen SD Akkulaufzeit essen
i said my kernel is support init.d.
maybe this because busybox? ..siyah kernel have busybox builtin in /sbin/
my kernel dont have busybox built on it and not have plan to include it at my kernel,
maybe you need to install busybox if your rom does not have it also, download busybox installer at google play and install it.
or maybe you just mod the external2internalsd to point to your busybox system path.
personally i dont using external2interalsd mod..., and also my objective when decided to build a custom kernel is battery life.. so external2internalsd modification is not my main concern..since running app from external sd will eat battery life.
Reaktionen: diddsen und akaebi
V 2.5 ist heraussen.
Ich benötige bei V2.4 fast nur Idle 1,285 % /h. Mit dem SpeedMod waren es ~1,7 %.
Bin kein Benchmarkjunkie aber er läuft generell genauso Smooth wie ich es mir erwarte, keine Lags oder Ruckler im normalen Gebrauch.
PS: Great work @harunjo. Keep it up! Thank you!
Fantastisch
Checkrom 3.5 mit GalaxSih 2.5
Danke für die Arbeit.
Reaktionen: alf328 und Masta_Gee81
Oebbler
SiggiP
Oebbler
Borkse
Oebbler
SaschaKH
SaschaKH
