[Kernel][GPL]Ninphetamin3 - Current rev: 1.2.0[11/07]
  • 100 Antworten
So_ony
So_ony
Hey Leute !
Möchte euch hier einen neuen Kernel vorstellen!
Original Link zum Kernel auf XDA:
It's here...[Kernel][GPL]Ninphetamin3 - Current rev: 1.0.0 - xda-developers
Source code:
All source code for the kernel can be found at the Ninphetamin3 Github repo, located at
https://github.com/Ninpo/ninphetamine3
FAQ:
Q: Is the kernel compatible with AOSP/CM9?
A: As of the first release, this is unknown. If it is not, an AOSP compatible version will be made available in a future release.
Q: OMG I'm not stable when I overclock to X
A: Your phone likely cannot handle the overclock. Get over it, and use a lower clock speed.
Q: How to I adjust the voltages for the cpu?
A: You can either use SetCPU's voltage interface, or you can do it manually through the UV_mV_table interface (if you don't understand how to manually adjust the table, just use SetCPU).
Q: What are the voltage limits?
A: The ceiling is 1500mV, the floor is 600mV.
Q: Why is Deadline the only available I/O scheduler?
A: After extensive testing, we've come to the conclusion that Deadline represents the best balance between performance and overall user experience. If you think otherwise you are officially incorrect until we determine otherwise, and shall be subjected to regular beatings by our army of rabid naked bunnies... and/or a place in "Post 5."
Q: Do the exfat modules get loaded?
A: Yes.
Q: How do I use the init.d script support?
A: Busybox needs to be installed into /system/xbin and your scripts go into /system/etc/init.d/
Q: Help, SetCPU wants to set my voltage to over 9000!
A: SetCPU has millivolts hard coded as a unit of measurement. The numbers reported are actually in nanovolts. Use usual millivolt settings (900 for 900mV, 1200 for 1200mV etc) and the clock interface will automatically convert.
Q: How do I use the GPU control interface?
A: Currently you change the values by echoing new values into a specific device file. If you echo 6 values, this will modify the clock up/down thresholds, if you echo 4 values, this will change the GPU speed at each step. For example:
Code:
echo "160 266 350 440" > /sys/class/misc/gpu_clock_contro/gpu_control
will restore default clocks.
Code:
cat /sys/class/misc/gpu_clock_control/gpu_control cat /sys/class/misc/gpu_voltage_control/gpu_control
To see the current values for each setting.
Changelog:
Revision 1.2.0:
- Updated to Samsung Update3 (LFB sources)
- Version bump to reflect base update
- Camera fix declared stable
Revision 1.1.0:
- A configuration option that was designed to keep more memory free
resulted in a huge degradation in performance over time. It has
reverted, and the minion responsible now resides at the bottom
of Crystal Lake.
- GPU Voltage and clock control added.
- The CPU should no longer lock at 1200mhz during GPU load
- No bunnies were harmed during the making of this build.
Revision 1.0.2:
- exfat modules not only load, but actually work!
(The culprit responsible has been reduced to a pile of ash)
- Undervolting floor lowered from 850mV to 600mV
Revision 1.0.1:
- The beast responsible for exfat modules not loading has been beaten
senseless with assorted blunt objects.
Revision 1.0.0:
- Initial release
- Overclocking to 1800mhz is possible, while possibly not stable on all phones. Overclock at your own risk.
- Deadline tweaked and set as default I/O scheduler.
- Module exception to allow loading exfat modules
- SHA1 algorithm improvements
- CRC32 algorithm improvements
- CPU Voltage control interface implemented - Debug overhead removed from config and assorted places in source code[/quote]Download:
Ninphetamin3-release-1.2.0.tar.md5
Ninphetamin3-cwm-1.2.0.zip CWM package
Ninphetamin3-release-1.1.0.tar.md5
Ninphetamin3-release-1.0.2.tar.md5
Ninphetamin3-release-1.0.1.tar.md5
Ninphetamin3-release-1.0.0.tar.md5
Yes, use Odin or Mobile Odin or Heimdall. I'll add CWM flashables later or at the next release.​
Reaktionen: DPT, craP_cillA, diddsen und eine weitere Person
oh je... bootloop...
pineingabe kommt kurz dann reboot
was für ne Rom hast du drauf? AOSP wird noch nicht unterstützt ;)
lf2 stock
diddsen schrieb:
kann sein dass es am exfat modul liegt, probier mal den 1.0.0 der müsste laufen :) heute nacht werden sie wahrscheinlich noch an nem fix arbeiten :)
Wuhu, der kernel war beim sgs2 richtig nice, mal schaun was das team sich fürs s3 einfallen lässt ^^
1.0.2 ist raus. ExFat läuft.
Gesendet von meinem GT-I9300
Reaktionen: diddsen und So_ony
Danke habs mal angepasst :)
Der Kernel läuft echt super ! Wieder mal gute Arbeit von den Devs !
Habe ihn seit heute morgen drauf. Bisher ganz nett.
Das einzige was ich "komisch" fand: Deadline sollte ja der Standard Scheduler sein, bei mir war es aber Noop.
Mal beobachten wie er sich den Tag über so schlägt...
Grüße
Andi
kann ich bestätigen... war auch noop eingestellt.
hab mal auf deadline umgestellt...
wie ist der Kernel vom Akku verbrauch
also ich finde... besser als alles andere was ich bisher probierte!
das freut mich zuhören dann werde ich mir den mal Laden und Testen, denn der Siyah läuft Spitze, aber frist am Akku ohne ende
ich bin kein siyah jünger ;-)
So kernel ist drauf mal sehen wie er sich macht, aber erster eindruck läuft nicht schlechter wie der Siyah
Melde mich wieder wen ich mehr Sagen kann
wie kann ich umstellen von noob auf deadline?
mit Voltage Control app aus dem Market
edit : Tegrak geht nicht
Hab den Kernel jetzt 1/2 Tag drauf. Dass er ansich gut läuft, kann ich bestätigen, aber wie bei Siyah, ist mir der Akkuverbraucht zu hoch.
~4% pro Stunde in der Hosentasche ist zuviel.
Mit Abyss habe ich ~2%.
Also wieder zurück.
mir ist was aufgefallen, und zwar wen der lockscreen an ist und display aus wacht das Handy immer mal wieder auf.
Weiß nicht ob das noch bei jemandem anderen ist ??
Ist halt nicht gerade schön wen man das handy in der Hosentasche hat
Saugt dann am akku. Die Farben finde ich sehr schön macht das ganze sehr frisch finde ich
weiter so und Bitte die kleinigkeit beheben
Danke
Oebbler
SiggiP
Oebbler
Borkse
Oebbler
SaschaKH
SaschaKH
