[KERNEL][DUAL-BOOT] Googy-Max Kernel2 2.1.3 (Linux 3.0.101 / Linaro 4.8.2)
  • 702 Antworten
rk#
rk#
This kernel is ONLY for SAMMY4.3 / CM11 / OMNI / TEMASEK (r3p2) !!!
Dualboot IS WORKING !!! (reboot to desired rom via stweaks dualboot tab or via @Derteufel1980 recovery)
Aktuelle Version: 2.1.3 Changelog
Daten zum Kernel:
- Based on Samsung Update13 Sources
- Updated to latest XXUGMK6 ramdisk
- Linux version 3.0.101*:good:
- Compiled with linaro gcc 4.8.2 with Neon and Hard-Float :good:
- DUAL Sound-Engine : Audio enhancement and sound boosting for great headphone experience (Wolfson Sound Engine*AND ScoobyDoo Sound Engine 1.1*selectable via STweaks)
- Touch-to-Wake support
- Cpu OC support (up to 1600Mhz)
- Cpu UV support
- Gpu OC support (up to 700Mhz)
- Gpu UV support
- Governors : Pegasusq [default] / Zzmoove 0.7d / Lulzactiveq (Configurable via STweaks :good: )
- I/O Schedulers : Deadline - cfq[default] - noop - row - sio - vr - fifo
- Xpad support
- TriangleAway support
- Network filesystems support (nfs, cifs, sunrpc)
- Dynamic FSync 1.2 - Configurable via Stweaks (Off by default)
- init.d support
- Custom bootanimation support (bootanimation.bin or bootanimation.zip to be placed in /data/local/)
- Increased values for SD ReadAhead - Configurable via Stweaks
- TCP congestion control (cubic[default]-wetswood-bic-hctp) configurable via STweaks
- Auto-root (updated to latest su and supersu with daemon autorun)
- NTFS automounting for USB sticks, mounted to /mnt/ntfs folder in Read Only mode
- Permanent TRIM
- ExFAT support (opensource)
- Charge current for AC & USB raised
- CRT-OFF support (Early Suspend) [Adjustable]
- Almost everything is configurable via simple and free STweaks (included in the kernel)
- more too come!
- Gokhanmoral !!!
- @Yank555
- @DerTeufel1980
- Samsung : For the code source :p
- @arbi97, @davtse, @FadeFx, @habylab, @qtwrk, @rafaelpernil & my friend @romskii : my first and only beta testers ;) (Beta team is now complete, no more additions)
- @qrashers for the Googy-Max Kernel logo & user / betatester signatures
- and last but not least, THE WONDERFUL XDA COMMUNITY !!!
https://github.com/googyanas/Googy-Max2-Kernel
XDA Thread:
(15/12) Googy-Max2 Kernel 2.0.8 (Linux 3.0.101 / Linaro GCC 4.8.2) - xda-developers
Changelog
Download Official Release
Download Test Version
Contributors
googy_anas, arbi97, davtse, FadeFx, habylab, qtwrk, rafaelpernil, romskii (Beta team is now complete, no more additions)
Kernel Special Features:
Version Information
Status: Testing
Reaktionen: craP_cillA
This kernel is ONLY for SAMSUNG 4.1.2 ROMS OR CM10.1/CM10.2/CM11 (or both :thumbsup:) !!!
SAMSUNG 4.3 ROMS (and roms using r3p2 mali drivers) are NOT supported by this version.
/* if your rom is based off PAC, Bam, Fusion, ... *
/* Generic framework "framework-2.jar" introduced *
/* (teamed up with Yank555, DerTeufel1980, AndiP, Psndna, Temasek), *
/* this is to get rid of proprietory framework naming conventions *
/* and come up with an aligned approach between rom and kernel devs. *
/* For now, specific framework for Pac Man remains added, *
/* but for a grace period only. *
/* Those will be removed with the first update after November 10th. *
/* So please do pass this message along to your favorite ROM devs, *
/* we will stop supporting additional frameworks with specific ROM names. *​
Der Googy-Max Kernel basiert auf der wundervollen Arbeit von Gokhanmoral (Siyah Kernel).
Aktuelle Version: 1.8.0 Changelog
Daten zum Kernel:
- Based on Siyah Kernel 1.9.1 Sources
- Dual-booting. You can have Samsung JB and CM10.1/CM10.2/CM11 ROMs on a single device at the same time
- Updated to latest ramdisk
- Patched to Samsung Sources Update11*
- Wireless hotspot working on sammy & cm
- Touchkeys backlight configurable mode [Sammy - cm10.2 or CM11] / [cm10.1] vis STweaks
- SELinux support
- ZRAM activated and configurable in STweaks (On/Off (Off default) - (up to 4 disks) Zram disksize (total 400MB default) - Swappiness(80% default) )
- CPU OC/UC/UV
- GPU OC/UC/UV
- Adaptive Body Bias control
- DUAL Sound-Engine: Audio enhancement and sound boosting for great headphone experience (Wolfson Sound Engine*AND ScoobyDoo Sound Engine 1.1*selectable via STweaks)
- Governors : Pegasusq [default] / Zzmoove 0.7d / Lulzactiveq (Configurable via STweaks )
- Improved cpu hotplugging mechanism
- init.d support
- Auto-root
- Kernel based gestures support by Tungstwenty
- mDNIe values can be adjusted using the interfaces in /sys/class/misc/mdnie
- Charge control for AC & USB chargers [Adjustable via STweaks]
- Led control [Adjustable via STweaks]
- Touch-to-Wake 1.1a configurable via STweaks
- Xbox controller support
googy_anas von XDA
- Gokhanmoral : For the wonderful base !!!
- @Yank555 for his help and support
- @DerTeufel1980 for his help
- @arbi97, @davtse, @FadeFx, @habylab, @qtwrk, @rafaelpernil & my friend @romskii : my first and only beta testers (Beta team is now complete, no more additions)
Source: (Up-to Date)
https://github.com/googyanas/Googy-Max-Kernel
XDA Thread:
[KERNEL][DUAL-BOOT][JB] (10/12) Googy-Max Kernel 1.8.0 (Linux 3.0.101 / Linaro 4.8.2) - xda-developers
Changelog
Contributors
Version Information
Status: Testing
Hört sich gut an. Hat ihn jemand schon getestet? Läuft soweit rund?
Vlt kannst du den xda thread noch mit aufnehmen.
Reaktionen: fr3ak87
Wollte den gerade mit reinsetzen :p ist mir auch eben aufgefallen.
Der Kernel läuft super. Sehr gute Batterielaufzeit und keine lags, einfach testen :) ich freue mich auf das Feedback
also Dualboot und zzmoove hat schon was :) Klasse natürlich auch das bekannte sTweaks.
Würde ihn auf jedenfall bei meinem nächsten Romchange mal testen.
Mal sehen wie der Support und vor allem die Updates sind. Linaro ist übrigens bei einem Feldversuch von Yank nicht unbedingt der beste.
MfG
Also mit dem Linaro bin ich positiv überrascht, nur der zzmove governor hat mich enttäuscht. Googy hat bei dem pegasusq ganze Arbeit geleistet. Mit seinen Tweaks bin ich ein Fan von diesem governor geworden.
zzmove soll wohl ein bisschen Akkulastiger sein. Das Gefühl habe ich, zumindest gegenüber Siyha 1.9.1 mit pegasusq nicht. Aber kann ja sein, das googy hier was verändert hat.
hier mal was zu Linaro:
yank555 schrieb:
Neuer Zwischenstand der Toolchain-Umfrage, nun wo die Toolchains bekannt sind, schon lustig :D
Google 4.4.3 : -3% (27% runter auf 24%)
Google 4.7 : -3% (58% runter auf 55%)
Linaro 4.7 : +5% (15% rauf auf 20%)
Nimmt man nur die neuen Stimmen :
Google 4.4.3 : +3 -> 15% (27% runter auf 15%)
Google 4.7 : +9 -> 45% (58% runter auf 45%)
Linaro 4.7 : +8 -> 40% (15% rauf auf 40%)
Marketing am Werk :D
Yank hatte seinen Kernel mit den 3 Toolchains compiliert und 3 Versionen veröffentlicht OHNE zu verraten, welcher dahinter steckt. Das Ergbniss ist eigentlich eindeutig. Nur 15% der User bevorzugten die Linaro Version.
Nach Bekanntgabe änderte sich das rasch;)
Linaro hat wohl ein Applemarketing :D
Das möchte ich nicht bestreiten. Ich fühle mich mit dem Googy Kernel sehr wohl. Ob es an Linaro liegt oder seinen super Tweaks kann ich echt nicht sagen.
Für mich war auch der Dual Boot wichtig, mit dem Siyah Kernel lief es nicht rund.
gibt nun ne version 1.2
[13/05] Version 1.2.0 :
- Updated to Linux 3.0.78
- Activated Zram with updated lzo compression
- Some pegasusq optimizations
- lulzactiveq is now set by default
- No more lags !!!
Gut aufgepasst :p ich war noch mit der Test version beschäftigt, dachte nicht das Googy so schnell ist.
Aktualisiere den Thread jetzt, endlich Zuhause
Edit: Thread aktualisiert.
Version 1.2.0 online. -> Nun sollten alle lags, die bei Version 1.1.0 zum Vorschein kamen behoben sein. Viel Spaß euch. Ich freue mich auf euer Feedback
Läuft gut bis jetzt
Gov : row
Mhz: 1600
Reaktionen: rk#
golf3heizer0503 schrieb:
Läuft gut bis jetzt
Gov : row
Mhz: 1600
welcher governer? Du hast als scheduler row :tongue:
Was sagst die Akkulaufzeit? Ich habe aktuell seit gestern Abend 20 Uhr 23% verloren :-D seitdem 4 Stunden on Screen.
ah sry ;D
habe lulzq als gov und row als sheduler =)
ah sry ;D
Und wie läuft es?
Zzmoove-row Top:D
Gesendet von meinem GT-P5110 mit der Android-Hilfe.de App
Reaktionen: rk#
Bei mit läuft der kernel absolut Genital # genial xD
Zusammen mit der slim 10.1 Rom
Reaktionen: rk# und janosik
Kann plus bestätigen:D:thumbup:
Ich habe für euch mal eine Version ohne ZRam und mit weiteren pegasusq Tweaks von Googy :biggrin:
Viel Spaß beim testen und ich bitte um Feedback :)
  • Googy-Max-Kernel_1.2.0_NoZram_PegasusTweaked_CWM.zip
Geiler Kernel
Reaktionen: janosik und rk#
Oebbler
SiggiP
Oebbler
Borkse
Oebbler
SaschaKH
SaschaKH
