KingJames23
Stamm-User
- 487
Die V1.3 ist erschienen.
Changelog
Changelog
ArchiKernel V1.3
- Enabled LED fading/blinking support
- Enabled haptic control on AOSP roms like CM/Omni
- Enabled voltage control of the CPU
- Enabled overclocking of the CPU to 1600Mhz
- Enabled GPU clock control and voltage interface
- Enabled touch LED control
- Updated ZZmoove to 0.9 beta3
- Enabled SELinux
- Enabled ext4 security labels # This fixes being unable to mount ext4 sd cards, reported by Senior_Limpio
- Enabled OC by default # This enables 1600 MHz by default, you can still go back to 1400 via sysfs
- Fixed CVE-2014-3153
- Fixed frequency slider in performance settings # Found i.e. in Omni
- Cleanup of ArchiKernel settings
- Enabled SELinux
