[KERNEL][22/12] - Kernel 3.0.56 HydR3xtReme-2.6g - For Battery Performance- JB
  • 3 Antworten
Q
quasimodo
Gast
Ich, Android-Hilfe.de oder die Entwickler/Publisher der ROM oder Mods,
übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
Ihr seid daher für euer Handeln selbst verantwortlich!!!
Achtung: Rein zur Info reing
estellt,
wer Lust hat den Beitrag zu Übernehmen, kann dies gerne tun!
HydR3xtReme-2.6g
JB Kernel for Samsung Stock ROMS
Only for stock jelly bean ROMS
EXTREME won't work in all mobiles so, if don't work extreme for you, put Semi.​
The config:
  • Based on 3.0.56 - Yank.555 with patches, configs, optimizations and tweaks (so thanks to Yank)
  • OC up to 1800mhz.
  • Reduced low cpu steps to get some performance (Deleted 300mhz, 400mhz, and 600mhz)
  • Voltages:
  • EXTREME:
    Cpu arm : -112,5mv in all freqs from 200 to 1500mhz (low freqs as 200,500 +12,5mV)
    Cpu internal: -50mv in all freqs
    Bus: -100mv in all freqs
    Gpu: -100mv in all freqs
  • SEMI:
    Cpu arm : -100mv in all freqs from 200 to 1500mhz (low freqs as 200,500 +12,5mV)
    Bus: -75mv in all freqs
    Gpu: -75mv in all freqs
  • MEDIUM:
    Cpu arm : -87,5mv in all freqs from 200 to 1500mhz (low freqs as 200,500 +12,5mV)
    Gpu: -50mv in all freqs
  • Tree RCU+NO_HZ
  • SIO Iosched enabled by default and tweaked.
  • Governor hydrxq (based pegasusq governor with some tweaking, if you see it drains much with this governor, you can select pegasusq governor with voltage control)
  • Disabled Tracing, logging, and debugging.
  • Some compiler CFLAGS optimizations added (linaro toolchain)
  • Tweaks de memoria virtual, I/O, kernel y scheduler.
  • Set wifi power limit to 8dBm.
  • Max powersave in sleep mode with some modifications and screenstate:
    *More stable GPU voltajes set on the fly when you screen off the display (min 775mV).
    *Cleaning of cache/inodes when you screen off, and each 6 hours.
    *laptop mode enabled with screen off.
    *some tweaks more when you screen off I consider they save power.
  • Priorized some system apps at boot, to get some a performance system..
  • Auto script to close all possible samsung apps at boot.
  • Swap compatible, but not used for now.
  • Stand alone hotplug tweaked to low usage of cores.
  • Sound eargasm voodoo patch added controlable with STweaks from market. (thanks to gokhanmoral)
  • Tweaks mdni, for better colors.
  • More powersave in 2G/3G networks and wifi supplicant time modified.
  • I forget some things I'll put more.
  • etc
GPL: https://github.com/NeoPhyTe-x360/i9300-JB-kernel
[*] It's not compatible with 64GB exFAT sdcards (if you like to see your files you have to format your sd64 in FAT) [It's a common issue with updated kernels and proprietary modules]
Reaktionen: Marzl85 und mareis1973
Bei mir hängt er sich immer auf, egal welche Version ich nehme.
Gesendet von meinem GT-I9300
Es gibt schon ne neue Version :D
Gesendet mit meinem Android Smartphone :)
Moin.
HydR3xtReme-2.7a
The config:
  • OC up to 1800mhz.
  • Voltages:
  • EXTREME:
  • SEMI:
  • MEDIUM:
    Cpu arm : -62,5mv in all freqs from 200 to 1500mhz (low freqs as 200,500 +12,5mV)
    Cpu internal: -37,5mv in all freqs
    Bus: -50mv in all freqs
  • Tree RCU+NO_HZ
  • Governor hydrxq (simply a lulzactiveq governor with tweaks to performance (thanks to tegrak), if you see it drains much with this governor, you can select pegasusq governor with voltage control)
  • Tweaks virtual mem, I/O, kernel & scheduler.
  • etc
  • [KERNEL][24/12]· ▀▄ · Kernel 3.0.56 HydR3xtReme-2.7a - For Samsung Stock-JB - xda-developers
Reaktionen: Marzl85
Oebbler
SiggiP
Oebbler
Borkse
Oebbler
SaschaKH
SaschaKH
