[Kernel][20 Jun.][GT-I9300][Stock Feel][2.6] Adam Kernel
  • 14 Antworten
Caho
Gast
-This kernel works only for Samsung 4.1.2 ROMs-
/!\ Flash it at your own Risk /!\
Wanam präsentiert seinen eigenen Kernel für Sammy Rom's.
Anleitung,
Wie flashe ich den Kernel? über CWM
1. Die Zip.Datei legt ihr auf eure ext.SDCard
2. Danach in das Recovery booten und choose from SDCard klicken
3.navigiert zu dem Verzeichnis wo die Zip liegt
4. die Zip auswählen und mit dem Homebutton bestätigen
5. Wenn der Flashvorgang beendet ist, Handy neustarten und freuen
The main goal of this kernel is to keep it stable and close to stock. It contains a few CPU and Memory optimizations for better balanced performance/battery life (the same tweaks i have on all my Roms), it includes Stweaks, Boeffla Sound, and "init.d" support so you can tweak as you like.
Features:
Built from Samsung GS3 sources Update10 (Sudden death & Exynos bug fixes included)
Battery charging control Trough Stweaks App (AndreiLux implementation, Big thanks to him)
Stweaks App support (Used AndreiLux customization of GokhanMoral generic interface, Big thanks to them)
Auto install of Boeffla Sound and Stweaks Apps (Thanks to Simone201 and Gokhan)
Boeffla sound App support (Thanks to AndiP and Simone201)
Reduce Battery monitor wakelocks (Thanks to AndreiLux)
Added IO schedulers: SIO & ZEN & ROW (Thanks to AndreiLux and Yank555-lu)
Enabled Car Dock charging
Triangle away support (Thanks to IndiP and Delute)
Compiled CIFS as module
Compiled NFS as modules (it depends on the compiled modules “sunrpc” and “lockd”)
Compiled NTFS as module
exFAT support
Dynamic FSyn control
Init.d support
Added support for Crt-Tv Off Animation (thanks to Codeworkx and Perka)
Tegrak overclock App support (CPU/GPU optimizations - OC/UV)
Built with Stock ARM Toolchain 4.4.3
Zmoove and Lulzactiveq cpu governors (Thanks to the Authors)
Proportional Rate Reduction for TCP (Thanks to Nandita Dukkipati)
CPU voltage control for UV trough Stweaks (Thanks to AndreiLux)
Black crush fix (Thanks to Andip and AndreiLux)
Auto Root (if Not Rooted)
(SuperSU 1.30)
Disabled Wifi multicast (Thanks to Entropy)
Increased timeout for some bad Sdcards
Disabled Android Logger
Switch Android Logger ON/Off trough Stweaks (No Reboot required, Thanks to AndiP for the Sysfs interface).
Tweaked Pegasusq CPU Gov
Enabled Swap and Zram
Control CRT Off delay trough Stweaks (default=100ms) (Thanks to AndreiLux).
Download.
Sources: https://github.com/wanam/Adam-Kernel-GS3
Credits by Wanam.
CAHO
Schön das es noch einen neuen Kernel gibt!
Aber ich sehe noch nicht so ganz die Vorteile zu den anderen Kerneln bzw. zum Stock. :confused:
Im Prinzip ist das doch 1:1 der Stock , nur mit den Extras die oben angezeigt werden.
Reaktionen: Hcolhcsra
Ja, das ist der Vorteil.
Stock-Kernel mit ein paar Extra-Modulen.
Für alle die, die den Stock-Kernel wollen, aber für ihre 64GB SD-Karte exFAT brauchen zum Beispiel.
...der stockkernel unterstützt doch schon exfat...wizu also der Kernel?
gesendet vom letzten Jahr auf folgenden Festivals
Nun, dann eben NFS.
Spielt ja keine Rolle.
Abgesehen davon musst du ihn ja auch nicht flashen.
Ist eigentlich nur ein Stock Kernel mit init.d support, dem early suspend delay für die CRT Off animation und den 2 Modulen.. Also echt nix besonders und auch nicht wirklich sinnvoll.. Aber vielleicht gibt es ja Leute, die es so krass nah an stock mögen ;)
TheSpiritof69 schrieb:
Nun, dann eben NFS.
spielt wohl ne Rolle wenn man den Nutzen eines Kernel diskutieren möchte.
abgesehen davon hättest du dir deine Bemerkung auch sparen können, da ich immer noch selbst entscheide, was ich flashe oder nicht....
Wenn der Mehrwert eines Kernels für dich nicht besteht, heißt das nicht, dass der für niemanden besteht.
Wieso soll dieser Kernel nutzlos sein, bloss weil er kein OC hat oder keinen eigenen Governor oder sonstiges special feature? Bzw. er nicht dein Nutzverhalten anspricht?
Es ist ganz klar angegeben was der Kernel kann, wenn jemand genau das erwartet ist dieser Kernel genau richtig.
Zusätzlich ist die Möglichkeit, die Wahl eines Kernels zu haben niemals nutzlos.
Deine Frage sorgt lediglich für unnötige Diskussion (an der ich mich sogar noch beteilige) und müllt hier im Endeffekt den Thread zu.
Es ist ein Update da, Adam Kernel V1.4 Faster USB charging – I9300
Faster USB charging (700mAh)
Enabled ARM CPU topology
Enabled Swap support
Startpost Aktualisiert. Desweiteren bitte Ich darum nun jegliche Äußerungen darüber zu unterlassen ob es sinnvoll ist den Kernel zu flashen oder nicht. Wer Ihn nicht haben will muss Ihn auch nicht flashen,ergo sind solche sinnlosen Kommis zu unterlassen!
CAHO
Reaktionen: Gene S, jomi und TheSpiritof69
Eigentlich soll der Link eingebaut sein, ein Fehler meinerseits, trotzdem Danke.
Bisschen empfindlich was? :rolleyes:
Wenn dich der Kernel nicht ineressiert oder du ihn als nutzlos erachtest dann ignoriere doch einfach diesen Thread, den ein oder anderen wird es schon geben der interesse an diesem Kernel hat.
das hat aber jetzt gewaltig was zum Thema beigetragen..danke!
Adam Kernel V2.2.1
Adam Kernel V2.2.1 -
Changelog:
Workaround to enable the Equalizer on Note2
Fixed IO Scheduler Settings on Stweaks
Other small fixes
Oebbler
SiggiP
Oebbler
Borkse
Oebbler
SaschaKH
SaschaKH
