The-Tapper
Hier einmal ein Stock Kernel für das I9300
Android 4.3 AGNi pureSTOCK v3.2c
- CPU GOVERNORS: conservative, ondemand, powersave, hotplug, adaptive, interactive, performance, userspace, lulzactive, lulzactiveq, pegasusq, Zzmoove 0.7d
- I/O GOVERNORS: deadline, cfq, row v4, sio (tweaked), noop, vr, bfq-v6r2
- CIFS & NFS Network FileSystems support
- Boeffla sound v1.6.4 supported but not enabled by default (use automatically installed Boeffla Sound app)
- tweakable led fading notifications
- swap support enabled
- cleancache enabled
- automatic efs backup on internal sdcard
- CRT-OFF friendly
- 300MB LZ4 Zram with zcache
- uses my compiled busybox (v1.22) integrated in kernel to support swap device priorities
- kernel uses LZMA compression
- Triangle Away support
- SAMSUNG Open-Sourced exFAT support v1.2.4
- Dynamic Fsync v1.2, Battery Charging voltages support
- CPU OC(1.6GHz) & UV support
- integrated second prioritised optional AGNi preloadSWAP option in Boeffla app
- CWM-FLASHABLE OC/UV boot failure reseter tool automatically placed on internal sdcard
- Touchboost & Touchwake implemented
- GCC 4.7.2 toolchain compiled arm-v7l cortex-a9 neon optimised
- Implemented Zram modifications with 4 zram devices support
- AGNi Main user profiles (Extreme Battery Save / Battery Save / Normal / Gaming) which does not break NON-OC limits but user can override settings at will
- Drop & forget for init.d scripts (user doesnt need to set permissions manually)
- Linux kernel upstreamed to 3.0.101
- 11-11-2013: Update v3.1 :-
Reduced WiFi wakelocks | some performance improvements | internal & external SD read_ahead_kb values user tweakable | Implemented Power Saving CPU load balancer (sched_mc_power_savings) | user changable Quad-Zram implementation(with equal swap priority) size and swappiness - 01-12-2013: Update v3.2 :-
added ignore unstable power charging option (changed custom charging code implementation) | some code change regarding how boeffla sound is handled upon boot | Mali r3p2 OC/UV implementation (now users dont have to OverVolt GPU when GPU OC) | reduced some mali debug messages - 02-12-2013: Update v3.2a :-
applied fix for broken MALI r3p2 GPU OC/UV sysinterface | introduced "160/266/350/400/440" GPU freq steps in Boeffla Tweaks - 16-12-2013: Update v3.2b :-
fixed HDMI sound issue | applied some mali gpu oc/uv fixes | Implemented CPU boost kernel driver experimentally | Auto Root SuperSU v1.80 - 21-12-2013: Update v3.2c :-
Updated to SAMSUNG OSRC I9300 Update 13 (XXUGMK6) | Auto Root SuperSU v1.86 | added settings backup and restore to Boeffla Tweaks and its reset settings will not need reboot and default settings will be applied instantly | Disabled some kernel debug support
