[TUTORIAL][KERNEL] Kernel Development Tuts
  • 29 Antworten
Wo hapert es den?
Hi
also ich bekomme erst diese Meldung, wenn ./build.sh -j1 starte
Code:
Checking build tools versions...
You are attempting to build with the incorrect version
of java.
Your version is: Fake java 1.6.0 revisiion.
The correct version is: Java SE 1.6.
Please follow the machine setup instructions at
    http://source.android.com/source/download.html
find: "../../external/nist-sip/java": Datei oder Verzeichnis nicht gefunden
da läuft es allerdings weiter und bleibt dann mit dieser Meldung stehen
Code:
frameworks/base/include/utils/KeyedVector.h: In instantiation of 'const VALUE& android::DefaultKeyedVector<KEY, VALUE>::valueFor(const KEY&) const [with KEY = android::String8; VALUE = android::sp<AaptSymbols>]':
frameworks/base/tools/aapt/AaptAssets.h:446:59:   required from here
frameworks/base/include/utils/KeyedVector.h:193:31: error: 'indexOfKey' was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
frameworks/base/include/utils/KeyedVector.h:193:31: note: declarations in dependent base 'android::KeyedVector<android::String8, android::sp<AaptSymbols> >' are not found by unqualified lookup
frameworks/base/include/utils/KeyedVector.h:193:31: note: use 'this->indexOfKey' instead
frameworks/base/include/utils/KeyedVector.h: In instantiation of 'const VALUE& android::DefaultKeyedVector<KEY, VALUE>::valueFor(const KEY&) const [with KEY = android::String8; VALUE = android::sp<AaptGroup>]':
frameworks/base/tools/aapt/AaptAssets.cpp:1636:41:   required from here
frameworks/base/include/utils/KeyedVector.h:193:31: note: declarations in dependent base 'android::KeyedVector<android::String8, android::sp<AaptGroup> >' are not found by unqualified lookup
frameworks/base/include/utils/KeyedVector.h: In instantiation of 'const VALUE& android::DefaultKeyedVector<KEY, VALUE>::valueFor(const KEY&) const [with KEY = android::String8; VALUE = android::sp<AaptDir>]':
frameworks/base/tools/aapt/AaptAssets.cpp:1700:53:   required from here
frameworks/base/include/utils/KeyedVector.h:193:31: note: declarations in dependent base 'android::KeyedVector<android::String8, android::sp<AaptDir> >' are not found by unqualified lookup
make: *** [out/host/linux-x86/obj/EXECUTABLES/aapt_intermediates/AaptAssets.o] Fehler 1
real    0m10.150s
user    0m5.228s
sys     0m2.356s
> Build failed! <
Bei ./build.sh kommt dieses
Code:
Done
Profile Ready: please run [b2g|firefox] -profile /home/rene/Daten/Auslagerung/Android/Samsung/Firmware/boot2gecko/Versuch1/B2G/gaia/profile
make[1]: Leaving directory `/home/rene/Daten/Auslagerung/Android/Samsung/Firmware/boot2gecko/Versuch1/B2G/gaia'
cd /home/rene/Daten/Auslagerung/Android/Samsung/Firmware/boot2gecko/Versuch1/B2G/gaia/profile && tar cfz /home/rene/Daten/Auslagerung/Android/Samsung/Firmware/boot2gecko/Versuch1/B2G/gaia/profile.tar.gz webapps user.js permissions.sqlite
real    0m12.929s
user    0m13.385s
sys     0m2.924s
> Build failed! <
Dachte es liegt an der Java-Version und habe OpenJDK1.6 deinstalliert und Sun-Java-JDK1.6 installiert, mit dem gleichen Ergebnis. Ich kann dummerweise nicht viel mit den Fehlermeldungen anfangen, was mich schon des öfteren angenervt hat bei anderen händischen Installationen.
MfG
Debian Stable oder Debian Testing/Sid am laufen?
Hi
Sorry, als Grundsystem Unstable/Sid, die Java-Version von Stable, da Sun-Java bei Wheezy rausflog.
MfG
Hi
auch wenn ich es ungern mache, Ubuntu mit Debian zu mischen, hab ich es mal versucht, aber genau die gleichen Meldungen.
java-version gibt das aus
Code:
java version "1.7.0_05"
Java(TM) SE Runtime Environment (build 1.7.0_05-b05)
Java HotSpot(TM) 64-Bit Server VM (build 23.1-b03, mixed mode)
also die aktuelle.
MfG
und wenn du
sudo update-alternatives --config javac
machst und auf oracle linkst?
Hi
da kommt das raus
Code:
Es gibt nur eine Alternative in Link-Gruppe javac (die /usr/bin/javac bereitstellt): /usr/lib/jvm/java-7-oracle/bin/javac
Nichts zu konfigurieren.
MfG
Hm sehr komisch :/
Ansonsten schmeiß das mal wieder runter..openjdk könnte noch eine Möglichkeit sein.
Hi
gesagt, getan und alles, wirklich alles geblieben. Liegt dann wohl nicht an java, würde ich behaupten.
MfG
