[Sammy-KERNEL] Phenomenal [4.0] -Gingerbread-
  • 639 Antworten
Gast5050
Gast
Based on speedmod k21.
All prevoius settings. LoadH is 85. For medium and normal memory voltages go back to stock values for stability.
extreme
CWM: http://dl.dropbox.com/u/33360162/phe...4.0Extreme.zip
ODIN: http://dl.dropbox.com/u/33360162/phe...4.0Extreme.tar
medium
CWM: http://dl.dropbox.com/u/33360162/phe...l4.0Medium.zip
ODIN: http://dl.dropbox.com/u/33360162/phe...l4.0Medium.tar
normal
CWM: http://dl.dropbox.com/u/33360162/phe...l4.0Normal.zip
ODIN: http://dl.dropbox.com/u/33360162/phe...l4.0Normal.tar
[KERNEL] Phenomenal [3.0] I want share with you my kernel.
I like speedmod kernel.
I like undervolting.
So, I compiled my kernel Phenomenal (I compiled it for my use).
But now I want share it with you.
It is jeffrey kernel philosophy applied on speedmod kernel, but should give more battery (me and my friends confirm this after some days of use)
NEW
Phenomenal 3.0
Black is based on speedmod k-19. Blue on speedmod k1-16.
For extreme: screen uv from 3.0v to 2.5v (-500mv). Camera related uv -50mv. All the others -100mv. Internal, arm cpu, gpu and bus are classic uv for extreme version
For medium: sceeen uv from 3.0v to 2.9v (-100mv). All the others -25mv. Internal, arm cpu, gpu and bus are classic uv for medium version
For normal: screen uv from 3.0 to 2.95mv (-50mv). All the others -25mv. Internal, arm cpu, gpu and bus are classic uv for nornal version.
Black extreme
CWM: http://dl.dropbox.com/u/33360162/phe...ackExtreme.zip
ODIN: http://dl.dropbox.com/u/33360162/phe...ackExtreme.tar
Blue extreme:
CWM: http://dl.dropbox.com/u/33360162/phe...lueExtreme.zip
ODIN: http://dl.dropbox.com/u/33360162/phe...lueExtreme.tar
Medium and normal versions removed causes some modules doesnìt support 25mv steps.. In next days I'll upload working versions
OLD
Phenomenal 2.2
Screen controller undervolt from 2500mv(phenomenal 2.1) to 2900mv (stock = 3000mv).
Added several undervolting in serveral modules (cam sensor, cam autofocus, memory,etc etc)
For black version, used loadH cpuHotPlug is 85
Blue
Normal
CWM: http://zantekk.de/mirror/phenomenal/...BlueNormal.zip
ODIN: http://zantekk.de/mirror/phenomenal/...BlueNormal.tar
Medium:
CWM: http://zantekk.de/mirror/phenomenal/...BlueMedium.zip
ODIN: http://zantekk.de/mirror/phenomenal/...BlueMedium.tar
Extreme:
CWM: http://zantekk.de/mirror/phenomenal/...lueExtreme.zip
ODIN: http://zantekk.de/mirror/phenomenal/...lueExtreme.tar
Black
Normal:
CWM: http://zantekk.de/mirror/phenomenal/...lackNormal.zip
ODIN: http://zantekk.de/mirror/phenomenal/...lackNormal.tar
Medium:
CWM: http://zantekk.de/mirror/phenomenal/...lackMedium.zip
Odin: http://zantekk.de/mirror/phenomenal/...lackMedium.tar
Extreme:
CWM: http://zantekk.de/mirror/phenomenal/...ackExtreme.zip
ODIN: http://zantekk.de/mirror/phenomenal/...ackExtreme.tar
Phenomenal 2.1
Thanks to Schindler33 for compiling these versions, because I've problems with my linux virtual machine
Blue versions are based on speedmod k-16
Black versions are based on speedmod k-18
Why black and blue? : www.inter.it
voltages for normal, medium, extreme versions alre the same of phenomenal 2.0
I add also "controller of superamoled plus screen" undervolting (for all versions from 3V to 2.5V)
for black version (based on speedmod k-18) i reverted loadH cpuhotplug to 60..you can use script published for phenomenal 2.0 if you want change
Blue stock frequencies
Normal
CWM: http://zantekk.de/mirror/phenomenal/...meno83-CWM.zip
ODIN: http://zantekk.de/mirror/phenomenal/...fenomeno83.tar
Medium:
Extreme:
Black stock frequencies
Normal:
Medium:
Odin: http://zantekk.de/mirror/phenomenal/...fenomeno83.tar
Extreme:
EDIT: REMOVED VERSIONS WITH FREQUENCY TABLE CHANGED, BECAUSE VERY UNSTABLE AND WITH A LOT OF BUGS!
if you want underclock to 1000mhz, use this script in init.d
http://dl.dropbox.com/u/724391/S80underclock.rar
phenomenal 2.0
Based on speedmod k-18
cpu hotplug: loadH = 80%
Loadh --> instructs the second core to kick-in only when the first core is above 80% threshold
LoadL value is not used
Normal/Stable version:
cpu arm voltages: 1200mhz = 1200mv (stock = 1250mv)
1000mhz = 1100mv (stock = 1150mv)
800mhz = 1000mv (stock = 1050mv)
500mhz = 925mv (stock = 975mv)
200mhz = 875mv (stock = 975mv)
cpu internal voltages: 1200mhz = 1050mv (stock = 1100mv)
1000mhz = 1050mv (stock = 1100mv)
800mhz = 1050mv (stock = 1100mv)
500mhz = 950mv (stock = 1000mv)
200mhz = 950mv (stock = 1000mv)
bus voltages: 400mhz = 1050mv (stock = 1100mv)
266mhz = 950mv (stock = 1000mv)
133mhz = 950mv (stock = 1000mv)
gpu voltages: 266mhz = 950mv (stock = 1000mv)
160mhz = 900mv (stock = 950mv)
Cwm: http://zantekk.de/mirror/phenomenal/...l-v2.0-CWM.zip
Odin: http://zantekk.de/mirror/phenomenal/Phenomenal-v2.0.tar
Medium version (settings from phenomenal 1.1)
cpu arm voltages: 1200mhz = 1175mv (stock = 1250mv)
1000mhz = 1075mv (stock = 1150mv)
800mhz = 975mv (stock = 1050mv)
500mhz = 900mv (stock = 975mv)
cpu internal voltages: 1200mhz = 1000mv (stock = 1100mv)
1000mhz = 1000mv (stock = 1100mv)
800mhz = 1000mv (stock = 1100mv)
500mhz = 900mv (stock = 1000mv)
200mhz = 900mv (stock = 1000mv)
bus voltages: 400mhz = 1000mv (stock = 1100mv)
266mhz = 900mv (stock = 1000mv)
133mhz = 900mv (stock = 1000mv)
160mhz = 875mv (stock = 950mv)
Cwm: http://zantekk.de/mirror/phenomenal/...Medium-CWM.zip
Odin: http://zantekk.de/mirror/phenomenal/...v2.0Medium.tar
Extreme version
cpu arm voltages: 1200mhz = 1150mv (stock = 1250mv)
1000mhz = 1050mv (stock = 1150mv)
800mhz = 950mv (stock = 1050mv)
500mhz = 875mv (stock = 975mv)
200mhz = 850mv (stock = 975mv)
gpu voltages: 266mhz = 900mv (stock = 1000mv)
160mhz = 850mv (stock = 950mv)
Cwm: http://zantekk.de/mirror/phenomenal/...xtreme-CWM.zip
Odin: http://zantekk.de/mirror/phenomenal/...2.0Extreme.tar
If you want choose own cpu hotplug values, edit this file and put in system/etc/init.d (LoadL value is not used)
http://zantekk.de/mirror/phenomenal/S71hotplug
Phenomenal 1.1 test (will became final when I'm sure that it is stable)
New mixed voltage values from Frankcilo(tested in several phones for several mounths). Battery should be good as 1.0 extreme, but stable as 1.0 normal version
cwm
http://www.zshare.net/download/969300864c27e419/
odin
http://www.zshare.net/download/969301567c4aa530/
Phenomenal 1.0.
Speedmod k-16 as base
CPU Undervolting (stock - 50mv on all frequencies, except for 200mhz, where is 875mv)
Internal Undervolting (stock - 50mv on all frequencies)
Bus undervolting (stock - 50mv on all frequencies)
GPU undervolting (stock - 50mv on all frequencies)
All undervolting are little for stability.
cwm version
http://www.zshare.net/download/960558054182290a/
mirror:
NOTICE
odin version
http://www.zshare.net/download/9605805347d03983/
mirror:
NOTICE
full source
http://www.zshare.net/download/9625790645c1ef85
PHENOMENAL 1.0 EXTREME EDITION (COULD BE NOT STABLE!)
CPU Undervolting (stock - 100mv on all frequencies, except for 200mhz, where is 850mv)
Internal Undervolting (stock - 100mv on all frequencies)
Bus undervolting (stock - 100mv on all frequencies)
GPU undervolting (stock - 100mv on all frequencies)
cwm:
http://www.zshare.net/download/9656521390cd0362/
odin:
http://www.zshare.net/download/9656529172f0bf1b/
Thanks to:
hardcore, for his fantastic kernel
gokhanmoral and angelom for great help
zantekk for ftp server
shahulvm for loadH optimal value
frankcilo for settings of the medium version
Schindler33 for compiling kernel phenomenal 2.1, because I'd problems with my linux virtual machine
Garysquib for create file of my script underclocking to 1000mhz
simone2001 for screen controller undervolting
if you don't like undervolting, use speedmod
http://forum.xda-developers.com/show....php?t=1182498
No Bln compatible(against battery), no bootamination(but in speedmod thread you can search a guide to have custon bootanimation), no overclocking(phone is already very fast). Setcpu compatible, but i suggest to don't install.
Goals: battery and performance
GUIDE FOR DUMMIES: HOW UNDERVOLT
http://forum.xda-developers.com/show...5&postcount=26
[KERNEL] Phenomenal [1.0] - xda-developers
Reaktionen: minimalbensn, Fn0rd, FotoMichi und 6 andere
Schon getestet?
Sent from my GT-I9100
runter geladen ja *g* aber geflasht noch nicht
Ist jetzt nicht so die Weltneuheit, aber einen Flashvorgang ist es Wert ;)
...dann wäre jetzt noch bln perfekt ;-)
Hallo alle zusammen,
ich habe den Kernel(V2.0 extreme) jetzt mal mit CrisKelo V32 getestet und bin gerade bei einer Akkulaufzeit von 51 Stunden!, Restladung noch immer 9%.
Einen solchen Wert habe ich mit noch keiner anderen ROM/Kernel Kombination erreicht.
Die Sache hat mich komplett überzeugt und läuft bis jetzt absolut stable.
In Kombination mit dem CheckRom ist der Kernel auch sehr gut und sparsam ( extreme version )
SGS II Tapatalk
Reaktionen: mystery007
Posting 1 Aktuell
Reaktionen: mystery007 und Kjetal
Kann man den mit Miui auch nutzen?
Nein, nur für Stock Roms
SGS II Tapatalk
Teste gerade den Kernel (Extreme Version).
Nach dem mein Akku voll geladen war, hab ich mich ein bissl mit dem Handy beschäftigt.
Knappe 2 Stunden Display on, davon die meiste Zeit via Tapatalk im Forum gelesen, mit dem Facebook App gestöbert - ca. 250 Bilder betrachtet, einige Youtube Videos geschaut und das resultat finde ich im Moment bombastisch.
Die Performance ist top, kann nichts negatives feststellen. Alles läuft sehr flüssig bei mir.
Ich habe den 2000er Akku drin. Nachfolgend die momentanen Resultate: :thumbup::thumbup::thumbup:
Die Screenshots sprechen für sich :scared:. Ich werde es weiter beobachten und entsprechendes Feedback dazu abgeben.
Auch hatte ich heute Nacht schonmal kurz nach dem Deep Sleep geschaut, welcher mit aktiven W-Lan/Hintergrunddaten bei ca. 96% lag.
Aber das war nur nach ca. 1 Stunde. Auch das werde ich mal weiter beobachten.
Bis dahin, viel spass mit dem Kernel ;)
EDIT: DS getestet mit aktivem W-Lan/Hintergrunddaten Gesamtlaufzeit über 3 Stunden 96% DS. Akkulaufzeit ca. 7 Stunden, davon 2h 10m Display on, W-Lan unentwegt aktiv 77% Akkuanzeige.
EDIT 1: Seht selbst, nach einer Gesamtlaufzeit von ca. 11 Stunden mit W-Lan/Hintergrunddaten und ca. 2h 40m Display on immer noch bei ca. 70%::thumbup:
Bis jetzt der absolute Akku Spitzenreiter für mich und das mit einer tadellosen Performance!
Edit 2: WOW, nach dem deakivieren des W-Lan/Hintergrunddaten über Nacht (ca. 11 Stunden) hat der Akku gerade mal 2% (von 69% auf 67%) in knapp 11 Stunden verbraten. Nach einer Weile lage die geschätze Stromaufnahme bei unglaublichen 4mAh (ca. die Hälfte vom DK oder Siyah), seht selbst:
Edit 3: Nach ca. 24 Stunden und Display on ca. 3h 15m liegt mein Akkustand immer noch bei 62% :scared:
Edit 4: Nach einer Akkulaufzeit von ca. 30 Stunden und Display on ca. 5h 5m liegt der Akkustand bei ca. 35%.:thumbup:
Das ist noch immer ein Top Wert. Ich war heute ca. 1 Stunde ausser Haus. In der Zeit war anstelle des W-Lan die Mobilefunkdaten aktiviert.
Die kann man im nachfolgenden Bild (W-Lan unterbrochen erkennen).
EDIT 5: PHENOMENAL es ist einfach unglaublich...
Nach 23:00 Uhr habe ich W-Lan/Hintergrunddaten bei einem Akkustand von ca. 29%
deaktiviert. 11 Stunden später schaue ich auf das Handy und sehe (PHENOMENAL) 29%.
Ich dachte mir das kann nicht sein...schnell ein paar Screenshots machen, das glaubt mir sonst keiner...
Der geschätze Verbrauch über Nacht hat sich nochmal halbiert. Es wird ein Wert von 2mAh
(PHENOMENAL) angezeigt. Diesen Wert sehe ich eigentlich nur von 100% auf 99%, wenn der Akku frisch geladen ist und die volle Kapazität hat.
Nach 5h 30m Display on und 1d 20h 30m sind noch immer ca. 29% Akku verfügbar
(PHENOMENAL).
Aber seht selbst: :scared::thumbup::scared::thumbup:
EDIT 6 - Fazit:
Mein Fazit mit dem ersten Ladezyklus von 100% auf 1% ist einfach Phenomenal.
Die Perfomance ist Top:thumbup:, Stabilität Top:thumbup:, Akkuleistung einfach Phenomenal:thumbsup:.
Nach über 48 Stunden Gesamtlaufzeit und einer Display on Zeit von über 7 Stunden bin ich fast sprachlos.
Da diese Werte ohne UC und einer top Leistung einher gehen, ist dies mein momentaner Spitzenreiter, was Kernels angeht.
Nachfolgend einige Screenshots. Bilder sagen mehr als 1000 Worte:
Reaktionen: ->TopAZ<-, Kaio, enrage und 3 andere
Bin momentan auch mal kurzfristig auf einem Stock Rom um die ganzen Kernel selbst zu testen, ich rede gerne nur über Dinge die ich selbst getestet habe und hatte den Kernel auch einen Tag drauf.
Nachdem ich jetzt die ganze Palette durch habe muss ich sagen
vor allem bei Benutzung hat dieser hier von allen getesteten definitv mit großem Abstand am wenigsten von allen verbraucht und dabei trotzdem eine sehr gute Performance, kein Ruckeln , kein lag, nichts trotz der Extreme Version.
SGS II Tapatalk
Absolut, stimme dir voll zu. Ich bin regelrecht überrascht, dass so eine Akkuleistung bei der Performance überhaupt möglich ist.
Auch der DS scheint mit dem Siyah gleich auf zu sein.
Ich bin sehr gespannt auf die restlichen knapp 70% des Akkus, mal schauen wie sich das weiter verhält. Auch ein Benchmark mit Antutu hat einen Wert von ca. 6.000 ergeben. Das ist mit dem Standard Siyah 2.6.1 vergleichbar.
Dieser Kernel hat zwar kein BLN, brauche ich aber auch nicht wirklich. Was bringt mir die Anzeige eines Anrufes in Abwesenheit, wenn der Akku nicht mehr für das zurückrufen ausreicht. Außerdem gibt es ja noch NoLED, ich muss nicht zwingend ein Icon auf dem Display anzeigen lassen. Besser finde ich die Möglichkeit der Soundwiedergabe in einem einstellbaren Intervall und dies ist eben auch mit NoLED möglich (wenn mans brauch).
Ich werde den Kernel jetzt noch einige Tage testen. Mal schauen wie er sich weiterhin schlägt.
Wer die Wahl hat hat die Quahl.
Werde ich aber auch mal antesten.
Sent from my S2
Die Akkulaufzeit ist wirklich Top bei meiner Extrem Nutzung 30 Stunden.
Hast Du die Extreme Version drauf?
Sent from my S2
Ja, und läuft wirklich super flüssig. 3h Display an ... da kann ich mit leben.
Und auch stabil?
Sent from my S2
Kann dem ganzen hier nur zustimmen!
Läuft mit der Extreme-Version schnell und eben extrem akkuschonend.
Dieser Kernel muss erst mal getoppt werden :thumbsup:
Hab ihn seit gestern am laufen, bisher der flüssigste Kernel mit niedrigstem Akkuverbrauch.
Habe die Omega V 9.2 mit dem Kernel am laufen.
Bisher sehr zufrieden, das einzige "manko" das man nicht auf 100 MHz runter kann (nicht unbedingt notwendig aber bisher irgendwie so angewöhnt) sonst echt Perfekt bisher ! dagegen kommt meiner meinung nach auch der Siyah nicht an (mit Siyah hatte ich egal mit welchen settings immer ein paar ruckler, und der Akkuverbrauch ist mir beim Siyah in letzter zeit auch ein bisschen zu sehr gestiegen) mal gucken wie sich das ganze hier weiterentwickelt =)
beicuxhaven
HCD
HCD
Gregor901
Bernd82
Bernd82
Z
Zoomson
Zoomson
