[Sammy-KERNEL][JellyBean] *19.04.13* SpeedMod SGS2 [K5-8] für 4.1.2-ROMs
  • 375 Antworten
pro.aggro
pro.aggro
Ikone
3.414
SpeedMod für ICS ist da!!
Für JellyBean siehe Post 2
Hi guys,
This is the SpeedMod kernel for Android ICS for the Samsung Galaxy S2 GT-I9100.
This kernel only works with Samsung ICS based ROMs.
SpeedMod's core features are:
- Super stable: No undervolting, overclocking or potentially unstable modifications
- Fast and smooth: Compiler and code optimizations
- Excellent battery life: Remove unecessary logging and debugging
>>> CLICK HERE for more info and the DOWNLOAD links.
>>> CLICK HERE for the Frequently Asked Questions list.
This is an early release with basic functionality only. No CWM yet.
Current features:
Root:
- Automatically installs root (su)
Screen and misc tweaks:
- init.d, TUN, CIFS, IPV6 Privacy support
Performance:
- CPU governor tweaks: increase responsiveness
- IO tweaks
- Read ahead tweaks
- Compiled with optimizations using Linaro GCC toolchain
- Switched to SLAB instead of SLUB
Turned off unnecessary logging for better smoothness and efficiency:
- Disabled Android Debug Logger / logcat
- Disabled Samsung debug
- Disabled various kernel debugging, statistics and tracing options
Changelog
K3-31:
- Rebuilt using Codesourcery 2012.03 GCC 4.6.3 toolchain
- Minor tweaks to ondemand governor
- Minor tweaks to GPU DVFS driver
K3-30:
- Minor compiler flag changes
- Camera driver fixed for 4.0.4 ROMs
K3-28:
- Rebuilt on new GT-I9100_ICS_Opensource_Update7 source code
- Should be compatible with 4.0.4 ROMs
K3-26:
- Rebuilt on new GT-I9100_ICS_Opensource_Update6 source code
- sched_mc_power_savings set to 0 by default
K3-25:
- Changed to Linaro GCC 4.4 compiler for better stability
- Better MDNIE display settings to eliminate over-sharpening
K3-24:
- Rebuilt on newer source code GT-I9100_HK_IC_Opensource_Update1
- Hide boot partitions (TriangleAway 1.51+ still works)
- Changed some compiler settings to fix boot hangs
K3-21: - Updated mach-exynos cpufreq code from GT-N7000 sources - Updated root: Superuser.apk and su binary to latest versions
K3-20:
- Delayed min_free_kbytes adjustment a bit to prevent hanging at boot
- Enabled utf-8 support for CIFS
K3-19:
- Patched Wifi driver with "bcmdhd: Fix FW hang recovery"
K3-18:
- Slight change to min_free_kbytes to fix the problem of sometimes hanging at boot
K3-17:
- Reverted some compiler flags to fix the problem of sometimes hanging at boot logo
K3-16:
- Tweaks to touchscreen sensitivity
- Compiler flags updated
- min_free_kbytes increased to fix wifi toggling problem
K3-15:
- Tweaks to touchscreen sensitivity:
- - Movfilter for battery set to GB kernel values
K3-7:
- Minor update to IO tweaks
- MDNIE tuning for more natural color and sharpness
- GPU DVFS adjustments
K3-5:
- Minor update to IO read_ahead tweaks
K3-3:
- ARM CPU topology patch from Linaro
- SCHED_MC multi-core aware scheduler patch from Linaro
- Changed to DVFS based CPU hotplug policy
K3-2:
- Added CWM5
- Increased USB charging speed to same speed as AC charge
- max17042: Fix fuel alert wakelocks
- Touchscreen MOVHYST ("Vitalij fix") set to 10
K3-1:
- Initial release
Original XDA Thread
  • speedmod-kernel-s2-ics-k3-1-CWM.zip
  • speedmod-kernel-s2-ics-k3-2-CWM.zip
  • speedmod-kernel-s2-ics-k3-3-CWM.zip
  • speedmod-kernel-s2-ics-k3-5-CWM.zip
  • speedmod-kernel-s2-ics-k3-7-CWM.zip
  • speedmod-kernel-s2-ics-k3-9-CWM.zip
  • speedmod-kernel-s2-ics-k3-15-CWM.zip
  • speedmod-kernel-s2-ics-k3-16-CWM.zip
  • speedmod-kernel-s2-ics-k3-17-CWM.zip
  • speedmod-kernel-s2-ics-k3-18-CWM.zip
  • speedmod-kernel-s2-ics-k3-19-CWM.zip
  • speedmod-kernel-s2-ics-k3-20-CWM.zip
  • speedmod-kernel-s2-ics-k3-21-CWM.zip
  • speedmod-kernel-s2-ics-k3-24-CWM.zip
  • speedmod-kernel-s2-ics-k3-25-CWM.zip
  • speedmod-kernel-s2-ics-k3-31-CWM.zip
Reaktionen: increpidix, Condition, Fn0rd und 12 andere
Platzhalter2
So,ich habe nun mal den SpeedMod Kernel auf meine Omega Stock v.7+ICS Domniation 4.1 Theme geflasht. Bin mal gespannt wie sich dieser Kernel so verhält.
Es gibt übrigens schon die K3-2 Version!
Reaktionen: Simuur95
Gibts schon erstes zu berichten? Läuft flüssiger als CF-Root XXLP7, ruckelt oder gibt es dinge die nicht funktionieren etc ? :)
Ist die V2 noch immer ohne CWM?
Hat CWM!
K3-2 angehangen
k3-3 auch schon draußen .. Der haut aber Updates raus :D
Danke für die Info. Schade das er nur mit Sammy Roms funzt.:unsure:
kann man die bootanimation bei dem K3-2 Kernel nicht ändern?
Hab es gerade versucht aber nicht hinbekommen.
Hi habe ihn auch grad geflasht denke mal das er noch keine Custom Bootanimation unterstützt kommt bestimmt noch :)
Der Speedmod unterstützt keine alternativen Bootanimationen...
naja egal, ich mach mir jetzt mal die K3-3 drauf...
K3-5 hinzugefügt!
Die K3-9 läuft wunderbar mit der LPS. Kein Ruckler, keine Ausfälle, nichts.
Hab den k3-9 auch mal drauf, bin gespannt. Die sich täglich wechselnden siyah waren schon unter GB zeiten nicht meins.
Ja, die K3-9 läuft außerordentlich gut.
Momentan sind ja die "Mode"-Kernel wie siyah oder neak sehr im Rennen, und SpeedMod wird etwas unbeachtet gelassen, weil da nicht so viel Geschrei drumherum ist.
Ich meine, ihr solltet Euch den mal draufziehen. Ich bin sehr erstaunt über die "Laufeigenschaften" dieses Kernels und überzeugt, ihr werdet ebenfalls positiv überrascht sein.
Hier die Downloadseite:
Tourist In Paradise: Samsung Galaxy S2 ICS: Download SpeedMod kernel
