[Sammy-KERNEL] [Jelly Bean] *22.04.13* Phenomenal - [hiroX 5.8]
  • 357 Antworten
Gregor901
Gregor901
Enthusiast
2.024
Der Phenomenal-Kernel wird inzwischen von GEROXX gepflegt.
Quelle: xda-developers
bzw. hier: [Kernel] Phenomenal 6.1 ICS - Back to the future - Page 104 - xda-developers
Die Hirox-Versionen gibt es hier zum downloaden:
hiroX 5.8: (for 4.1.2)
Light:
CWM: Dev-Host - hiroX_5.8_Light.zip - The Ultimate Free File Hosting / File Sharing Service
ODIN: Dev-Host - hiroX_5.8_Light.tar - The Ultimate Free File Hosting / File Sharing Service
CWM: Dev-Host - hiroX_5.8_Light_CWM6.zip - The Ultimate Free File Hosting / File Sharing Service (with CWM6-Recovery)
ODIN: Dev-Host - hiroX_5.8_Light_CWM6.tar - The Ultimate Free File Hosting / File Sharing Service (with CWM6-Recovery)
Medium:
CWM: Dev-Host - hiroX_5.8_Medium.zip - The Ultimate Free File Hosting / File Sharing Service
ODIN: Dev-Host - hiroX_5.8_Medium.tar - The Ultimate Free File Hosting / File Sharing Service
CWM: Dev-Host - hiroX_5.8_Medium_CWM6.zip - The Ultimate Free File Hosting / File Sharing Service (with CWM6-Recovery)
ODIN: Dev-Host - hiroX_5.8_Medium_CWM6.tar - The Ultimate Free File Hosting / File Sharing Service (with CWM6-Recovery)
Intensive:
CWM: Dev-Host - hiroX_5.8_Intensive.zip - The Ultimate Free File Hosting / File Sharing Service
ODIN: Dev-Host - hiroX_5.8_Intensive.tar - The Ultimate Free File Hosting / File Sharing Service
CWM: http://d-h.st/mcu (with CWM6-Recovery)
ODIN: Dev-Host - hiroX_5.8_Intensive_CWM6.tar - The Ultimate Free File Hosting / File Sharing Service (with CWM6-Recovery)
Extreme:
CWM: Dev-Host - hiroX_5.8_Extreme.zip - The Ultimate Free File Hosting / File Sharing Service
ODIN: Dev-Host - hiroX_5.8_Extreme.tar - The Ultimate Free File Hosting / File Sharing Service
CWM: Dev-Host - hiroX_5.8_Extreme_CWM6.zip - The Ultimate Free File Hosting / File Sharing Service (with CWM6-Recovery)
ODIN: Dev-Host - hiroX_5.8_Extreme_CWM6.tar - The Ultimate Free File Hosting / File Sharing Service (with CWM6-Recovery)
Erklärung zu Intensive:
CPU & GPU-Values sind identisch mit "Medium"
Screen/Memory-Voltages sind identisch mit "Extreme"
Changelog:
http://touristinparadise.blogspot.co...od-kernel.html
CWM6-Recovery:
- Updated to newest version 6.0.3.1
- Added /preload backup & restore support
- swapped sdcards in recovery
Vorangegangene Versionen:
http://forum.xda-developers.com/show...postcount=1031
Reaktionen: AndroidLover666, adl, netguru und 24 andere
Wen es interessiert, welche CPU-Voltwerte in den jeweiligen Versionen eingestellt sind, kann es hier nachlesen:
Normal:
CPU voltages: 1200mhz = 1200mv (stock is 1275)
1000mhz = 1125mv (stock is 1175)
800mhz = 1025mv (stock is 1075)
500mhz = 950mv (stock is 975)
200mhz = 900mv (stock is 950)
Internal voltages: -50mv respect stock for all frequencies
Bus voltages: 266mhz = 950mv (stock is 1000)
133mhz = 900mv (stock is 950)
GPU voltages: 266mhz = 950mv (stock is 1000mv)
160mhz = 900mv (stock is 950mv)
Medium:
CPU voltages: 1200mhz = 11750mv (stock is 1275)
1000mhz = 1075mv (stock is 1175)
800mhz = 975mv (stock is 1075)
200mhz = 875mv (stock is 950)
Bus voltages: 266mhz = 900mv (stock is 1000)
133mhz = 850mv (stock is 950)
Extreme:
CPU voltages: 1200mhz = 1150mv (stock is 1275)
1000mhz = 1050mv (stock is 1175)
800mhz = 950mv (stock is 1075)
500mhz = 925mv (stock is 975)
200mhz = 850mv (stock is 950)
GPU voltages: 266mhz = 900mv (stock is 1000mv)
160mhz = 850mv (stock is 950mv)
Screen controller voltages = - 300mv in comparison to stock
Memory voltages = -100 mv in comparison to stock
Reaktionen: AndroidLover666, Cheyenne, pyro75 und 2 andere
Ich hätte euch jetzt gerne geschrieben, dass ich den phenomenal erfolgreich geflasht habe und alles bestens ist, allerdings bin ich vorhin nicht dazu gekommen, da ich 3 freezes hatte und nicht bis zum tapatalk app gekommen bin... also zurück zum neak... ach und ja, ich habe ukcs benutzt.
Gesendet mit dem Senden Button
Aufgrund dieser Meldung habe ich mir sofort diesen Kernel aufgezogen, was ich erst für morgen auf der Agenda hatte.
Ergebnis: o.k.! Keinerlei Probleme, Bugs oder Freezes.
Geflasht als "tar" mit MobileOdin ohne UKCS
TestRoms: Omega 9.0, Turkbey 5.0, Thebyani 3.9
Sehr gut dass diesen Kernel nun auch für ICS gibt. Werde ihn demnächst mal testen.
Läuft super, geht bei mir leider nur nicht in den deepsleep.
Neustart hat das Problem behoben.
Ob der Kernel auch wieder so Akkusparsam wie in GB Zeiten war bzw ist!?:smile:
Bis jetzt würde ich sagen ist er sehr sparsam. Besser als abyss, siyah und neak. Und er ist auch super smooth und sehr schnell. Kann ihn bedingungslos empfehlen.
Reaktionen: Sanane und Hsv-Tobi
Ich bin auch schon zu GB Zeiten mit dem Pheno bestens zufrieden gewesen!Hoffen wir das es unter ICS auch so sein wird....und nun druff mit dem Ding :D
Nur für SammyRom? Oder auch für Aosp Aokp?
War bei Gb-Zeiten auch immer mit Phenomenal unterwegs....
Ich habe den Kernel auch drauf. Läuft auch alles super. Eigentlich wollte ich damit aber Root-Rechte erlangen, dies ist nicht der Fall. Was muss ich da noch machen:confused2:
Also bei mir auf der Aktuellsten CM9 Nightly läuft der nicht ich bekomme nur einen Blackscreen
Ist nur für SammyRoms, da es auf Speedmod basiert.
Reaktionen: Darkpassion
Vielleicht wäre das eine Anregung es in den Opener und in den Titel aufzunehmen... ;)
Reaktionen: Gregor901
Ich habe den Kernel seit gestern drauf, habe den Akku bis jetzt einmal vollgeladen, der Kernel ist einfach nur der hammer seht selbst :
Reaktionen: masteru und privat75
Das schaut ja gut aus, werde dann auch mal testen.
Sent from my GT-I9100 using Tapatalk 2
Unterstütz der Kernel auch BLN?
Aktuell:
Dual Rom's
[--VK--™]-[-XWLP8-V4.6.1]
TurkbeyRom V5
Siyah RC5 (Battery)
Probiere ihn einfach mal, ich bin bisher mit keinem anderen Kernel auf so eine lange Displayzeit gekommen.
Da es auf Speedmod basiert, glaube ich nicht.
@Hsv-Tobi
Kernel ist schon drauf, schauen wir mal in den nächsten Tagen wies läuft.
PS: Rechtschreibfehler in deiner Signatur, schau mal ob du es findest. :)
Aktuell:
Dual Rom's
TurkbeyRom V5
Siyah RC5 (Battery)
Kann mir einer sagen was Sammy Rom bedeutet?????? :confused2:
Danke,
Gruß....
