[Sammy-Kernel][Jelly Bean] *18.01.15* Apolo JB 4.15b [Apolo Configurator]
  • 515 Antworten
Z
Zytrel
Apolo JB Kernel (Speedmod Basis) für Samsung Jelly Bean ROMs
*Kernel ist sicher - No Brick Bug*
*BLN / BLNWW Support*
*Slide 2 Wake Support*
*Alles per Apolo Configurator App einstellbar*
Download:
Kernel Download
Configurator (Google Play Store)
Changelog:
Apolo 4.15b
Removed vibration interface compared with 4.15)
- Governor zzmoove updated to 1.0 beta 4
- Speedup keyresume (faster wake up)
- Governor Neox has come back (not included in beta
- FPBug fix by @zeitferne & @Lanchon)
Apolo 4.14
- New zzmoove 0.8 (thx ZaneZam Link)
Apolo 4.13
- Wifi drivers updated to 1.61.58
- Updated row scheduler
- Added bfq scheduler
- Removed MDNIE Sharpness by Hardcore (no mor problems with mdnie scenarios)
- Initramfs improved
Apolo 4.12
- Reverted the stupid android_secure change I did in last kernel
- Added new governor Neox
- Added MyFluxi sound interface (to control it you'll need to use the new Apolo configurator 5.0)
- Fixed mdnie in the camera with mdnie sharpness disabled
Apolo 4.11
- zzmoove updated to 0.7d
- Backup and restore Android_secure fixed
Apolo 4.10 (Final version)
- Added brightness curve interface (credits to gokhanmoral) It will be necessary to use new Apolo Configurator 4.0 to configure the brightness curve (available in Google Play).
- Exfat support in kernel and recoverys (CWM and TWRP)
- TWRP recovery updated to 2.6.1 (thx to the TWRP team)
- zzmoove updated to version 0.7c.(thx ZaneZam)
- su and supersu updated (thx chainfire)
- Added a new tab to configure the brightnes curve.
- Version of Apolo kernel is showed in the Menu.
- Now you can configure up to 40 parameters of the gobernor
- Spanish leftovers remove
- Bugs fixed
Apolo 4.9
- Slightly change in brightness levels (automatic brightness higher than 4.8)
- Wifi drivers updated (latest S4) thx dorimanx
- Pegasusq , sampling time set to 50000, instead 100000 (improvement listening music with bluetooth)
- Try to solve issue of charging animation with phone off (will see if it works)
- zzmoove updated to 0.6 and tweaked thx ZaneZam
- sio scheduler updated
- su, supersu updated
- Revert USB charging values to 450 mA by default (safety measure). Added charging interface, so in the next release of Apolo configurator you will be able to change it.
Apolo 4.8
- Bilingual CWM recovery(Spanish-English). Default: English (you can change language in Extras Apolo)
- Fixed toggle ctr-off in CWM recovery
- Default backup format set to tar in CWM
- Updated TWRP recovery to version 2.5 (Thx Jeboo for sources). Added Preload support.
- Two new minimum brightness levels in manual mode (lower than stock)
- Fixed init.d. Now kernel considers all scripts in /system/etc/init.d
- Fixed BLN test in Configurator
- Current for USB charging to 650 mA (same as wall charger) Thanks to Zytrel, I forgot to mention it
CWM version is 4.8b (4.8 had little bugs)
Fixed:
- "Volver" text in English is gone
- EFS backup and restore (I hope so)
- BLN test
Apolo JB 4.7
- New Wifi Drivers from S4 (Thx dorimanx and codeworks)
- Added I/O Scheduler row (Thx Jeboo)
Apolo JB 4.6
- Revert Linaro toolchain compiler to GCC 4.6.3
- New governor interactivex (thx dorimanx)
- New governor zzmoove tweaked by pedestre (I recommend this governor, it's great)
- Fixed bug flashing from recovery updates with Assert instruction (for instance modem zips)
- Updated su and supersu
- Fix Touchscreen Choppy using MXT224E chip(thx kgp700)
- New Apolo Configurator 3.2 (useful for activating and scheduling BLN and BLNWW, selecting governors and schedulers and much more ...). You can find it free in Google Play
Apolo JB 4.5
- New interface with BLNWW, leds timeout and brightness and Slide to Wake (All the credits for gokhanmoral)
- New governor Intellidemand (thx dorimanx)
- New Apolo Configurator 3.0 (useful for activating BLN and BLNWW and much more ...). You can find it in Google Play free
Apolo JB 4.4
- New Linaro compiler 4.73
- LTO (Link Time Optimization) for ARM enabled (compiled should be faster and smaller)
- CrossBreeder support. I’ve added in kernel an additional entropy generator (frandom). This module is used by CrossBreeder instead the default one (it should be faster). You need to install CrossBreeder mod in recovery to take advantage of it. There is a thread in xda about this mod : here. It improves the performance (specially lag)
- Security fix by Hardcore (UNAME26)
- Remove some extra debugging
Undervolting:
5 Versionen mit unterschiedlichem UV:
- Light (Stock voltages)
- Regular (-50mV)
- Extreme (3 Versionen)
Regular und Extreme haben -50mv GPU Undervolting
(Bus, Memory und Video Controller ebenfalls)
Die Light Version hat Stock GPU Spannungen.
Es wird zuerst die Regular Version empfolen!!
Wenn in 2 Tagen Nutzung keine Probleme auftreten (Reboots, SoD etc.) kann die Extreme V0 ausprobiert werden.
Ausführliche Information zu den Spannungen:
Für jede Frequenz gibt es 8 verschiedene Spannungen (Steps). In ICS hat das System immer den 4. Step gewählt.
Seit JB wählt das System in Abhängigkeit der internen und ARM Spannungen zwischen verschiedenen Steps, die im Kernel definiert sind, und versucht dabei die optimalen Steps zu wählen, bei denen das System stabil bleibt.
Es ist daher also nicht verwunderlich, das der Configurator bei der gleichen Kernelversion, jedoch verschiedenen Geräten, unterschiedliche Spannungswerte anzeigt.
Spannungstabelle (Spanisch)
Code:
This kernel is mainly based in hardcore work (thank you to Hardcore  for his great contributions). I have added undervolting (kind of phenomenal) and some additional features.
- TWRP recovery (thanks to Jeboo). If you understand Spanish I recommend the CWM versión (this a personal touch CWM recovery)
- No logs, no extra debugging
- install su, supersu. Support init.d and cifs (scripts in init.d must be named starting with an S)
- MDNIE Sharpness by Hardcore
- Ondemand Tweaked by Hardcore
- Added some governors (specially tweaked slp and zzmoove)
- Scheduler changing enabled
- BLN enable (Since Apolo 4.5 BLNWW too)
- CRT-OFF enable
- Effective Underclock (max frequency limited)
- UV Interface for ARM (you can change voltages in ARM with external aplications)
- Kernel Includes frandom for using with CrossBreeder (I really recomend it, Thx idcrisis)
- No Overclock and no different CPU-GPU steps from stock
*Es wird keine Haftung für eventuelle Schäden übernommen, flashen auf eigene Gefahr!*
Quellen:
Original Thread @XDA Developers
Thread ürsprünglich erstellt von Dare. Schönen Dank an dieser Stelle.
Reaktionen: j1gga84, da_Mike, craP_cillA und 23 andere
Hab ihn schon über eine Woche drauf V2+Balaced Profil läuft flüssig und bessere Akkulaufzeit hatte ich unter JB noch nicht außerdem hatte ich noch nie einen Reboot.
Edit: Bln Support hat er auch das fehlt im Changelog.
Reaktionen: Manu-1, steuerboy, Dare und eine weitere Person
Bekomm ich da auch irgendwie CWM dazu?
Gesendet von meinem GT-I9100
Danke, ist korrigiert.
Kann das auch nur bestätigen, habe das "balanced" Profil aktiv, jedoch mit Coservative/Noop Einstellung.
Die Extreme v2 läuft bei mir ebenfalls stabil, Laufzeiten sind traumhaft im Vergleich zu anderen Kernel die BLN unterstützen!
Stock Niveau wird trotzdem übertroffen!
Tapatalked
Den Kernel gibt es mit Cwm aber dort ist alles auf spanisch.
Es gibt ihn auch mit TWRP auf englisch ;)
Kann man mit dem Tool nun die Spannungen einstellen? Bisher hat jedes Tool die Spannungen falsch eingrstellt, wenn ich sie auf hiroX extreme-Niveau senken wollte und das Handy hat sich abgestellt:crying:
Ansonsten wie im Phenomenal/ hiroX-Thread gesagt: sau guter Kernel, wenn der Kernel BLNWW könnte und das Tool alles einstellen könnte (wie STweaks), wäre es der perfekte Kernel:love:
Reaktionen: Dare
Die Spannungen lassen sich über die Apolo App leider nicht einstellen!
Geprüft hab ich es mit SetCPU, da werden die Spannung korrekt übernommen!
Alle anderen Einstellungen funktionieren und werden übernommen!
Tapatalked
Reaktionen: Manu-1
Habt ihr in der TWRP auch die beiden Meldungen: E: Unable to find partition for path '/and und E:UnMound: Unable to fin partition fpr path '/a ? die beiden Sachen stehen wenn ich unten in der mitte auf den "Deatails" Button drücke.
Nach einem 2ten Reboot in die TWRP scheint es weg zu sein, aber wo finde ich jeden die Apolo Einstellungen in der TWRP ?
EDIT: Ich hab keinen Freeze wenn ich die Spannungen mit der App verstelle.
@EdleRatte die Einstellungen zum Kernel findest du im Konfigurator der oben im Thread verlinkt ist nicht in der Recovery.
Im Startpost bitte folgendes korrigieren. Die Regular Version läuft mit -50mV Spannung und die Light Version mit Stock Spannung.
Reaktionen: beicuxhaven und Dare
Danke, hab ich ganz übersehen, wird korrigiert! ;)
Ich muss sagen ich bin begeistert.
Ich glaube ich hatte noch nie so dermaßen gute Akkulaufzeit.
Im "Apolo Configurator" habe ich bei Frequency auf "Saving Mode" + auf Max. Freq. 1000.
Bei Voltages Profil Extreme V2/V1. Im Tool scheint es wurden die Voltages übernommen, Dh. nach neu öffnen der App immer noch vorhanden.
Bissher kein Freeze & total flüssig
1Tag 3Stunden Standby, davon 1Stunde 30Min Bildschirm an. Jetzt 52% Restakku...
I love it!
Reaktionen: Manu-1
Scheinbar seit gestern ist der 4.4 online:thumbup:
Changelog
Hat mal wer dieses CrossBreeder ausprobiert?
Habe jetzt den apolo v4.4 regular draufgemacht.
Beim umstellen in der Apolo app gleich nen Freeze kassiert.
Werde die App erstmal ignorieren und governor und scheduler mit voltage Control einstellen. Spannungen lasse ich unangetastet.
So, avast kann die Firewall nicht einschalten :
Es kommt diese Fehlermeldung
SuperSU Berechtigungen habe ich schon neu gemacht, keine Besserung.
Die Spannungen lassen sich bei mir immer noch nicht richtig einstellen, CrossBreeder habe ich gleich mit geflasht und konnte bisher nichts verdächtiges feststellen.
@mahd: Wie hast du geflasht und hast du alle alte Skripte bezüglich Spannungen gelöscht? Deswegen hatte ich auch riesige Probleme mit meinem System, sogar Juice Defender hat dadurch Probleme gemacht.
Komme von philZ. Daher war mein System sauber. Denke ich.
Komme auch mit Tapatalk nicht auf xda, hier geht's aber...
Vllt liegt es ja am avast update. Kann das vllt mal wer testen. Firewall geht nicht.
Hey, hat jemand von euch die Crossbreeder.zip geflashed ? Was bringt die Datei und hat man dadurch irgendwelche vorteile ?
EDIT: Habe gerade den Post von schgeedaa gelesen :D
Ich habe einen riesen Fehler gemacht. Ich haben den 4.4 mit CrossBreeder Skript yusammen installiert und heute bekomme ich Probleme mit derAkkuanzeige (riesiger drop von 40% auf 13%) und freezes en masse. Allein CrossBreeder zudeinstallieren hat nicht geholfen und daher bin ich zurück auf den 4.3 und werde vermutlich morgen ein Backup einspielen und nochmal in Ruhe testen.
@EdleRatte: bei xda gibt es einen Thread zu. Im Grunde soll das Skript alle möglichen Flaschenhälse bereinigen/umgehen, die das Ansprechverhalten des Systems verschlechtern. Hört sich interessant an, ist aber nicht so ganz ausgereift (laut Thread) und wenn dein Szstem eh läuft, brauchst du das auch ich nicht. Ich wollte es nur mal testen/ werde es nochmal testen, aber mein S2 mit Alliance Rom läuft schon gut genug und ich denke nicht, dass es groß etwas bringen wird.
Hab mal die Seeder App installiert die macht wohl so in etwa das selbe, muss wenigstens nicht geflashed werden :D Dein Problem ist gar nicht so tragisch, liegt wahrscheinlich daran das es zu stark Undervolted ist. Einfach mal andere werte Testen zum Beispiel:
1200 = 1175
1000 = 1100
800 = 1000
500 = 950
200 = 925
Hab übrigens den Extreme v2 4.4 und hab mit den Werten 0 Probleme :D
GT-I9100 GoA 6.4
