Gast5050
Gast
My new kernel!
Will come in two flavours:
- U1 - based on Samsung Update1
- U2 - based on Samsung Update2 - not released yet.
Features:
- support for SetCPU OC (upto 1400MHz)
- UV between 800mV and 1400mV
- support for Boot Animation
- support for BLN
The goal of my first kernel was to take the battery savings gained from HardCORE's kernel and allow undervolting and underclocking to further improve battery life. I added Boot Animation and BLN support just because I could. This kernel adds to my previous kernels, taking bits and pieces from here and there also.
As usual, this kernel could break your hardware, so only flash if you are not concerned with bricking your device.
Thanks also to the authors of Ninphetamine kernel - their SetCPU supporting code was the basis for the SetCPU support in this kernel, I have also used BLN code from their Git Repository, thanks to creams.
Change Log:
- U1 - v1.1 - based on Samsung Update 1
- New compiler optimisations - partially from SpeedMod, partially my own.
Future plans:
- Auto Root-ing
NOTE FOR ALL:
Patch files are for developers, not end users.
Quelle:
http://forum.xda-developers.com/showthread.php?t=1252301
Gibt es noch was zu beachten?
