[kernel][miui] enigma
  • 6 Antworten
pinpong
pinpong
Kernel Source https://github.com/pinpong
Hello all. This is a extremely stable kernel for the international Samsung i9100.
*Custom CWM with touch
*Based on Samsung Opensource Update-3 + Linux Kernel 2.6.35.14 patches
*Touchscreen fix
*Increased touchscreen sensitivity
*Bootanimation support
*MDNIE screen sharpness tuning
*MDNIE color tuning
*init.d support
*BLN V2 auto install
*GPU/CPU overclocking support
*Root auto install
*Voodoo louder App support
*I/O schedulers: noop, V(R), deadline, CFQ, BFQV3r1, SIO(by default)
*21 different CPU Governor's
*CFLAGS optimisations
*GPU UI Rendering
*Lower brightness at low-light levels
*Read ahead tweaks
*Updated to jhash3
*Some patches for speed, performace and battery life
*Full compatible with Voltage Control
>>XDA VOLTAGE CONTROL LITE APP THREAD<<
>>SUPPORT XAN AND BUY THIS EXTREM VERSION<<
*********************CHANGELOG*********************
1.37
*modified initramfs scripts
*update toolchain
*full compatible with voltage control
*cpu overclock up to 1,6Ghz
*gpu overclocking support
*update cleanup script
*add some cpu governers
*cleanup my source
*new script for optimal performance
*remove unused modules
*********************CHANGELOG******************** *
1.39
*fix music play issue if the phone is locked
*small fixes
*supercurio *codeworx *existz *Smasher816 *neldar *Napstar
*pikachu01 *madrooster *hardcore *simone201
*gokhanmoral *cattleprod *creams *arighi
*vitalij *and all i forgot
BIG THANKS TO
*stratosk *saturn_de *mialwe *zacharias.maladroit
FOR ANSWER ALL MY STUPID QUESTIONS​
ENIGMA-1.39-CWR.zip
Reaktionen: Simuur95
Hört sich gut an .. kanns leider momentan nicht testen ( kein Aosp derzeit ) ..
Aber werde ich ! :D
Also nur für AOSP Rom's (Miui), richtig?
Edit: Ok, bin aufgeklärt^^
In der Überschrift steht Miui , demnach sollte man den begriff AOSP hier nicht verallgemeinern, ob er unter anderen Aosp RoMs problemlos läuft ist nicht zu entnehmen.
SGS II Cyanogen Mod 9 Tapatalk
Ein Bekannter hatte ihn mit einer Stock Rom getestet. Problem war halt das er per Wifi keine ip zugewießen bekommen hat.
Wenn ich mal lust zu habe werde ich mal in den Sourcen von dem Siyahs Kernel schauen, einen diff machen und es auch mit anderen Roms kompatibel machen. CM7 sollte auch nur mit Problemen gehen
update+++++++
Hat noch niemand Erfahrung mit diesem Kernel gemacht? Wie ist den der Akkuverbrauch und die Performance von diesem Kernel wäre froh über einen Bericht darüber
