[KERNEL] Jeffrey-SpeedFrey 3.0.0 Amazing battery life(!) & more (Update 21/08)
  • 137 Antworten
Gast5050
Gast
Hello guys,
It's my kernel for the SGS II.
I am very surprised with the battery life.
With my own experience (with Batista ROM, the best for me): The battery is still 100% after 8 hours sleep (wifi ON, data ON)
The kernel works very great. Stable, fast, no reboot or freeze. Tested with some roms. Stress test successfully done without reboot or freeze.
The kernel has these frequencies: 1204 / 1150 / 1100 / 1000 / 800 / 500 / 200 mhz. Compatible with SetCPU (auto detect).
IMPORTANT
For versions 2.2.0 and lower : there are 3 versions. Release Version, Workaround Version and Stock Voltage Version.
For versions 3.0.0 and higher : there are 2 versions. Release Version and Workaround Version.
Try only Workaround Version or Stock Voltage Version if you have issues with Release Version.
You can install this kernel with Odin (in PDA) or CWM Zip installer (since 2.1.0).
AFTER the kernel has been flashed please calibrate your battery.
My goal: Battery life and Optimization.
More optimizations and options in the future. Kernel continuously updated.
<b>
Jeffrey-SpeedFrey_Kernel 3.0.0​
</b>​
This kernel is optimized and uses low ram. The boot is very fast and everything is very smooth and fast.
Impressive battery life while using your mobile phone.​
FEATURES (for more details, look changelog) :
  • Undervolted (CPU and GPU) (not compatible with the SETCPU control voltage because the kernel is optimized with my own values)
  • Workaround version available (less undervolted)
  • Stock voltage version available
  • SetCPU compatible (1204/1150/1100/1000/800/500/200 mhz)
  • BFQ-V2 Scheduler added and set by default
  • 838 MB ram memory available
  • CIFS support (cifs.ko and slow-work.ko automatically integrated in "/lib/modules")
  • BLN support
  • Vitalij's touchscreen fix (value : 10)
  • Rooted
  • CWM 4.0.1.4
  • Interactive governor
  • Disable some debugging options / look changelog (better battery life, better ram usage and smoothness)
  • Some tweaks / look changelog (better battery life, better ram usage and smoothness)
  • Initd.d support
  • I/O scheduler tweaks
  • Low ram usage
  • Optimized for battery life
Changelog 3.0.0 :
    1128603088.00png
  • Increased smoothness with ram optimization
  • Increased battery life when the phone is on sleep with cpufreq.c optimization
  • Disabled Config_bugverbose (more memory, better smoothness and better battery life)
  • Disabled Bug() (optimize memory usage, better smoothness and better battery life)
  • Unnecessary developer options disabled (optimize memory usage)
  • General optimization for battery life
  • Thanks to all beta testers
At the bottom of the page screenshots of stability test.
Odin :
Download (Release 3.0.0) / better battery life : Download
Download (Workaround 3.0.0) : Download
CWM Zip installer :
Download (Release 3.0.0) / better battery life : Download CWM zip installer
Download (Workaround 3.0.0) : Download CWM zip installer
Changelog 2.2.0 :
  • BLN support
Odin :
Download (Release 2.2.0) / better battery life : Download
Download (Workaround 2.2.0) : Download
Download (Stock Voltage 2.2.0) : Download
CWM Zip installer :
Download (Release 2.2.0) / better battery life : Download CWM zip installer
Download (Workaround 2.2.0) : Download CWM zip installer
Download (Stock Voltage 2.2.0) : Download CWM zip installer
Changelog 2.1.0 :
  • CIFS support
  • Init.d support
  • Low ram usage (optimized)
  • Increased battery life with kernel optimization
  • Increased performance
  • Increased kernel stability
  • Switched to SLAB
  • CONFIG_STACKTRACE disabled
  • CONFIG_CGROUP_DEBUG disabled
  • CONFIG_DEBUG_FS disabled
  • CONFIG_DEBUG_USER disabled
  • Switched to Linaro 4.5.2 GCC toolchain
  • Compiler optimization
Odin :
Download (Release 2.1.0) / better battery life : Jeffrey-SpeedFrey2.1.0uVx3-Release.tar
Download (Workaround 2.1.0) : Jeffrey-SpeedFrey2.1.0wAx3-Workaround.tar
Download (Stock Voltage 2.1.0) : Jeffrey-SpeedFrey2.1.0sVx3-Stockvoltage.tar
CWM Zip installer :
Download (Release 2.1.0) / better battery life : Download CWM zip installer
Download (Workaround 2.1.0) : Download CWM zip installer
Download (Stock Voltage 2.1.0) : Download CWM zip installer
Changelog 2.0.0 :
  • Disabled CONFIG_FTRACE
  • Disabled CPU FREQUENCY TRANSLATION STATS
  • Disable Kernel-debugging (better battery life and smoothness)
  • Disabled SLAB-debugging support (better battery life)
  • FIXED reboot and freeze (stable)
Download (Release 2.0.0) / better battery life : Jeffrey-SpeedFrey2.0.0uVx3-Release.tar
Download (Workaround 2.0.0) : Jeffrey-SpeedFrey2.0.0uVx3-Workaround.tar
Download (Stock Voltage 2.0.0) : Jeffrey-SpeedFrey2.0.0sVx3-Stockvoltage.tar
Stability test (3.0.0 / classic test) :
Stability test (3.0.0 / scaling test) :
RAM usage (2.2.0) :
Battery usage (2.2.0) :
Thanks to Hardcore (Speedmod) for his initramfs.
Quelle:
[KERNEL]░█░ Jeffrey-SpeedFrey 2.2.0 ░█░ Amazing battery life(!) & more (Update 17/08) - xda-developers
Reaktionen: evildragon09
benutze ich seit paar stunden
akkulaufzeit 5h33
display 49 min an
rest akku noch 87%
find ich bis jetzt sehr gut
Kannst du und die folgenden Erfahrungsposter bitte dazu schreiben, welche Version ihr euch installiert habt? Danke. :rolleyes2:
Habe die better battery installiert akku war auf 100% seitdem 30min sind rum einmal 3 min tekefoniett apn daueran 98% . Werde um 16 uhr weiter berichten
Sent from my GT-I9100 using Tapatalk
Ich habe den Kernel bis ebend in der Version Jeffrey-SpeedFrey 2.2.0 getestet. Meine Meinung nach lief der Kernel nicht wirklich flüssig und dazu war die Hitzeentwicklung auf dem SII bei um die 48°C
kann ich das einfach so drüberflashen??? :huh:
habe die kg6 mit cf root cwm 4 und dann nen orig. kg6 kernel drübergeflasht
mfg
Seit meinem posting
3 x mal jeweils 2 min telefoniert
Wharsapp daueran
2gmail acc sync an
Amgry birds 10 min
2min video gesehen
2 bilder gemacht
Bin bei 72% find es imo sehr gut
mfg
Habe auch KG6 und CF Root (gehabt ;))
Einfach unter CWM drübergeflasht, alles paletti ;)
Wolf
PS: Hab die 2.2.0 Release genommen... Mal beobachten...;)
Wie sind es mit einer übermäßigen hitzeentwicklung aus?
Hmm, BLN funktioniert bei mir scheinbar nicht... Oder muss ich das erst irgendwo aktivieren? Wenn ja, weiss einer wo? :confused:
Wolf
Status:
30 % Rest akku seit ca 8.40
Seit 14:43
2 Gmail Acc dauer sync
Whasapp daueran
Fancywidget daueran 2h rytm eingestellt (dies war ganzen tag an)
1SMS gesendet
ca 7 MAL a 2 Min telefoniert.
10Min Angry Bird
10MIn AIrattack
PS muss dazu sagen habe ca 11UHR energiesparoption bei LT6 eingechaltet der ja bei 50% dann in spaarmodus wechselt...
Hitzeentwicklung habe ich null gespürt.. Bei Nemp Kernel konnte ich es ab und an spüren hier nichts
hallo leute
wenn ich den kernel mit cwm flashe dann schreibt er das kein zImage gefunden wurde :(
wenn ich am pc die zip entpacke dann ist aber ein zImage dabei, wenn ich die zip am handy entpacke ist aber kein zImage dabei.
was hats da?! :huh:
mfg
nimm die odin version und flash über cwm, war bei mir auch so wie bei dir
je nachdem mit was du entpackst, scheint das buggy zu sein.
einige apps haben probleme mit Dateien die keine Endung haben wie z.b. *.zip oder *.txt etc etc
Ich muss sagen, bei mir klappt es per Recovery problemlos. Auch mit der CWM App (egal ob als *.zip oder direkt die zImage geflasht)
Danke euch, habe es aber mit odin als pda geflasht. cwm hat einfach nicht funktioniert.
runtergeladen mit versch browsern, über handy geladen alles mögliche versucht. hatt nicht geklappt.
Mal schauen wie sich der kernel macht.
Mfg
Bitte oben ergänzen:
CWM Flash funktioniert nur im Recovery Modus.
Flash Kernel in def App geht nicht.
Ansonsten wird das Handy schon weniger warm.
per cwm app geht es !
aber nur mit der odin version, bei der anderen kommt diese zimage fehlermeldung
also sollen wir das lieber viel koplizierter verfassen damit es viele unnoetige Fragen gibt... .
wieso komplizierter CWM Zip installer version geht nciht bei der cwm app über flash kernel, aber die odin version geht ohne probleme
und hier meine verbrauchswerte
endlich funktionierder cifs support. 1000 dank! :scared:
