Masta_Gee81
Enthusiast
- 5.405
Die Neusten Updates erhaltet Ihr auch hier :
Offizielle Seite:SiyahKernel for SGS2 | "One kernel to rule them all"
SiyahKernel V2.XX
SiyahKernel V2.XX
Although some parts can be considered as original, all are based on inspirations, examples and other people's code.
I have no claim to be original. I am only trying to make my (and probably other's) SGS2 experience better and fun.
I do this for fun. so, if you just want to argue with me please don't. use the energy coming from your youth in something useful.
SiyahKernel v2.6.14
FEATURES
Can be flashed on Samsung ROMs and AOSP Based ROMS. Currently all Samsung 2.3.4, 2.3.5, 2.3.6, 2.3.7 based ROMS, CM7 (CM9 or any other ICS based ROMs are not supported) and MIUI ROMS are supported.
Based on linux kernel 2.6.35.14 + drivers from Samsung sources
Auto-Rooting
Custom CWM compatible Redpill Recovery from af974 (For more info: http://forum.xda-developers.com/show...postcount=9680 )
Custom boot animation support
Supports SetCPU (OC upto 1600MHz, UC downto 100MHz)
User customizable frequency steps. You can edit "freq_table" and use 25MHz as the lowest step and 1696MHz as the highest. You have 8 steps (it is fixed) but the frequencies can be set.
Supports undervolting (UV between 800 mV and 1500 mV)
Supports voltage control via SetCPU (thanks to netarchy, ninpo, hacre)
Stock voltages as default
smartassV2, lulzactiveV2 governors. and lots of other governors which are available as modules
Default governor is lulzactive (200-1200MHz)
Tweaked ondemand and conservative governors
no compiler optimization. it is just a myth.
Touchscreen fix (thanks to vitalij)
Increased touchscreen sensitivity
GPU clock (thanks to netarchy), voltage and scaling thresholds control interface.
I/O, scheduler, hotplug and vm tweaks
automatic battery calibration. (removed. thanks to Entropy512. we do not need battery calibration for SGS2)
Available I/O schedulers: noop, deadline, CFQ, BFQV3r2(default), V(R), SIO
Available CPU governors: see this thread for the list of available governors and modules (thanks to droidphile)
/system/etc/init.d startup scripts support
Automatic backup of efs partition. You will have the files in your sdcard as well as /data/.siyah directory. copy them to a safe location in case you may need them later.
BLN (thanks to creams), liblights is autoinstalled if the existing one doesn't support BLN
supports advanced touch tune driver. thanks to vitalij Link. the control app from Web, from Mobile. Thanks to tegrak for the driver patch file download
2nd core application support (thanks to tegrak)
Automounting of NTFS volumes for USB sticks (ntfs on external card is not supported). although your rom says "clear storage", just check /mnt/usb folder. ntfs drives will be automatically mounted in read-only mode.
LZOP compression for the kernel to have very fast decompression. We have a VERY BIG kernel image because we have ntfs-3g, CWMManager and lots of other things both in initramfs and payload.
Integrated new&faster sha-1, crc32 slice-by-8, crc32c, jhash and rwsem algorithms
SCHED_MC enabled to have less power consumption.
Lower brightness levels for low-light conditions to save battery.
Brightness behaviour modification via setting min_bl, min_gamma and max_gamma values. you can control the lowest and hightest levels used in autobrightness.
Native BLN support for CM7 based roms.
Three GPU stepping (160-267-300) instead of two
optimized and configurable hotplug thresholds and rates.
Thunderbolt! script integrated (thanks to pikachu01)
Voodoo louder app support (thanks to supercurio)
Current Widget support while charging the device.
ExTweaks (uci.sh) support. (Thanks to xan and AndreiLux) ( https://market.android.com/details?i...n.extweaks.app )
CIFS, SLUB, FUSE, NTFS, cgroup_timer_slack, autogroup,... and lots of other mambojambo that I forgot...
Download link: SiyahKernel for SGS2 | "One kernel to rule them all"
FLASHING GUIDE
TO FLASH TAR:
If you already have root, use DarkyOTA app from the market ( https://market.android.com/details?i...to.darkyromota ) .
If not, use ODIN.
TO FLASH ZIP:
Use CWM Recovery and install zip file. Wiping cache&dalvik cache is recommended for those who use BLN.
if you lose root after flashing the kernel (unlikely), flash http://goo-inside.me/superuser/su-2....fgh-signed.zip in CWM.
Some Example Init.d Scripts
Example CWM-flashable /system/etc/init.d/99gpuv script (thanks to AndreiLux)
Example GPU/CPU undervolting and underclocking scripts by kwerdenker
Improved version of CPU undervolting script by kwerdenker
Another couple of nice init.d scripts created by fenomeno83
flashable lionheart cpu governor and setting default i/o scheduler to deadline (remove /system/etc/init.d/01lionheart to uninstall. thanks to knzo for the tweaked conservative governor settings)
releases can be found here: SiyahKernel for SGS2 | "One kernel to rule them all"
source code repository: http://bitbucket.org/gokhanmoral/siyahkernel
CHANGELOG
see SiyahKernel for SGS2 | "One kernel to rule them all" for the changelog.
TODO
more and more optimizations for less battery drain
ICS edition when samsung releases new kernel sources
stable wifi driver which doesn't cause a lot of wakelocks with proper offloading
BLN notifications without wakelocks
OTA application (just to prevent users downloading wrong kernel for their device. other than that, it will be useless for a kernel)
Samsung, supercurio, hardcore, Hacre, RAvenGEr, tegrak, cattleprod, codeworkx, hellcat, creams, vitalij, arighi and others I might have forgotten...
Download:
[KERNEL] SiyahKernel v2.2 - "One kernel to rule them all" (SAMMY&AOSP ROMs) - xda-developers
oder
[Bootanimation] The Very Unofficial Siyah Kernel Bootanimation
Use this for myself, nothing special so far, BIOS bootscreen and after that blackscreen which says Siyah Kernel and does some wiggle...
Enjoy ^^
Preview:
Full Resolution Preview
Download:
PC_SiyahKernel_bootanimation_CWM.zip
The New Very Unofficial Logo
PC_SiyahKernel_bootanimation_withSound_CWM.zip
Siyah New Logo NoSound.zip
Original Sound CWM.zip
Bootup Revert CWM.zip
Quelle: [Bootanimation] The New Very Unofficial Siyah Kernel Bootanimation - xda-developers
Danke an KcDaRookie für die Bootanimationen !!!
Setting Voltage Control Siyah 2.3 - YouTube
CPU
850@100Mhz
875@200Mhz
875@500Mhz
975@800Mhz
1100@1000Mhz
1175@1200Mhz
1225@1296Mhz
GPU
800@100Mhz
900@200Mhz
Charging
Charger 750mA
Misc 650mA
USB 450mA
Enjoy ^^
Preview:
Download:
CPU
850@100Mhz
875@200Mhz
875@500Mhz
975@800Mhz
1100@1000Mhz
1175@1200Mhz
1225@1296Mhz
GPU
800@100Mhz
900@200Mhz
Charging
Charger 750mA
Misc 650mA
USB 450mA
Quelle:
[KERNEL] SiyahKernel v2.6.4 - "One kernel to rule them all" (SAMMY&AOSP ROMs) - xda-developers
P.S. Danke drücken kostet nix
