[KERNEL][ExTweaks] SiyahKernel v2.6.14 - "One kernel to rule them all" - Nur für GB
  • 6.747 Antworten
Mal wieder was neues vom Siyah... Es gibt ein neues CWM Recovery...
SiyahKernel v2.6.3
Posted on December 29, 2011
changelog:
Fixed setting of lulzactive & smartassV2 parameters via scripts
battery optimized defaults.
updated codecs
removed siyah-battery, siyah-defaults and siyah-performance scripts from the blog. please remove all existing scripts before installing this version (or flash your existing rom again to remove all scripts). use init.d scripts if you know what you do, otherwise use VoltageControl app or ThunderBolt! scripts.
CWM Recovery v5.5.0.4
Reaktionen: Metzi
Kjetal schrieb:
SiyahKernel v2.6.3
changelog:
  • Fixed setting of lulzactive & smartassV2 parameters via scripts
  • battery optimized defaults.
  • changed the order of internal & external sdcards in cwm recovery. internal sdcard can now be mounted over usb in cwm recovery, but external sdcard cannot be mounted.
  • updated codecs
  • removed siyah-battery, siyah-defaults and siyah-performance scripts from the blog. please remove all existing scripts before installing this version (or flash your existing rom again to remove all scripts). use init.d scripts if you know what you do, otherwise use VoltageControl app or ThunderBolt! scripts.
International (i9100) Version: Not released yet
NTT DoCoMo (Japanese) Version:
AT&T (SGH-I777) Version:
Posted in Uncategorized
Ergänzung bzw. Änderungen:
SiyahKernel v2.6.3
changelog:
  • updated codecs
  • CWM Recovery v5.5.0.4
Reaktionen: Blackman1945, Metzi und Kjetal
Jopp danke, dass ist das Selbe was cm9 auch hat:)
SGS II Cyanogen Tapatalk
Na das kann ja was werden.
Wieder eine neue version von cwm. Sicherlich wieder was experimentelles. Naja ich lass mich mal überraschen, hoffe ja das er morgen das Update raushaut.
Gesendet von meinem Samsung Galaxy S2
:Ddann rutschen wir ja richtig rein :lol:
oha, solch CWMSprung :scared:,
aufwärtskompatibel in Bezug auf Nandro Backups
vielleicht ne feine Sache aber dann evtl. wieder abwärts,
hoffentlich störts nicht, wie wenn man ein CWM5 Backup
unter CWM4 wiederbeleben will :D
Man muss dann umso schneller entscheiden.
finde noch keine Fakten (chancelog von CWM Recovery v5.5.0.4 )
gibt es das ?
Ich bin ein derart absoluter Fan vom CWM-Manager 3.0 unter CWM5 :thumbup:
Das Teil ist der Kracher in Bezug: STOCKWARE wiederherstellen OHNE USB ,
egal ob 1- oder 3-teiler, einfach grandios!
@Kjetal
läuft es denn gut unter cm9? :drool:
Deinem Smilie zu entnehmen, eher ja, ja?:D
Nachtrag-----------------------------------------
der Punkt erledigt sich schonmal durch das KernelCleaningScript :D
changelog:
Wie wird es gehandhabt, wenn man beides (VoltageControl app or ThunderBolt! scripts) am laufen hätte, denn ist denn der Sheduler auch
auswählbar über den ThunderBolt!, ansonsten wäre ja VC nicht wegdenkbar. Wie wird das abgearbeitet?
Ja, hatte keine probleme damit :)
Der 2.6.2 ist zwar vom Verbrauch besser als der 2.6.1 aber der ruckelt irgendwie leicht.
Sent from my S2
Sent from my S2
siyah 2.6.2 mit lulz app? bei mir ruckelt frei von 2.6.2 mit lulz app.
MFG Hotroadster
PS: ich bin gehörlos :D
Hallo
Kann mir mal einer CWM Manager v3.0 hochladen?
Danke
Danke ;)
Bin von 2.6.2 etwas enttäuscht.
Wenn ich lulzactiv anpassen will per app friert das Handy öfters mal an ohne Grund ein. Schade eigentlich.
Ich hatte ähnliche Probleme. Meins wollte nicht mehr aus dem Standby aufwachen bzw. der Bildschirm blieb schwarz. Bei mir hat es geholfen, screen_off auf 500MHz anzuheben.
Kann das nicht auch an den Einstellungen liegen, die du vorgenommen hast?
Hatte zwischendurch auch einen Freeze, habe dann alles nochmal ein bisschen performance mäßiger umgestellt und siehe da, läuft.
Klar liegt es an den Einstellungen. Freezes entstehen zu 90% durch zu niedrige werte. :)
Manchmal ist weniger mehr;)
@ ich bin mit dem Siyah 2.5.2 wirklich bis heute am besten gefahren im Verbrauch und in der Performance, kein Freeze, kein Hänger und keine Ruckler und alles ohne Einstellungen....das passt super mit Siyah 2.5.2 und bleibt drauf...:cool2:
Nix eingestellt.
Das teil läuft Stock bei mir nicht rund. Spontan reboots, death im standby usw.
Mit 2.5.2 läuft alles ohne zicken.
Kleiner Zwischenbericht von mir: Habe Kjetals Werte übernommen. Läuft anständig.
MadMurdoc schrieb:
Nix eingestellt.
@MadMurdoc...es kann doch sooo einfach sein...:cool2:
So und jetzt hat jeder 2.6.2 Siyah User seine Performance für 2.6.2 gefunden, eingestellt und 2.6.3 liegt schon im Torpedorohr...na viel Spass beim Einstellen...ich bleibe bei 2.5.2 ohne Einstellungen.:cool2:
kann mir einer die frage beantworten ob im deepsleep immer gleich viel akku verbraucht wird, egal welchen govener man eingestellt hat?
Androidflash
firemaker911
firemaker911
j1gga84
j1gga84
j1gga84
beicuxhaven
HCD
HCD
