mecss
Ehrenmitglied
- 11.925
Hier der Vollständigkeitshalber der komplette Changelog mit samt aller Links...
SiyahKernel GT Edition v2.5
Posted on December 12, 2011
GT = Gokhanmoral and Turkbey (thanks to him for his Rom and feedbacks)
Changelog:
NTT DoCoMo (Japanese) Version : TAR, ZIP
AT&T (SGH-I777) Version: TAR, ZIP
Changelog:
- fixed min_bl typo. now, it works as it should. (it is in /sys/classes/misc/brightness_curve . set it higher to have minimum brightness for more bright conditions. you may also want to lower max_gamma to lower the maximum brightness level. My settings are 70 for min_bl 19 for max_gamma. see /sbin/siyah/tweaks.sh for a commented example (remove # and use in an init.d script)
- changed frequency scaling method and removed rate multipliers from ondemand governors.
- removed intellidemand governor and added ondemandx back.
- set default i/o scheduler to v(r)
- enabled AFTR
- added tcp tweaks from speedcore kernel (thanks to hardcore)
- lowered the min GPU frequency from 160MHz to 100MHz and enabled aggressive scaling policy (it lowers the up_threshold for GPU freq scaling from 65 to 55)
- vmscan: prevent background aging of anon page in no swap system
- some other tweaks in other governors &&/|| thresholds
- disabled CONFIG_RCU_FAST_NO_HZ
- enabled CONFIG_CGROUP_TIMER_SLACK
- A commented example is added to /sbin/siyah/tweaks.sh to set the touchscreen threshold (/sys/devices/virtual/sec/sec_touchscreen/tsp_threshold)
- deep sleep entering frequency is 500MHz (1000MHz on stock, 800MHz on most of other custom kernels)
- reverted back the tweaks for lulzactive. we are back to lulzactiveV1 and if tegrak publishes the sources I will integrate lulzactiveV2
- Set default governor back to Ondemand. (My new favorite is now ondemandX).
- updated wifi drivers
- compiled with dev release of linaro 2011.12-4.5 toolchain, with -O3 (this is the only difference between this release and the one in Turkbey rom. I didnt want it to be experimental and compiled it with old good codesourcery toolchain)
