mecss
Ehrenmitglied
- 11.925
v2.2 beta12
Posted on November 17, 2011
Changelog:
Last known good beta: (In case you have a problem, use this version before going back to previous release) v2.2beta11
tar: http://www.gokhanmoral.com/public/files/siyahkernel/test/Siyah-v2.2beta12.tar
zip: http://www.gokhanmoral.com/public/files/siyahkernel/test/Siyah-v2.2beta12-CWM.zip
Changelog:
- back to SLUB
- some performance tweaks in scheduler and memory manager
- re-enabled TREE_PREEMPT_RCU with FANOUT=16 just like in beta6
- only external sd is mounted over usb in CWM recovery.
- some apps may index your external sd content twice because we have both /mnt/emmc and /mnt/sdcard/external_sd directories pointing to the same content.
