Masta_Gee81
Enthusiast
- 5.404
- Themenstarter
- #2.801
v2.2 beta10-DarkKnight
Posted on November 16, 2011
Changelog:
known issues:
Last known good beta: (In case you have a problem, use this version before going back to previous release) v2.2beta6
Changelog:
- removed symlink from /mnt/emmc to /mnt/sdcard/external_sd
- experimental fix for bt problems
- disabled SCHED_MC
- experimental lower screen-brightness values for low light conditions (not yet configurable, but it will be)
- fix for touchkey backlight not turning off
- fixed liblights not being copied for miui and oxygen roms. copying lights library suppressed only for CM7 and derivatives.
known issues:
- only external sd is mounted over usb in CWM recovery.
