[KERNEL] DarkKnight V2.5.2p
  • 521 Antworten
Simuur95
Simuur95
DarkKnight v2.5.2p Updated (DEC 16 )
16. Dezember:
Update: DarkKnight V2.5.2p
has all the features of Siyah-v2.5.2b with the following exceptions:
pm_max to pm_fast
wifi range should be increased.
If a feature cause instability it is disabled or limited. Battery optimizations are included as long as they do not decrease the performance or cause instability.
default cpu governor is conservative
default i/o scheduler is deadline
sleep frequency is 800MHz
stock lowest brightness value
Update 2.4.3
FEATURES
Update: DarkKnight V2.4.3
hd playback is fixed.
touch lights fixed.
sleep freq is set to 500MHz and it should be stable this time.
it should be near perfect, even the best release made till now.
fixed USB OTG
Added intellidemand governor. this is a modified ondemand governor and very battery friendly.
default lowest freq is set to 200MHz. default governor is still (tweaked)conservative.
some other tweaks & fixes
tweaked ondemand, conservative and ondemandx governors. I think stuck-to-800MHz problem is fixed.
Enabled some tweaks in tweaks.sh. video playback on external sd should be better now.
disabled hidden ssid in wireless driver to fix wifi tethering problems (thanks to Entropy512)
back to SLAB
fixed usb keyboard&mouse problems
Update
Ok so i have updated the old downloads for the kernel with a updated kernel that will no longer cause any bootloop issues that were reported by some!
also UV has been removed so that i can facilitate my personal UV steps hats better than you yourself doing it!
Checkrom Dev:
So Me and Gokahamoral (Siyah Kernel Dev) Decided to build a entirely new platform for Battery Saving's
This is a Kernel with Crazy Feature! And with Out of the ordinary performance.
This is not the regular Siyah Kernel but different and trust me really different, its build for more stability and more battery life instead of a all round performer like siyah.
Choice of kernel is your personal preference.
FEATURES
Changed auto-brightness levels.
fixed auto-rooting problem
reverted back to old workqueue implementation
reverted memory allocator to SLAB
enabled cleancache
default i/o scheduler: sop
slub as in stock kernel.
some limitations in undervolting (max 100mA per each step)
some limitations in charging current (max 800mA) to prevent overheating
lulzactive default and tweaked a little more (55 up-threshold which makes it more snappier, previous was 60) and disabled lulzactive debugging.
cleancache enabled. this should improve performance.
ondemand and conservative are also better than previous release
Can be flashed on Samsung ROMs and AOSP Based ROMS. Currently all Samsung 2.3.4 & 2.3.5 based ROMS, CM7 and MIUI ROMS are supported.
Samsung sources Update3
Auto-Rooting
Complete DK Engine
Boot animation support
Custom boot logo and startup sound (thanks to hellcat)
Supports SetCPU (OC upto 1600MHz, UC downto 100MHz)
Supports undervolting (UV between 800 mV and 1500 mV)
Supports voltage control via SetCPU (thanks to netarchy, ninpo, hacre)
Stock voltages as default
smartassV2 governor
Tweaked interactive governor
Tweaked on-demand governor
Compiler optimizations (DK style)
user customizable charging speed (use at your own risk). you have to echo AC, MISC and USB charge currents to a misc device.
Touchscreen fix (thanks to vitalij)
Increased touchscreen sensitivity
Increased battery polling interval
GPU clock and voltage control interface (thanks to netarchy).
I/O Tweaks
automatic battery calibration. (removed. thanks to Entropy512. we do not need battery calibration for SGS2)
Available I/O schedulers: noop, deadline, CFQ, V(R), SIO (default)
Available CPU governors: ondemand (default), interactive, smartassV2(recommended), conservative, userspace, performance, powersave
/system/etc/init.d startup scripts support
Automatic backup of efs partition. You will have the files in your sdcard as well as /data/.siyah directory. copy them to a safe location in case you may need them later.
Updated jhash to version 3
Increased charging speed.
BLN (thanks to creams), liblights is autoinstalled if the existing one doesn't support BLN
CIFS, SLQB, NTFS
Quelle:
[KERNEL] DarkKnight V2.3 | CheckROM
Download 2.5.2p:
CWM:
Multiupload.com - upload your files to multiple file hosting sites!
Reaktionen: Carew, FotoMichi, Peter Griffin und 12 andere
Habe ich drauf und rennt wie eine 1 :)
Habe mit dem auch weniger Probleme als mit Siyah obwohl sie fast gleich sind
Rennt wie henne bisher mal schauen fettes danke erstmal
Einfach in Odin´s PDA einfügen ?? Hab schon länger nicht mehr geflasht...:crying::confused2:
wenn du die Tar runter lädst ja.
wenn du die zip geladen hast, dann die entpacken und die ZIMAGE auf deine SD kopieren.
Dann mit CWM App flashen
Einfacher ist natürlich Methode 1
....gerade die mag er aber nicht ????
Was passiert denn da mit Odin bei dir ?
Hast du auch Odin3 1.85 ?
.zip downloaden Handy aus und uns recovery booten und im cmw installiert zip from sd card zip suchen Standart im Download Ordner. Zip auswählen und yes install
Keine Ahnung was war...jetzt ging´s.....trotzdem danke !!!
@blackcorsa wieso die zip entpacken?
Also bei mir geht es nicht. Habe die Checkrom drauf und habe es erst über CWM und dann per Odin gemacht keine change bleibt immer beim Dreieck stehen.
Hat da jemand eine Lösung?
[OFFURL]https://www.android-hilfe.de/root-hacking-modding-fuer-samsung-galaxy-s2/126994-der-handy-startet-nicht-mehr-hilfe-thread.html[/OFFURL]
Ich bin mir bewusst wie ich mein Handy wieder hin bekomme. Habe auch gleich den alten Kernel mit Odin drauf gemacht und es läuft aber wieso der DK nicht?
Darauf ist die Frage bezogen und nicht wie ich da wieder weg komme!
Lg
Kalle
Teste den DK 2.3 jetzt auch mal.
Bin gerade auf Stock 2.3.4 KI4 und darauf läuft der DK sehr gut. Kann ich nur empfehlen.
Habe aber auch nichts eingestellt. SetCPU oder dergleichen.
Bei mir läuft er auch sehr gut.
Der DarkNight ist auch schon ewig mein lieblings Kernel.
Jup, kann man nicht meckern :)
Läuft mehr als rund
Reaktionen: Manu-1
Läuft der auch mit der neuen KK5?
Edit: Ok mit der 2.3.6 geht es wohl nicht wie es auf der Seite auch steht.
Doch funktioniert. Zumindest der Siyah 2.3 geht, also wird der hier auch gehen;)
doch bei mir läuft er mit der crikskelo 32 ( based on kk5 ) astrein :)
edit: zu langsam :p
