->TopAZ<-
Ehrenmitglied
- 6.434
- Themenstarter
- #21
@ dodo666
Zitat droidphile @ XDA
Beantwortet das deine Frage?
CU
"What's the basic architecture behind dual booting?"
A. Any rom will have /system, /data, /cache partitions and requires a kernel to boot. Primary rom has all these partitions on the same location and partitions as if you were single-booting. ie, /dev/block/mmcblk0p12 for /system and rootfs for /data and /cache. Secondary rom uses a hidden partition (/dev/block/mmcblk0p9) for /system and sdcard to store /data and /cache partitions. They're stored in /sdcard/.secondrom directory as mountable ext4 block device images (data.img and cache.img).
Kernel partition is shared, so same kernel boots both the roms. If you switch from Siyah to a different kernel, dual booting will not be available even though there's a clone of secondary rom. Internal sdcard, external plastic sdcard, /efs, /emmc, other kernel related virtual filesystem directories, etc are shared among roms.
There's /system, /data/ and /cache to clone. 2 GB data + 103mb cache + 513 mb system = 2.6 gb
CU
wurde ja wieder rausgenommen
