[AOSP/Sammy-KERNEL][ICS] *14.12.12* Shun Andromeda 2.2.5
  • 102 Antworten
Chris1996
Chris1996
Stamm-User
141
Shun Andromeda v2.1.0
2040
After Ikki The Phoenix, the adventure is continuing on ICS thanks to XDA and Elite recognized developpers as Gokhanmoral, Entropy512 and others devs (myfluxi, simone201, and many others...).
Toolchain 2012.03 (gcc 4.6.3) with -Ofast compiler option as with Ikki.
Tweaked conservative settings
100-1600 Mhz frequencies (but 200-1200 Mhz by default)
ExTweaks configuration powered (I recommend ExTweaks Plus)
GIT
https://github.com/bgn9000
CWM Scripte um Profile zurück zu setzen (battery, default et performance) : HERE
Remarks:
1/ Changing profiles not working into CWM (additional kernel actions) because I never had time to compile my own CWM and change Siyah's code to point to /data/.shun
2/ This script is moving all profiles into sub directory named "backup".
ChangeLogs and zImages (only through CWM)
Changelogs:
Version 2.1.2 / CWM only ICS 4.x and CM10 ROM
1/ Linux 3.0.46
CWM version : HERE
Version 2.1.1 / CWM only ICS 4.x and CM10 ROM
1/ Linux 3.0.45
CWM version : HERE
Version 2.1.0 / CWM only ICS 4.x and CM10 ROM
1/ Linux 3.0.44
CWM version : HERE
->XDA-Thread
Reaktionen: janosik und ricmaster
Zu den ATT-Versionen:
DerMächtigeSchmops;3299064 schrieb:
Die ATT-Version ist für den amerikanischen Markt gedacht. Da gibts nen Provider der Att heißt (so wie bei uns Telecom oder Vodafone) und dieser Provider hat ne bestimmte angepasste Version des SGS2, ich würd die ATT-Version nicht flashen, wenn ihr euer Gerät nicht kaputtmachen wollt.
hab ihn jetz mal zusammen mit miui V4 drauf.
Neue Version :>
Version 1.0 / CWM
only ICS 4.0.X ROM
1/ bcmdhd : patches from Siyah 3.2.3
2/ mmc: increase mmc read and write timeout for some crappy cards.
3/ ld9040: adjust panel gamma order to have more smooth transitions in lower brightness levels
& panel gamma set changes to have lower brightness for low-light conditions
4/ from Siyah : cypress: led fadein/fadeout (inspired from myfluxi's repo).
& cypress: restore led regulator voltage after fading out
5/ mozilla boot-to-gecko (b2g) support. (thanks to pulser)
6/ cm9 sdcard mounts
CWM version : http://bit.ly/Ll3FUu
Reaktionen: Chris1996
Ich war mal so frei und habe bereits den Thread-Titel aktualisiert... ;)
Vielen dank. :D
Unterstützt der Kernel Dual-Boot ?
Ja.
Danke dann werde ich den mal testen !
@ Perle2312
sry aber ich lag falsch! im Moent unterstützt der Shun noch keinen Dual-Boot :/
aber kommt noch ;)
Ist doch okay jeder täuscht sich mal.Danke trotzdem und woher weisst du das Dual-Boot in nächster Zeit unterstützt wird ?;)
Weil es im recovery diese Optionen schon gibt und wenn du jedoch einen der dual-boot Optionen auswählt kommt eine Meldung das diese Funktion noch nicht unterstützt wird ;)
Danke dir für deine Auskünfte und wünsche dir noch einen schönen Abend ;)
Chris haste den Kernel den jetzt drauf?
Gesendet von meinem Android-Flagschiff Galaxy s2
@Chris,
der Opener wird aber noch verbessert?... ;)
1.1 ist raus
@ mecss
Sry aber ich hatte den thread schon eingerichtet -.- keine Ahnung was da schief gelaufen ist :what:
Ich hatte auch den Link zum original thread und alles schon drin :banghead:
@ debaki
Ne da ich im Moment ungern auf dualboot verzichten möchte :rolleyes:
Der Suff :D
Da passieren so einige merkwürdige Dinge :cool:
Sent from SGS II powered by PARANOIDANDROID
Reaktionen: mecss und Chris1996
j1gga84
j1gga84
j1gga84
beicuxhaven
HCD
HCD
j1gga84
simplymad
