[AOSP/Sammy-KERNEL] *13.05.12* VokuKernel v2.7
  • 214 Antworten
voku1987
voku1987
sources:
github.com/voku/ (Git?)
* Ich habe momentan nicht viel Zeit, daher verweise ich an dieser Stelle auf den "Dorimanx Kernel" und werde versuchen dieses Projekt zu unterstützen :) Mfg *
---- 3.0.31 ----
onboard:
based on -> https://github.com/gokhanmoral/siyahkernel3 | THX @gokhanmoral
- sync with Dorimanx-Kernel (info)
- added some changes from NEAK-ICS-Kernel (info)
- added some changes from Thoravukk-Kernel (info)
- added some changes from SC-02C (Galaxy S2 JP) (info)
- added some changes from CherryPicker-Kernel (info)
- added some changes from xxKernel (info)
- added new Tweak-Script (info)
- cpu-freq (100 <-> 1500)
- added new CPUFreq Governors (info)
- added fsync-control | THX @Ezekeel (info)
- added default Compressed RAM block device [zram] (info)
- added tuned sqlite for CM9 and forks (info)
- added optimized SHA1 routine
- improve the performance of memcpy and memmove of the general version (info)
- compiled with gcc4.7 & new CFLAGS (info)
download: -> samdroid.voku-online.de
changelog:
Here you can find the most significant changes, for a full changelog take a look at the sources on github.com ... ;)
v2.7 (13.05.2012)
+ full sync with Dorimanx-Kernel (info)
+ sync with Linux 3.0.31 (info)
+ fixed Tweak-Script (info)
+ cpufreq: added lazy smartass
v2.6 (04.05.2012)
+ sync with Dorimanx-Kernel (info)
+ revert some CFlags
+ other small changes
v2.5 (02.05.2012) (deleted)
+ sync with Siyahkernel-Kernel (info)
+ fixed SD-Card problem
v2.4 (01.05.2012) (deleted)
+ sync with CherryPicker-Kernel (info)
+ compatible with "ExTweaks"-App
+ updated TCP-Buffer size (info)
+ updated CFlags (info)
v2.3 (30.04.2012)
+ sync with Linux 3.0.30 (info)
+ more battery-tweaks (info)
+ compiled with new gcc & new CFLAGS (info)
+ update "ext4"-filesystem & mount-optinos
+ update "Power Management support" => "Deep Sleep"
v2.2 (26.04.2012) (deleted)
+ disabled swap (zRam) by default (info)
+ updated lowmemorykiller.c | thx @dorimanx (info)
+ updated Tweak-Script for bettery battery-time (info)
+ changed voltage-settings for 100MHz => 925mV (info)
v2.1 (26.04.2012) thx @Perle2312 for testing
+ changed cpu-freq (100 <-> 1200) (info)
+ added some PM (Power Management) patches/changes
v2.0 (24.04.2012)
+ changed ExTweaks-Settings for this kernel
+ changed default cpu-gov.: Lazy
+ compiled with new gcc-version (android-toolchain-eabi-linaro-4.6)
v1.9 (23.04.2012)
+ sync with Linux 3.0.29 (info)
+ ondemand as default
+ using new liblights | THX @gokhanmoral
v1.8 (23.04.2012)
+ sync with Siyah-v3.1 (info)
+ changed cpu-freq (100 <-> 1400)
v1.7 (22.04.2012)
+ sync with Dorimanx (info)
+ added default sources with some new cpu-freq (25 <-> 1500)
+ fixed CM9 (missing kernel modules ...)
+ added default battery-saving settings
+ added tuned sqlite for CM9 and forks (info)
+ added Gingerbread legacy hotplug (info)
+ revert -> re-enabling GENTLE_FAIR_SLEEPERS
v1.6 (21.04.2012)
+ sync with Dorimanx-initramfs (info)
+ fixed wifi toggle issue | THX @wjchen (info)
+ changed cpufreq-4210.c -> to use "asv_voltage_B"
+ added synchronization framework (info)
+ added more optimised CFLAGS
v1.5 (20.04.2012)
+ fixed recovery-problem
+ sync with Dorimanx-kernel (info)
+ added cpufreq: smooth scaling interface
+ changed default cpu-hotplug settings (more battery-saving? -> need testing)
+ re-enabling GENTLE_FAIR_SLEEPERS
v1.4 (20.04.2012) (deleted)
+ updated Tweak-Script (info)
- added TWEAKS: for TCP read/write
- added TWEAKS: optimized for 3G/Edge speed
- added TWEAKS: cpu => battery-friendly | THX @mecss
- added TWEAKS: NET-Settings
+ added fsync-control | THX @Ezekeel
v1.3 (19.04.2012)
+ sync with Dorimanx-Kernel | THX @Yuri.Sh (info)
+ added some changes from SC-02C (Galaxy S2 JP) (info)
+ added more "CPUFreq Governors"
+ added battery-saving settings / features
+ changed cpu-freq (25 <-> 1600)
Reaktionen: denyo81, Galaxy_S2, mareis1973 und 9 andere
Da erinnert man sich an das Spica !
Werde ich mal testen, vor allem wegen der 1600 !
Spitze Kernel alles was der Sijah hat, damit meine ich, Dual Boot und viele andere Spielereien hat er auch noch. Jetzt muss nur noch der Akku passen und ich bin zufrieden
Hi. Danke für den Kernel. Bekomme ihn allerdings nicht zum laufen. Habe das Kernel Aufräum Script durchlaufen lassen und dann den Kernel geflasht. Startet auch und Anwendungen werden aktualisiert. Allerdings bleibt es dann bei "Anwendungen werden geöffnet" hängen.
Uro
Moin, habe eben den Kernel installiert, sieht alles sehr gut aus.
Es wäre besser in den Opener mit aufzunehmen, dass er sowohl für Sammy-ROMs als auch für AOSP/AOKP-ROMs geeignet sei, damit man sich all die Fragen sparen kann, wofür er verwendbar ist... ;)
Reaktionen: franzm19
Ich habe den Thread Titel in diesem Bezug angepasst. Der Kernel selbst wirkt sehr gut, basiert auf dem Siyah , gefällt mir.
Cyanogen (mod) 9
Du wirst doch GM nicht abtrünnig?!
Akku hält sehr gut bis jetzt seit 7.00uhr heute früh drauf 2std Display an und noch 71%Akku. TOP!
Uro
Wollte ihn auch mal flashen, aber das gleiche Problem bei mir! :what:
Aktuell:
Dual Rom's
[--VK--™]-[-XWLP8-V4.6.1]
TurkbeyRom V5
Siyah RC5 (Battery)
Ich weiß nicht warum er bei mir so gut Funktionert normal hab ich auch immer Probleme wenn es welche gibt:o .Aber dieser Kernel Funktionert super unf Akku ist auch Top
Keinerlei Probs.
Versucht es noch mal mit Cache Wipe, Dalvik, UKS, Kernel, Cache, Dalvik!
So, ich gebe dem Kernel hier jetzt auch mal eine Chance. Bin sehr gespannt, vor allem auf den Akkuverbrauch. Der Siyah Kernel frisst ja in letzter Zeit irgendwie doch relativ viel Ladung und das obwohl man im Standby ist.. :/
Vollkommen normal, hast du das Battery Profile genommen `? Ausserdem sind die % Zahlen nur schätz werte , durchaus normal das Kurzzeitig der Wert mal hoch gehen kann :)
Ach so, ja ich vergesse das immer das das nur Schätzwerte sind. Allerdings war irgendwie der Akkuverbrauch mit dem normalen Siyah Kernel trotzdem etwas größer als jetzt bisher mit diesem hier. (Wobei ja jetzt eine neue Version von Siyah Kernel draußen ist und bei dem kann ich es allerdings noch nicht sagen wie es da mit der Batterie aussieht.)
Nein, nicht ganz. Bin zwar mehr darauf gegangen das ich mehr Akku habe, allerdings habe ich geschaut das ich einige eigene Einstellungen tätige um auch etwas Performance zu haben. :)
Jo , ich wollte damit nur sagen das das mit den +% meist auffällt wenn man auf Battery umstellt :)
Allerdings was mir als negativer Punkt aufgefallen ist (was allerdings nur dann passiert) ist, wenn ich diesen Kernel geflasht habe und mein System reboote er anfangs richtig hackt und zögert und etwas braucht bis er die gesamten Daten gelesen hat. Braucht also erst mal 'ne halbe bis ganze Minute bis er meinen Display (den Homescreen) anzeigen kann und zuvor beim eingeben des PINs z.B. ruckelts auch schon.
Aber wie gesagt, dies passiert nur einmal direkt nach dem flashen, anschließend läuft der Kernel hier so flüssig wie 'ne eins.
Ist normal, da im Normalfall Cache und Dalvik beim Kernel Flash gewipt werden. Hat man mit anderen Kerneln auch ;)
Ach so, ja dann. (Wahrscheinlich dann, mit anderen bis auf Siyah! :p)
In dem Kernel gibts einen kleinen Fehler.
Bei mir ist es von 200-1200 MHZ eingestellt. Komischerweise wird auch 1600Mhz benutzt alles was zwischen 1200 und 1600 ist dagegen nicht.
