hsvl1ve
Gustav_s hat heute neue 4.4 Kernel rausgebracht
http://forum.xda-developers.com/showthread.php?t=2222843
sync: allow async waits to be canceled
Revert "cpufreq: zzmoove: tweak some tunables from apollo kernel"
stweaks: re-add generic01 script
arm: lib: re-add strnlen_user and strncpy_from_user
stweaks: fix typo
stweaks: fix typo
fs: dynamic fsync off by default
build: update defconfig
staging: zcache: fix length type mismatch
staging: zcache: avoid AB-BA deadlock condition
mm: frontswap/cleancache: final flush->invalidate
mm: cleancache: update to match akpm frontswap feedback
mm: frontswap: config and doc files
mm: frontswap: core frontswap functionality
mm: frontswap: core swap subsystem hooks and headers
mm: frontswap: add frontswap header file
zcache-main: switch to lz4 as default
zcache-main.c: use MACRO define instead of hardcoded default of lzo
staging: zcache: crypto API support
stweaks: clean-up and organization
Revert "lib: add generic strnlen_user() function"
Revert "ARM: 7449/1: use generic strnlen_user and strncpy_from_user
Revert "sync: allow async waits to be canceled"
Update timed_gpio from Linux 3.8
Update Android logger from Linux 3.8
ARM: mutex: use generic atomic_dec-based implementation for ARMv6+
slub: fix a possible memory leak
mach-u1: Decreased LCD PowerOn delay
ARMv7: Flush the vectors page using the base address
[PATCH 2/3] Optimize copy_page for modern ARM platforms
ARM: 7449/1: use generic strnlen_user and strncpy_from_user functions
ARM: 7746/1: mm: lazy cache flushing on non-mapped pages
ARM: keep __my_cpu_offset consistent with generic one
ARM: implement optimized percpu variable access
mm: remove compressed copy from zram in-memory
Gustavo_s schrieb:should be fixed in 22/01 release, i'll upload them soon
my desktop screen burned this weekend, until the new screen arrives (1 week) i won't be compiling, it took me more than 1 hour to compile the kernels on a 2gb ram, dual core notebook, and that is because i installed my solid state drive on it, if it was a HDD it would have taken around 2 or 3 hours i think(my desktop takes 2 or 3 minutes)
22/01 version brings a lot of changes on stweaks, merged cpu voltage tab with cpu tab, moved i/o schedulers to the new "file system" tab, tabs order is now:
[CPU] [GPU] [SCREEN] [SOUND] [BLN] [MEMORY] [FILE SYSTEM] [TWEAKS] [MISC]
also added a lot of changes and optimizations (check git)
i'm surprised with the download count, 16/01 version, including all kernels, was downloaded 2350 times
meanwhile, until my screen arrives, i will make some pools asking people's favorite governors/schedulers :good:
