[AOSP-KERNEL][JB][4.2/4.3] *21.06.2013* KangBang Kernel
  • 210 Antworten
beicuxhaven
beicuxhaven
Ehrenmitglied
10.437
FÜR 4.2 und 4.3 based ROMs
aber ACHTUNG!!!
2 Versionen!!!
Die V2.0 ist ausschließlich für 4.3 ROMs!!!
V1.3 für 4.2 ROMs!!!
CHANGELOG FOR v2.0
  • Made for Android 4.3(i dont recommend trying on 4.2)
  • Swteaks support!(thanks to gokhanmoral and gustavoss)
  • zzmoove v0.7
  • Sound amplification(thanks myfluxi) upto 20 decibels
  • CWM updated to v 6.0.37
  • All selinux features and AIO enabled
  • Compiled with -fno-pic -munaligned-access
  • Updated to linux 3.0.90 from korg
CHANGELOG FOR v1.3
  • Linux 3.0.82
  • Replace normal BLN with BLNWW(no more wakelocks,but static led)
  • Port gokhanmoral/dorimanx touchkey driver
  • Fix led_disable function,broken in previous release
  • Merge modem interface from smdk4210 kernel for better battery (cm upstream)
  • Updates to drivers/base/sync.c and sw_sync from android linux 3.0 upstream
  • Update zzmoove to v0.5
  • Tune zzmoove for our device
  • CIFS module support(requested by user)
  • add frandom driver(requested by user)
  • Updates to block from android linux 3.0 upstream
  • Revert "SMP: Update secondary cpu boot phase routine"
  • Samsung i9300 Update 10
  • Improve touch sensitivity
  • Introduce timer slack controller
  • Remove some debugging
v1.2
* Update to Linux 3.0.81
* Add BLN(Back Light Notification) function
* cpufreq: Add zzmoove v0.4
* Compile with GCC 4.7
* remove -fgraphite and loop optimizations and optimize modules
* Update row I/O scheduler to latest from CodeAurora
* Enable Swap and Zram(as requested by a user)
* Upstream patches for zram
* Change compression method for zImage,quicker boot
* CPU hotplug, writeback: Don't call writeback_set_ratelimit() too often
* ARM: vmlinux.lds.S: do not hardcode cacheline size as 32 bytes
* ARM: vmlinux.lds.S: align the exception fixup table to a 4-byte boundary
* block: Add support for reinsert a dispatched req
* block: Add API for urgent request handling
* block: add support for Linux 3.0.x for reinsert a dispatched req
* cpufreq: Make sure the cpufreq notifier is called last[arighi]
* Fix up freqs below 200 Mhz
v1.1
  • block: Add Zen I/O Scheduler
  • Makefile: Compile with -finline-functions -ffast-math -mtune=cortex-a9 -mfpu=neon -march=armv7-a
  • pegasusq: Kang from Siyah Kernel
  • bcmdhd: Enable Ad-Hoc (IBSS) mode
  • fs/dyn_fsync: check dyn fsync control's active prior to performing fsync ops
  • Dynamic Fsync : force flush if kernel panic or rebooting
  • staging: android: lowmemorykiller: Change default debug_level to 1
  • staging: android: lowmemorykiller: well-marked debug print
  • dynamic fsync: favor true case since most will be using this feature
  • irq: Set CPU affinity as soon as the irq thread is created
  • f_fs: ffs_func_free: cleanup requests allocated by autoconfig
  • hrtimer: Consider preemption when migrating hrtimer cpu_bases
  • hrtimer: Prevent enqueue of hrtimer on dead CPU
  • ipv4: save cpu cycles from check_leaf() - Backport from linux 3.8
  • network speed tweak
  • AIO: Don't plug the I/O queue in do_io_submit()
  • tmpfs: fix mempolicy object leaks
  • ARM: Add optimised swahb32() byteswap helper for v6 and above
  • SCHEDULER: Autogroup patch group by current user android UID
  • ARM: net: JIT compiler for packet filters
  • ARM/mm: drop GFP_COMP for dma_alloc_coherent
  • ARM: cache: assume 64-byte L1 cachelines for ARMv7 CPUs
  • timer: optimize apply_slack()
  • ARM: spinlock: use ticket algorithm for ARMv6+ locking implementation
  • arm/crypto: Add optimized AES and SHA1 routines
  • currentwidget support based on Entropy512's commit in his GB kernel
  • increase VM_MAX_READAHEAD to 1024
  • mmc: use really long write timeout to deal with crappy cards
  • slicing-by-8 algorithm for crc32 and crc32c
  • ext4: fixup 64-bit divides in 3.0-stable backport of upstream fix
  • update Android logger,timer_gpio and lowmemorykiller from Linux 3.8
  • arch:arm: Compile with -pipe
V1
Updated to Linux 3.0.80
  • 18 Step cpu frequency(25 Mhz to 1600 Mhz) and CPU Undervolt support
  • Removed debugging(Like sec_debug,cgroup_debug,stand-hotplug debug)
  • lib/string: use glibc version
  • lib/sha1: use the git implementation of SHA-1
  • lib/sha1.c: quiet sparse noise about symbol not declared
  • arm: remove "optimized" SHA1 routines
  • arm: remove stale export of 'sha_transform'
  • fs/dyn_sync_cntrl: dynamic sync control
  • tcp: Proportional Rate Reduction for TCP
  • mutex: dynamically disable mutex spinning at high load
  • slub.c: little tweak for performance improvements
  • kernel: power: prevent DVFS_LOCK_ID_USER lock for min and max frequency
  • block: sio and deadline tweaks
  • lib/memcopy: use glibc version
  • various compiler optimizations,and compiled with linaro toolchain
  • ARM: 7011/1: Add ARM cpu topology definition
  • sched: Ensure cpu_power periodic update
  • ARM: cpu topology: Enable ARCH_POWER
  • ARM: topology: save cpu id of each core
  • ARM: topology: Update topology according to current sched_mc mode
  • ARM: 7182/1: ARM cpu topology: fix warning
  • ARM: topology: Add a cpu_power function
  • ARM: topology: Add a topology update notification
  • ARM: cpu topology: Add asym topology flag for using cpu0 1st
  • ARM: cpu topology: add debugfs
  • cpupower: update the cpu_power according to cpu load
  • sched: use cpu capacity to decide if a ILB is needed
  • sched/nohz: Rewrite, fix and add more accurate load-avg computation
  • sched: Add missing call to calc_load_exit_idle()
  • Optimized ARM RWSEM algorithm
  • ARM: decompressor: Enable unaligned memory access for v6 and above
  • lib/lzo: Update LZO compression to current upstream version
Reaktionen: Trucker1109, ui_3k1, antsa und 14 andere
Rennt wie Sau :D:thumbup:
Allerdings ist die Optik gewöhnungsbedürftig
Greetz
SlimBean-b6|KangBang-v1|i9100¬Tapa2
Reaktionen: beicuxhaven
Na endlich mal wieder ein neuer 4.2 Kernel (AOSP) für das S2. Gleich mal probieren!
Hab denn a mal drauf zum testen ma schauen wegen ram und freezes oda sod ob was auftaucht.. aber bis jetz rennt der voll
Reaktionen: steuerboy und beicuxhaven
Greetz
Wenn er funktioniert und nicht so viele Probleme auftreten, dann ist die Optik doch erst mal egal:scared:
Der ursprüngliche Beitrag von 13:47 Uhr wurde um 13:49 Uhr ergänzt:
BLN und UV/OC sollen folgen...
Habe ihn jetzt 3 Stunden drauf, Läuft super, Akku auch sehr gut.
Die Grafik stört mich doch ein wenig.. und mir fehlt BLN.:crying:
Ich habe bis jetzt nichts Negatives bemerkt - bei mir in Verbindung mit SlimBean Bd.6. Bin sehr überrascht, wie gut die V1 läuft. Lasse diese Kombination erst mal drauf.
BLN wird bei den nächsten Updates - lt. Dev. wohl dabeisein "Not supported yet,but I plan to add bln and GPU oc/UV later". :thumbup:
Der Dev sollte bloß nicht so viel Features aufnehmen. So eine Art Speedmod für AOSP wär top ;)
Sent from my GT-I91000 using german Tapatalk 4
Läuft bei mir auch in Verbindung mit slim Bean V6 ... Und das hervoragend
Der Kernel läuft echt gut, bei Antutu auf Anhieb über 10600 Punkte, im zweiten Durchlauf 10717 (alles Standard gelassen). Nur noch BLNWW und GPU-UV und ich bin zufrieden :D.
Es wird gearbeitet :
sakindia123 schrieb:
Changelog for v1.1[WIP]
_____
Ist bei euch die Grafik nun auch anders oder nur bei "zuviel" & mir?
Greetz
Reaktionen: Bernd82 und beicuxhaven
Ich habe mir ihn auch gerade aufgespielt.
Der erste Eindruck nach 15min ist TOP. Mal sehen, was der Akku die nächsten Tage über so macht.
Sehr flüssig. Das Recovery finde eich auch ziemlich cool.
Was ich mir noch wünsche:
- BLN (kommt ja wohl noch)
- Dass ich die USB-Ladespannung anheben kann (Akku geht im Auto beim navigieren sonst leer)
Was ich nicht unbedingt brauche:
- Viel zu viele Optionen wie bei beim Dorimanx
- Eine App für die Einstellungen (Recovery reicht)
Titel und Post 1 angepasst. Das geht jetzt hier ja jetzt wohl richtig los. Cool.
Warten wir auf den Download..
Reaktionen: leechseed
Schade nur, dass Sammy-ROMs nicht unterstützt werden :(
Dafür gibt es für Sammy ROMs noch genügend andere Kernels ;) Ich sag nur Apollo. Gönnt den AOSP'lern doch auch mal was :p
:scared:
Der ursprüngliche Beitrag von 11:35 Uhr wurde um 11:36 Uhr ergänzt:
Im Ernst, ich hoffe, dass er besser läuft als die Anderen.
Bin auch fro das sich mal jemand aufs wesentliche konzentriert - AOSP 4.2 :D
Nun hat der Dev (sakindia123) sogar von CM auf Slim gewechselt, perfekte Kombi:thumbup: war schon am überlegen ob ich Dorimanxs Kombi nutze, aber ne etz bleib ich erstmal hier:)
Achja nochmal: Ist bei euch die Grafik nun auch anders oder nur bei "zuviel" & mir?:confused:
Btw Tapa & AH haben wohl ein Signatur Problem :what: zumindest bei mir:o
Keine Änderung der Grafik bei mir.
Hast du mal unter "Bildschirm" nachgeschaut, ob bei mDNle was verstellt ist?
Sonst stell mal das Szenario auf UI und den Modus auf Standard.
Bzw gibt es da wohl jetzt auch bei einigen Roms die Auswahl "Cyanogenmod"...
Einfach mal testen. :)
Das wars Danke :D
Hatte da nie was verstellt, war aber auf Szenario: Kamera (Standard) & Modus: Standard. Werd mir etz mal das beste für mich rauspicken.
Hätte man eig selbt drauf kommen können :banghead:
/edit
Neben BLN kommt auch der Stweaks support, speziell der Screen Tab wird/ist für mich wichtig - es entwickelt sich zu meinem neuen Traum Kernel :p
j1gga84
j1gga84
j1gga84
Bernd82
  • Umfrage
  • Bernd82
->TopAZ<-
->TopAZ<-
Androidflash
firemaker911
firemaker911
