Glatzi84
Dauer-User
- 601
Hier findet ihr beide Mackay Kernel von kasper_h für JB 4.1 und JB 4.2
Downloads,Changelog und Original Verlinkung findet ihr in dem passenden Kernel Bereich, wenn ihr auf Text anzeigen klickt.
Original Thread auf XDA
Basierend auf Mackays CM10.1 Kernel
Changelog 0.333 compared to previous release (0.332)
-Updated CWM to 6.0.3.3
-Updated to linux v3.0.85
-Merged upstream android-linux-3.0
On 2.7.0+ Mackay ROMs, BLN/recovery/navbar can be activated in Mackay settings*
On other roms, install the kernel, reboot, open /data/local/mackay/bln/recovery/navbar and change the 0 for 1. Then reboot:
bln (set to 1) BLN will be activated
recovery (set to 1) CWM will be activated
navbar (set to 1) navbar will be activated
All features compared to stock kernel:
Features:
-build using Linaro toolchain
-O3 optimization
-updated to linux kernel version 3.0.77
-XZ compression of kernel & initramfs
-396MB RAM
-SIO scheduler
-BFQv5 scheduler (with upstream improvements)
-ROW scheduler (tweaked, default scheduler)
-many improvements to IO schedulers in general
-Deadline tuning (thanks to DerTeufel)
-Ondemand tuned (default governor)
-SmartassV2 governor
-Interactive governor (updated to android 3.4 code + fixes)
-Wheatley & Lulzactive governors
-Conservative tuned
-Call volume hack (use Settings>Mackay Settings* to set volumes)
-Reduced battery polling interval
-Fast charge (activate through Settings>Advanced Settings* or the QuickCharge toggle in MackayROM)
-WiFi PM_FAST mode selection (activate using Settings>Mackay Settings*)
-Battery life extender (set through Settings>Mackay Settings*)
-CustomVoltage (set using NSTools)
-BLN (can be enabled through Settings>Mackay Settings*)
-USB OTG support (needs external power supply)
-1100-1400MHz OC steps
-Custom kernel splash (Thanks to Malcho)
-Updated charging logo to match open charger
-Disabled swap & zram
-Improve memcopy/memmove
-Improve the performance of memcpy and memmove
-Kill task closest in size to memory needed to free
-LOAD_FREQ (4*HZ+61) avoids loadavg Moire
-Entropy tweaks: Russell: Sources of Randomness for Userspace [LWN.net]
-backport CPUIDLE from 3.5
-arm/crypto: Add optimized AES and SHA1 routines
-Unaligned CPU access
-Updates to binder
-Improvements to RWSEM code
-Improvements to binder code
-Improvements to tmpfs
-Added frandom (much faster random number generator)
-Updated to lowmemorykiller with PID whitelist (thanks to stratosk)
*Settings>Mackay Settings only available with Mackay ROM 2.7.0+
*also available through the Galaxy S & Mackay app in the launcher
bootable/recovery:
-Mackay recovery (based on CWM 6.0.3.1 & TWRP 2.5.0.0)
CWM:
-Clear NSTools settings
-Clear init.d settings
-Show battery status in recovery
-Aroma FileManager
-Include using soft keys to navigate the menu (thanks fishears for the idea)
-Enable holding keys for repeated presses
-Themed orange
TWRP:
-Themed orange
-Run recovery-apps (zip files should be present in /system/mackay, launch them through advanced->run app)
Downloadable with CMC & voodoo colour:
rootaxbox.no-ip.org - /kasper_h/kernels/JB42/
Source code: https://github.com/kasperhettinga/sa...s/mackay-cm101
This is a freshly started project. Ideas for improvements/additions are welcome but:
1. I try to stay close to stock
2. The time I spend on features depends on how much I like them myself
Credits:
-teamhacksung/pawitp for making CyanogenMod work on our ancient phone
-stratosk/DerTeufel/Mialwe for the inspiration I got from their kernels
-rootax for providing a high-speed server for high quality downloads
Download (TWO flavours can be download: CMC=CM stock colour or VC=Voodoo Colour
For those who want to theme it even further, Bejda made a Mackay splash screen!
http://forum.xda-developers.com/show....php?t=2214468
For those who want to theme TWRP (or simply get rid of the orange
), erpurohit made a TWRP theme:
http://forum.xda-developers.com/show....php?t=2262937
This version can only be used on JB4.2-based ROMs
Download
Features:
-O3 optimization
-396MB RAM
-SIO scheduler
-Conservative tuned
-Updates to binder
bootable/recovery:
CWM:
-Aroma FileManager
-Themed orange
TWRP:
-Themed orange
Credits:
Download
Basierend auf Pawtip CM10 Kernel
Stock Kernel mit einpaar zusätzlichen Funktionen.
Changelog
Kernel:
-Updated to linux kernel 3.0.71
-Combined BLN & CMLED in one kernel*
-TouchWake
-Improved OnDemand scheduler (thanks to stratosk)
*To set BLN:
-install the kernel
-reboot
-open /data/local/mackay/bln and change the 0 for 1.
-reboot: BLN will be activated
Mackay kernel 0.199Final:
-updated to linux kernel version 3.0.71
-396MB RAM
-SIO scheduler
-Wheatley governor
-Conservative tuned
-Interactive governor (default - updated to android 3.4 code + fixes)
-Call volume hack (using Settings>Advanced Settings* to set volumes)
-WiFi PM_FAST mode selection (activate using Settings>Advanced Settings*)
-Battery life extender (set through Settings>Advanced Settings*)
Mackay recovery (based on CWM 6.0.2.7)
Remove wipe battery function
Add reboot menu
fix default backup format selection menu
Aroma FileManager
-Four flavours: stock-LED/stock-colours, stock-LED/voodoo-volour, BLN/stock-colours, BLN/voodoo-colour
Source code: https://github.com/kasperhettinga/sa...es/tree/mackay
Credits:
Feature-Vorschläge für die neuen Versionen werden vom Entwickler gerne gesehen, aber mit dem Einwand, dass er so nah wie möglich an Stock bleiben will.
Download:
Mackay Kernel 0.199final
Changelog
Kernel:
-TouchWake
*To set BLN:
-install the kernel
-reboot
-396MB RAM
-SIO scheduler
-Wheatley governor
-Conservative tuned
Add reboot menu
Aroma FileManager
Credits:
Download:
