beicuxhaven
Ehrenmitglied
- 10.437
genau dieser hier, der 1.1.3
DerTeufel1980 schrieb:I have started to patch all the changes from hellybean kernel into this one, but it's too much to finish it today.
DerTeufel1980 schrieb:i just have started to upload the kernels.
changes since 1.1.0:
- use 200 mhz if gpu is active, but also 100 mhz if not (if you want the cpu to always run at higher than 100, you have to disbale lock_scaling_min at /sys/devices/system/cpu/cpu0/cpufreq/lock_scaling_min)
- linux 3.0.40
- row i/o scheduler from linux 3.5
- tunings to deadline i/o scheduler
- switch do_fsync() to fget_light() (less overhead)
- optimized AES and SHA1 routines
- added Wheatley governor, thx to kasper_h
- compiled new bigmem libs for latest hw_composer changes
- Increase dpram semaphore wait timeout (cdma modem fix by Efpophis)
- disabled twrp recovery for now (not working with jellybean)
- compiled with "old" toolchain for now (at least for me, there was no performance difference, but more issues)
- new cm 10 partition layout (use onenand for /data)
kernels can be found here: http://rootaxbox.no-ip.org/derteufel/jellybean/
until i move them to the correct folder tomorrow
susdiehl schrieb:So hab den Kernel grad auch mal draufgemacht. Nutze CM10,und es läuft gut. Noch ne Frage hab ich : Gibt's ne App mit der ich noch weitere Einstellungen vornehmen kann?
Gesendet von meinem GT-I9000 mit Tapatalk 2
beicuxhaven schrieb:du hast bestimmt save init.d vergessen?
im kernek config app links unten auf FILE... dann odebn SAVE INIT.D
