CarMan
einfach drüber
fireworkerfp schrieb:laufen die apps denn noch flüssig und schnell bei 800 MHz?
- soll heißen: ja, tun sie!jna schrieb:und es ist immer noch recht flott
#!/system/bin/sh
#Profiles
#Configure Settings Profile
#Recommended(HM)
#Execute and copy scripts
mkdir /data/SemaphoreScripts
rm -f /data/SemaphoreScripts/*
#Try kernel scripts first
# Recommended kernel features
cp /res/scripts/S05enable_oc_1000_default /data/SemaphoreScripts
cp /res/scripts/S06enable_uv_0_default /data/SemaphoreScripts
cp /res/scripts/S10enable_gov_ondemand_default /data/SemaphoreScripts
cp /res/scripts/S15enable_sched_sio /data/SemaphoreScripts
cp /res/scripts/S20disable_netfilter /data/SemaphoreScripts
cp /res/scripts/S25enable_sm_neutral /data/SemaphoreScripts
cp /res/scripts/S30disable_logger /data/SemaphoreScripts
cp /res/scripts/S35disable_tun /data/SemaphoreScripts
cp /res/scripts/S40disable_cifs /data/SemaphoreScripts
# Recommended addons
cp /res/scripts/addons/S60disable_cache_50 /data/SemaphoreScripts
cp /res/scripts/addons/S62disable_ipv6_privacy /data/SemaphoreScripts
cp /res/scripts/addons/S70disable_kernel_sched /data/SemaphoreScripts
cp /res/scripts/addons/S72enable_vmdirty /data/SemaphoreScripts
cp /res/scripts/addons/S74enable_lmk_64mb /data/SemaphoreScripts
cp /res/scripts/addons/S76enable_sdcard_0256kb /data/SemaphoreScripts
cp /res/scripts/addons/S78enable_touchscreen_1 /data/SemaphoreScripts
#Try sdcard second
cp /mnt/sdcard/SemaphoreScripts/S05enable_oc_1000_default /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S06enable_uv_0_default /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S10enable_gov_ondemand_default /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S15enable_sched_sio /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S20disable_netfilter /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S25enable_sm_neutral /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S30disable_logger /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S35disable_tun /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S40disable_cifs /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S60disable_cache_50 /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S62disable_ipv6_privacy /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S70disable_kernel_sched /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S72enable_vmdirty /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S74enable_lmk_64mb /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S76enable_sdcard_0256kb /data/SemaphoreScripts
cp /mnt/sdcard/SemaphoreScripts/S78enable_touchscreen_1 /data/SemaphoreScripts
chmod 755 /data/SemaphoreScripts/*
busybox run-parts /data/SemaphoreScripts
rm -f /data/SemaphoreScripts/*disable*
rm -f /data/SemaphoreScripts/*enable*default*
rm -f /data/SemaphoreScripts/*enable*neutral*
rm -f /data/SemaphoreScripts/*enable*standard*
# Clean and configure init.d
busybox mount -o remount,rw /system
rm -f /system/etc/init.d/*enable*
cp /data/SemaphoreScripts/* /system/etc/init.d
busybox mount -o remount,ro /system
rm -rf /data/SemaphoreScripts
jna schrieb:Oh, es wird Zeit, den Startpost zu ergänzen...
