Muppi
Enthusiast
- 2.807
Neuer Mackay Kernel von kasper_h für JB 4.3 ROMs
Alles Weitere (Download, Changelog und XDA-Thread):
[JB 4.3][KERNEL][CWM/TWRP/SwitchSD]Mackay kernel 0.514 (14-Oct-2013) - xda-developers
Separate bigmem libs for other kernels:
http://forum.xda-developers.com/show...0&postcount=16
Changelog 0.514
-Updated to v3.0.100
All features compared to stock kernel:
Features:
-Build using the Cortax-A8 optimized Linaro 4.7.4 toolchain of Christopher83: http://forum.xda-developers.com/show....php?t=2098133
-Christopher86's cortex-A8 optimized Linaro toolchain (September version)
-O3 optimization
-updated to linux kernel version 3.0.98
-SLQB memory allocator (default, should be slightly faster)
-XZ compression of kernel & initramfs
-395MB RAM
-SIO scheduler
-Added Lagfree governor
-ROW scheduler (tweaked, default scheduler)
-FIOPS scheduler (tweaked)
-395MB RAM
-many improvements to IO schedulers in general
-Deadline tuning (thanks to DerTeufel)
-Ondemand tuned (default governor)
-SmartassV2 governor
-Interactive governor (updated to android 3.4 code + fixes)
-Wheatley & Lulzactive governors
-Conservative tuned
-Call volume hack (use Settings>Mackay Settings* to set volumes)
-Reduced battery polling interval
-Fast charge (activate through Settings>Advanced Settings* or the QuickCharge toggle in MackayROM)
-WiFi PM_FAST mode selection (activate using Settings>Mackay Settings*)
-Battery life extender (set through Settings>Mackay Settings*)
-CustomVoltage (set using NSTools)
-BLN (can be enabled through Settings>Mackay Settings*)
-USB OTG support (needs external power supply)
-1100-1400MHz OC steps
-Custom kernel splash (Thanks to Malcho)
-Updated charging logo to match open charger
-Disabled swap & zram
-Improve memcopy/memmove
-Improve the performance of memcpy and memmove
-Kill task closest in size to memory needed to free
-LOAD_FREQ (4*HZ+61) avoids loadavg Moire
-Entropy tweaks: Russell: Sources of Randomness for Userspace [LWN.net]
-backport CPUIDLE from 3.5
-arm/crypto: Add optimized AES and SHA1 routines
-Unaligned CPU access
-Updates to binder
-Improvements to RWSEM code
-Improvements to binder code
-Improvements to tmpfs
-Added frandom (much faster random number generator)
-Updated to lowmemorykiller with PID whitelist (thanks to stratosk)
-Updated wifi driver to 5.90.195.114
-Updated GPU driver to DDK 1.8@2198402
-Proportional Rate Reduction for TCP
-Introduce timer slack controller
*Settings>Mackay Settings only available with Mackay ROM 3.x.x (to be released soon)
*also available through the Galaxy S & Mackay app in the launcher
On other roms, install the kernel, reboot, open /data/local/mackay/bln/recovery/navbar and change the 0 for 1. Then reboot:
bln (set to 1) BLN will be activated
navbar (set to 1) navbar will be activated
As an alternative, Bejda developed a script for Mackay settings:
http://forum.xda-developers.com/show...&postcount=953
bootable/recovery:
-Mackay recovery (based on TWRP 2.6.3.0)
TWRP:
-Themed orange
-Run recovery-apps (zip files should be present in /system/mackay, launch them through advanced->run app)
Source code: https://github.com/kasperhettinga/sa...s/mackay-cm102
This is a freshly started project. Ideas for improvements/additions are welcome but:
1. I try to stay close to stock
2. The time I spend on features depends on how much I like them myself
Credits:
-teamhacksung/pawitp for making CyanogenMod work on our ancient phone
-stratosk/DerTeufel/Mialwe for the inspiration I got from their kernels
-rootax for providing a high-speed server for high quality downloads
Downloadable with CMC & voodoo colour:
rootaxbox.no-ip.org - /kasper_h/kernels/JB43/
For those who want to theme it even further, Bejda made a Mackay splash screen!
http://forum.xda-developers.com/show....php?t=2214468
This version can only be used on JB4.3-based ROMs
Kernel for switching internal & external SD
Because vold.fstab is no longer used and has been integrated in fstab.aries (which can only be changed before compiling the kernel, as it ends up in the ramdisk), I made a special kernel version with switched SD cards:
http://rootaxbox.no-ip.org/kasper_h/...JB43/switchSD/
Changelog 0.514
Features:
-O3 optimization
-395MB RAM
-SIO scheduler
-395MB RAM
-Conservative tuned
-Updates to binder
bootable/recovery:
TWRP:
-Themed orange
Credits:
