Datenbank - Diskussionsplattform Kernel - für [AOSP] Jelly Bean & ICS/MIUI V4
  • 193 Antworten
Welchen Kernel favorisiert Ihr?
  • DerTeufel
    Stimmen: 116 43,0%
  • TK-Glitch
    Stimmen: 35 13,0%
  • Grooby
    Stimmen: 2 0,7%
  • Stockkernel von Pawitp
    Stimmen: 19 7,0%
  • Zacharias
    Stimmen: 16 5,9%
  • favorisiere keinen Kernel
    Stimmen: 32 11,9%
  • Nushor's
    Stimmen: 3 1,1%
  • Semaphore ICS
    Stimmen: 47 17,4%
  • Umfrageteilnehmer
    270
[Kernel][ICS] Devil2_0.62 [02/04/12]-BLN-Touchwake-USB_Host-LiveOC-DeepIdle2
Changelog:
03.04.2012:
no time for detailed changelog...have to sleep..
stock mem kernel has 379 mb ram
"slim" (XL) kernel comes with 390 mb
XL_BM is coming with 402 mb ram, but breaking 720p
while flashing the kernel, the modded rom files are also flashed, so you don't need to flash a new rom to get 379 or 390 mb
added new frequency: 1080 mhz (1100 does not like live_oc)
fixed SmartassV2 for live_oc (after changing live_oc value, you have to change the smartass values, too, but then they automatically apply to the live_oc value (although you can also select 800 mhz in nstools (for example)
also implemented touch recovery with custom devil menu (for some reason it takes a few seconds to load the first time)
more to come tomorrow...
Reaktionen: FCB-Fan
Devil2_0.64 [05/04/12]-BLN-Touchwake-USB_Host-LiveOC-DeepIdle2
133LR - 2012/04/07 Online - steht in Post 1 zum Download bereit
Change Log
- changed name: MNICS-<buildnr>[LR (large RAM for 386Mb)]
- kernel: 5 frequencies, switchable maxfreq 1/1.128Ghz
- kernel: adjusted smooth conserv. triggers, mp3@100Mhz again
- kernel: fixed internal divider bug, thanks to theDevil1980 for the hint
- kernel: removed old recovery backup (-700Kb)
- CWM: added manual zipalign option
- CWM: moved init.d/overclocking/Logcat toggles to CWM
- app: service for missed calls BLN - app: cleanup
Neu dazu gekommene Kernels /12-04-08
stehen in Post 1 zum Download bereit
Change Log
143LR - 2012/04/08
- app: updated to version 1.4
- adjusted default min_brightness from 25 to 20 (stock?)
- app: fixed bug with old nightmode sysfs setting at startup
142LR - 2012/04/08
- kernel: fix green screen on some occasions
141LR - 2012/04/08
- app: added missed call service toggle (reboot required)
- app: updated help file
- initramfs: fixed issues with some busyboxes/$PATH (SlimICS, grep not found)
[KERNELS][ICS][I9000] The ICS Kernel Benchmarking Project -Update: ICS 4.0.4
Goal of this little project is to dispel myths and hearsay and trying to assess the elusive performance of custom kernels for our beloved SGS I9000.
So far this has proven quite challenging as there is no single good benchmark on Android (yet):
  • a lot of people have been misled by ridiculous Quadrant scores: ridiculous because, with some small tweaks which do not affect real performance in any way, shape or form, it is possible to boost the Quadrant score by factor 3x.
    You're free to believe that your SGS I9000 which scores 3000+ on Quadrant is faster than a SGS II, but then please leave this thread and move on.
  • some kernels may seem smooth with some games, and get high scores on some synthetic benchmark, yet the UI appears "laggy" and stutters a lot in comparison to other kernels which score lower on the same benchmark
  • some popular benchmarks give results with unacceptably low reproducibility, i.e. if you run them multiple times without changing a thing on your system, you get scores varying by 50% of more, in a completely random fashion
  • most popular benchmarks do not measure or take into account multitasking and CPU contention with other applications, yet on a typical usage one has background tasks such as the media scanner or synchronization which kick in often and unpredictably
So this will be mostly a work in progress, i'm testing several benchmarks and several kernels in multiple combinations, trying to analyze which benchmarks offer certain criteria which make them useful, namely:
  • Reproducibility of results: running the same tests multiple times, should result in a very small variance of the final score
  • Performance separation: benchmarks which are too "synthetic" and show only a dependency on clock speed are not useful to discriminate "fast" kernels from "slow" kernels
  • Performance representation: we all know when a kernel "looks" or "feels" fast or smooth. If a benchmarks shows you that a "laggy" kernel scores higher than a fast and responsive one, it's likely that the benchmark is not well designed
I'll work more on this thread explaining my (current) choice of tests and what they're good for.
But for now i'll just post a link to the summary table, and give a brief recommendation concerning popular ICS kernels; recommendation which i'll explain in the coming days.
Base ROM:
Slim ICS 2.8
(because is fast, smooth and has the least background stuff of all ICS ROMs which i tested)
Test Conditions:
Whenever possible, i tried to overclock the kernels to 1.2GHz which most / all phones should have no trouble achieving.
In case of Semaphore i had to use the bus / live overclock but it wasn't fully stable at 1.2GHz on my phone so i ran most of the tests at 1.14GHz.
Tested Kernels:
Stock Teamhacksung V17
Devil 1.1.6b BFS
Devil 1.1.6b CFS
Icy Glitch V14 b
Semaphore ICS 0.9.5b
Recommendation:
Devil 1.1.6b CFS, Icy Glitch V14b (with SmartassV2 and FIOPS), and Midnight ICS (with a tweaked Conservative) are trading blows for the fastest kernel.
At the time of testing, Midnight is slightly worse in terms of overclocking though, apparently due to different voltages, also it doesn't allow overclocking beyond 1.2GHz.
But what's interesting is that it achieves great performance while using a tweaked conservative governor which supposedly gives good battery life (i can't verify this claim).
Devil 1.1.6b BFS is good but obviously inferior to its CFS brother.
Semaphore has the lowest cache and memory latency in the multithreaded test, it also has impressive sd card read speed and in general appears super responsive, but it's a bit worse in 3D gaming and especially it lacks "true" overclocking, "live overclocking" changes the bus clock and is way more unstable, in fact on my phone i couldn't run it stable at 1.2GHz.
All kernels are significantly faster than the stock teamhacksung's kernel, so you have no excuses not to upgrade to one of the popular custom kernels!
ICS 4.0.4
Started testing Android ICS 4.0.4 kernels on Slim ICS 3.2.
All tested kernels are "huge mem" versions with 380+MB of available RAM, without breaking video playback or 720p recording.
Summary:
  • the stock kernel from Teamhacksung is now a very respectable performer, unless you plan to overclock probably you don't need to install one of the other kernels
  • Semaphore appears the smoothest, and in 3D benchmarks is scoring the highest, although by a very slim margin
  • Midnight is still awesome and all around good kernel
Results table:
https://docs.google.com/spreadsheet/...FpJejFPWDh5S1E
Neue Umfrage
[OFFURL="https://www.android-hilfe.de/kernel-fuer-samsung-galaxy-s/226402-wecher-kernel-wird-von-euch-favorisiert.html"]Welcher Kernel wird von Euch favorisiert?[/OFFURL]
Hier finden dort keine Diskussionen statt - dient nur zur Transparenz!
Zur Auswahl stehen!
Midnight ICS - by mailwe / xda
Semaphore ICS - by stratosk / xda
Devil ICS - by derTeufel / android-hilfe.de
Icy Glitch by Tk-Glitch
Zur Transparenz kann dort gepostet werden
  • Welche Konfiguration
Rom:
Kernel:
Modem:
  • Welche Einstellungen habt Ihr vorgenommen?
App:
  • Screenshots gewünscht
Reaktionen: Radagast
upps...ich trottel
matze6989-albums-screenshots-picture2295-screenshot-2012-04-08-16-29-36.html
matze6989-albums-screenshots-picture2296-screenshot-2012-04-08-16-42-33.html
matze6989-albums-screenshots-picture2297-screenshot-2012-04-08-16-43-37.html
matze6989-albums-screenshots-picture2298-screenshot-2012-04-08-16-42-56.html
matze6989-albums-screenshots-picture2299-screenshot-2012-04-08-16-43-28.html
Besten Dank für dein Mitwirken
Kannst Du es nochmal in die Umfrage Posten
- steht in Post 1 zum Download bereit:
[KERNEL] Semaphore ICS 1.0.0
Change log
1.0.0 (09/04/2012)
- Touch Wake (thanks to Ezekeel)
- Vibrator intensity (thanks to Mialwe)
- Semaphore Script Manager application ICS themed (thanks to HM.Carbide)
- upstream fixes
- removed some stuff from kernel configuration
- Radio FM support as module
- remove kernel default script
- Ondemand: slight increased down differential ondemand
- battery polling interval to 10sec
- Some changes to compiler flags (thanks to Mialwe)
- fixed issue enable Wi-Fi hotspot twice after reboot (?)
- fixed bug ondemand sampling rate return to 10000 when awake even if user changed it (from 0.9.8)
- ondemand some optimization to sampling down momentum calculation (from 0.9.8)
- fixed bt rfkill script (from 0.9.8)
Variations:
Normal versions (for CM9 or ROMs without hugemem configuration)
1.0.0
- 345.2MB available RAM
1.0.0bm
- 357.4MB available RAM
- breaks 720p video recording
For Slim ROM or patched ROMs with hugemem configuration
1.0.0s
- 387.2MB available RAM
1.0.0sbm
- 399.4MB available RAM
[Kernel][ICS] Devil2_0.65 [10/04/12]-BLN-Touchwake-USB_Host-LiveOC-DeepIdle2
Devils Kernel von DerTeufel
10.04.2012:
- added vibrator intensity control (by mialwe), presets can be changend in recovery
- stock ram version now available (348 mb ram), XL (390 mb), XL_bm (402 mb)
- removed 1080 mhz freq for now
- small correction to touchwake
- small correction to selective live_oc (now the low freq really are not live_oc'ed)
to change the vibrator intensity on the fly, you have to do the following:
Reaktionen: FCB-Fan
Ich hoffe ich darf hier schreiben.. Kurze Frage:
Ich hatte Semaphore und habe gerade Midnight geflasht.. Davon auch noch Kernel Cleaning Script benutzt.. Nun ist aber im Menü immer noch die Semaphore-App drin. Wenn ich rein gehe ist zwar nichts, aber 1. ist das normal und 2. kann ich es löschen?
1 = ja
2 = ja
3 = das wars schon... ;)
SentFrom Tapatalk2 by ICS-I9K
[Kernel][ICS] Devil2_0.67 [13/04/12]-BLN-Touchwake-USB_Host-LiveOC-DeepIdle2
Changelog:
13.04.2012:
- updated wifi driver
- user interface to switch wifi mode (pm_fast better batterie, pm_max better signal)
echo 0 > sys/module/bcmdhd/parameters/uiFastWifi (pm_fast)
echo 1 > sys/module/bcmdhd/parameters/uiFastWifi (pm_max)
- user interface to disable fsync (this gives more performace, at the risk of data loss on a crash, taken from ezekeel, so it should be ok
), default is off, to be safe
echo 1 > /sys/devices/virtual/misc/fsynccontrol/fsync_enabled (fsync enabled)
echo 0 > /sys/devices/virtual/misc/fsynccontrol/fsync_enabled (fsync disabled)
to make this settings apply after reboot, select them from recovery --> devil --> misc
- fixed voodoo color kernels (these have the VC in their names)
Hat zufällig einer einen Tipp, wie man den Android OS bug mal zu leibe rücken kann? Bin etwas ratlos... das Ding hält ewig mein Handy wach. Bis zu 5 Stunden bei einer Akkuladung.
Bin aktuell auf AOKP Build 30 und Teufelkernel 0.64...
Was ist eigentlich Touchwake?
[Kernel][ICS] Devil2_0.67 b [14/04/12]-BLN-Touchwake-USB_Host-LiveOC-DeepIdle2
Changelog:
14.04.2012:
- new b versions (only stock ram) changend to 377 mb, VC version needs the 720p fix from my ftp server. cmc version already patched
Wie kann ich mit diesem Kernel BT komplett deaktivieren, wenn ich es nie nutze? Wäre echt cool, wenn mir das mal jemand verraten würde. :)
Test Version 1.0.1s - steht in Post 1 zum Download bereit!
New test version 1.0.1s (works on memory patched ROMs)
- updated SIO scheduler
- touch wake fix (from Ezekeel)
- touch wake fix enable again when proximity off (now should work always)
- cpufreq upstream fix
- cpufreq fix when max 800MHz (thanks to Mialwe, thanks to DerTeufel who pointed this out)
- cpufreq driver max freq to 800MHz when screen off
- ondemand sampling rate to 20000
- ondemand io_busy back to 0
In Post 1 zum Download bereit!
[KERNEL] Semaphore ICS 1.1.1
Change log
1.1.1 (28/04/2012)
- upstream updates
- updated initramfs
- Ondemand: smooth_ui tuner, CPU freq goes to max when touch the screen. Also sampling_down_momentum goes to max when touch the screen. (disabled by default, select from Semaphore app->Governors)
- Ondemand: bug fix sampling_down_max_momentum
- touch wake fixes (from Ezekeel)
Variations:
1.1.1
- 374.2MB
1.1.1bm
- 386.4
1.1.1s
- 387.2
1.1.1sbm
- 399.4
