Datenbank - Diskussionsplattform Kernel - für [AOSP] Jelly Bean & ICS/MIUI V4
  • 193 Antworten
Welchen Kernel favorisiert Ihr?
  • DerTeufel
    Stimmen: 116 43,0%
  • TK-Glitch
    Stimmen: 35 13,0%
  • Grooby
    Stimmen: 2 0,7%
  • Stockkernel von Pawitp
    Stimmen: 19 7,0%
  • Zacharias
    Stimmen: 16 5,9%
  • favorisiere keinen Kernel
    Stimmen: 32 11,9%
  • Nushor's
    Stimmen: 3 1,1%
  • Semaphore ICS
    Stimmen: 47 17,4%
  • Umfrageteilnehmer
    270
Bei DerTeufel hat sich wieder was getan: [Kernel][ICS] Devil3_1.0.0-Rc1
auch für Jelly Bean Roms einsetzbar!
[Kernel][JellyBean] Devil3_1.0.3b [25/07/12] - i9000 and i9000B
Changelog:
changelog 25.07.2012 part2:
- fixed cwm backup and restore for kernels without /datadata partition
changelog 25.07.2012:
- updated recovery (no "sdcard format"-bug anymore, external sd card is named correctly)
- vibrant: hopefully fixed froyo ril
- jellybean: galaxy s settings working now
Gelistet!
Devil Kernels von DerTeufel für Jelly Bean mit Archiv ICS
07/08/2012 12:59 120 Devil3_1.1.3_JellyBean_i9000 - Gelistet!
Post 2
[KERNEL][CM9][I9000] Mackay kernel 0.37
Thread By Developer: kasper_h / xda
Changelog:
1 August 2012 - version 0.37
Kernel is stock +
-Build with July-version of Linaro
-O3-optimization
-CWM6-based Mackay recovery
-Updated to linux kernel version 3.0.36 (thanks to trailblazerz)
-Adaptable vibration intensity (thanks to mialwe)*
-bigmem (384MB, combination of semaphore & kravind, 720p works with f4k patch)
-Bootloop detection (based on semaphore)
-Single initramfs (implementation based on work by stratosk/mialwe) - should reduce bootloops
-Call volume hack (use Advanced Settings to set volume)
-SIO (default scheduler)
-SmartassV2 (default governor)
-Wheatly governor
-Changed conservative/ondemand parameters
-Increased SD-card read/write speed under windows
-Reduced battery polling interval
-Custom kernel boot splash
*to adapt vibration intensity:
open terminal emulator and type:
$ su
# echo xxxxx > /sys/class/timed_output/vibrator/duty
xxxx can be any number between 0 (no vibration) and 40140 (max). 32000 is a fine compromise for me
Downloads:
Kernel zip:
https://dl.dropbox.com/u/69000552/Ma...ernel_0.37.zip
https://dl.dropbox.com/u/69000552/Ma...ernel_0.37.tar
http://forum.xda-developers.com/showthread.php?t=1778526
Neuer ICS Kernel
[Kernel][JB Devil3 1.0.5 - & Neu ICS Devil3_1.1.0] i9000 and i9000B [2-August-2012]
Post 2
[KERNEL] Semaphore JB 2.0.0b2 Online! [KLICK]
[KERNEL][CM9][I9000] Mackay kernel 0.41
[KLICK]
Neue JB Kernels
[FONT=&quot]
[/FONT]07/08/2012 12:59 120 Devil3_1.1.3_JellyBean_i9000_CFS_BLN_CMC_20120807. sha256sum
07/08/2012 13:02 6225920 Devil3_1.1.3_JellyBean_i9000_CFS_BLN_CMC_20120807. tar
07/08/2012 13:04 6519487 Devil3_1.1.3_JellyBean_i9000_CFS_BLN_CMC_20120807. zip
07/08/2012 13:02 119 Devil3_1.1.3_JellyBean_i9000_CFS_BLN_VC_20120807.s ha256sum
07/08/2012 13:04 6225920 Devil3_1.1.3_JellyBean_i9000_CFS_BLN_VC_20120807.t ar
07/08/2012 13:06 6519752 Devil3_1.1.3_JellyBean_i9000_CFS_BLN_VC_20120807.z ip
Post 2
Reaktionen: FCB-Fan
[JB][ROM]Mackay ROM 1.0.4 (30-August-2012)
Changelog 30-August-2012, version 1.0.4
-Mackay kernel 0.53: http://forum.xda-developers.com/show....php?t=1842324
-389MB RAM
-SIO scheduler (default)
-BFQ v4 (new version of BFQ optimized for flash devices - can be set through NSTools)
-SmartassV2 governor (default)
-Wheatley governor
-Ondemand/conservative tuned
-Adaptable vibration intensity (by setting /sys/class/timed_output/duty)
-Call volume hack (using Settings>Advanced to set volumes)
-Fast charge (module, active using NSTools)
-Battery life extender (active using NSTools)
-Faster bootanimation
-1000ms force close of apps on pressing back button
Downloads:
rootaxbox.no-ip.org - /kasper_h/roms/JB/
XDA File Server - For all your ANDROID ROMS! /Files/
Reaktionen: Trucker1109
Hallo Community, Ich stellen meine Arbeit für diesen Bereich ein.
Wie Ihr sicher schon an anderer Stelle gelesen habt, besitze Ich jetzt ein SGS III, daher dieser Schritt.
Bedanke Mich bei allen, die Mich Hier Unterstützt haben.
Der Beitrag kann geschlossen werden. Danke!
Reaktionen: FCB-Fan
