perog
Stamm-User
- 690
WICHTIGER HINWEIS:
Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg oder die Haftung für jegliche Beschädigungen an eurem Note 2.
Wenn ihr nicht sicher seid, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Daher flashen auf eigene Gefahr.
SaberKernel 7100
This Kernel Is Compatible with all TW/Samsung based JB ROMS for this device--- (Not AOSP)
READ, READ, READ before downloading, flashing, or posting questions
Not all phones are created equal meaning some phones will not handle Overclocking or Undervolting as well as others.
Features
Kernel Version 3.0.96
UC to 100
OC to 1960
UV Support
Added Support For 3rd Party OC apps---
Advanced Power Emulation
Default Scheduler= Zen
Default Governor= Pegasusq
Default boot set to 1600
Built using arm 4.4.3 toolchain
Ramdisk Mods to support Custom Boot Animations
Boeffla Sound Support
Touchwake
GPU Control
UC to 100
OC to 1960
UV Support
Touchwake
GPU Control
Github
In my GITHUB you can find my sources and code changes
Credits
Samsung for Official Source Code
Andreilux
Faux123
Cmenard
Simone 201
Gregkh
Sarcastillo
supercurio
Der Teufel
Ezeekel
ZaneZam
Yank
Andreilux
Faux123
Cmenard
Simone 201
Gregkh
Sarcastillo
supercurio
Der Teufel
Ezeekel
ZaneZam
Yank
Instructions
TWRP Recovery HIGHLY Recommended!
-Download Kernel
-Nandroid
-Flash Kernel
-Boot system and Feel The Force
-Nandroid
-Flash Kernel
Changelog
10|03
Upgrade to Linux 3.0.97
Revert of GPU edits to fix glitches in Graphics/reboots
Raise Voltages on 1960 for stability
Update zram_drv.c thanks to insanemal
9|26
Raised Max Clock Speed --1960
Edits to GPU Clocks and scaling for Max performance (while preserving battery at stock values)
New compression ADB Remount Enabled
9|26
9|18
Complete Rebuild from Updated Source
Zen default sched
Upgraded to 3.0.96
Fixed GPU freq scaling More voodoo code removal
Zen default sched
Upgraded to 3.0.96
9|11
Upgrade to Linux Version 3.0.95
Edits to GPU Voltage Allocation
Boeffla Sound Replaces Voodoo (by request)
Boeffla and Trickster apps now added with flash
Clean Up of Version
Remove Dirty in Version Description
USB Charging Rate Increased to match A/C rate
ZZmoove Updated to 7d
Fixed Memory/cache leak that was causing instability and poor battery
Clean Up of Version
8|28
I have been slacking on releasing kernels outside of my ROMs so this changelog is kind of a mess.
If you cannot follow the log please see my git for itemized changes
--Upraded to Linux 3.0.93
-- Added in exfat module source thanks to Faux123 and SORC
-- ZZMOOVE updated to v0.7 (ZaneZam/Yank)
-- LulzactiveQ added in (Gohkanmoral)
-- Upgraded to Linux 3.0.91
-- Wifi driver edit for reduce wakelock
-- All sources Merged!!
-- Upgraded to Linux 3.0.87
-- Added ZZMOOVE
---- zzmoove edited to support more frequencies
-- Edits to WIFI handling for less wakelock issues/performance
-- Some Peg gov Edits
-- Edit to I/O que
-- Edits to kernel/module.c in hopes of further work on exfat later on
-- Added ZZMOOVE
-- Edit to I/O que
7|2 --
Upgraded to Linux Version 3.0.84
New Under Clock Frequency --STABALIZED
- 100 mhz UC all set
---All testers have reported back as things being stable and most
have run it through intensive and reg use and no SOD at 100mhz low.
I believe the times of certain devices not liking the low step is over. Have Fun
6|24 --
Upgraded to Linux Version 3.0.83
2 Versions
--- One with UC for those who's chips dont mind
---One Stock Low end
New Under Clock Frequencies
- 120 mhz UC VERSION ONLY
Edits to Peg GOV in Both Versions
2 Versions
6|19 --
Upgraded to Linux Version 3.0.82
- 160 mhz
- 140 mhz
- 160 mhz
- 140 mhz
6|13 --
Complete Clean Rebuild from updated sources
Linux 3.0.81
ZRAM
Freq Voltage Edits
Compression Edits
Freq "Bleeding" fixed
Intelliplug/Ecomode
More Mali Edits
Dynamic Filesync
Linux 3.0.81
ZRAM
Freq Voltage Edits
Compression Edits
Intelliplug/Ecomode
More Mali Edits
Dynamic Filesync
5|05 --
Upgraded to Linux Version 3.0.76
GPU Handling is Back And Fixed
Touchscreeen Mods
TouchBoost Control Added
SetLocalversion Modification ( Just Shows differently in about)
More...
Touchscreeen Mods
More...
4|26 --
Upgraded to Linux Version 3.0.75
TouchWake Added (Control With TricksterMod)
Voltages/Voltage interface Fixed for Undervolting Compatibility
FlexRate Edits
Fsync Edits
IntelliPlug
FlexRate Edits
Fsync Edits
IntelliPlug
4|18 --
Upgraded to Linux Version 3.0.74
Edits to Freq/Voltage Handling
4|11 --
Upgraded to Linux Version 3.0.72
sysfys-helpers edit
double flexrate
Voltage control/UV voltage edits
Freq Edits
sysfys-helpers edit
double flexrate
Freq Edits
3|20 --
Upgraded to Linux Version 3.0.69
Etc
Etc
3|11 --
Voodo Sound Enabled
Upgraded to Linux Version 3.0.68
Voodo Sound Enabled
2|22 --
MHL Tv Out Audio Officially Fixed Damnit lol
Updated to Linux 3.0.64
2|15 --
Edit Frequencies
-OC to 1920
-Fix for CPU sticking Etc
-Removed GPU Edits From Last Version For Now
Edit Frequencies
-OC to 1920
2|6 --
Mali Rework
GPU Can Now Be Adjusted By 3rd Party App
Ramdisk Modifications
- Fixed Memory Swap
- Probable MHL Audio Fix
Edit to Module.c
Added Lazy Governor
Added BFQv5 Sched
Added V(R) Sched
Set ReadAhead to 1024
Fixed Wonky Frequencies: No Issues With 3rd Party Apps Holding Freq
Mali Rework
- Fixed Memory Swap
Edit to Module.c
Added Lazy Governor
Added BFQv5 Sched
Added V(R) Sched
2|4 --
3.0.59 Revised
3.0.60
3.0.61
1900mhz OC!
Voltage Optimization
Edits to mali/gpu
Increased Charging Rate
3.0.59 Revised
3.0.60
3.0.61
1900mhz OC!
Edits to mali/gpu
2|1 --
Linux 3.0.59
Deadline Edit
Edits to sched.c
Multiple Updates from Samsung OSRC
Linux 3.0.59
Deadline Edit
Edits to sched.c
1|28 --
Updated 27 Kernel Versions to Linux Kernel Version 3.0.58
-(ALOOOTTT of code updates)
Update to device sensors
1|21-- Initial Public Release
Note To Donators!
Every donation is more than appreciated! To show my appreciation for my
supporters, I will now begin listing every Donator in the OP as a special
thank you.
thank you.
THANK YOU
yoojin1081
Special Thanks To The Following Supporters Of This Kernel
**Webleeper
** TheContinental
** TheContinental
Downloads
SaberKernel_45.3- Dev-Host - SaberKernel_45.3_7100.zip - The Ultimate Free File Hosting / File Sharing Service
How Do I Use TouchWake?
*** Grab TricksterMod From Below. Enable TouchWake and Set Delay To 0 ( You can now wake your phone without power button)
TricksterMod-- Dev-Host - com.bigeyes0x0.trickstermod-1.apk - The Ultimate Free File Hosting / File Sharing Service
Voodoo Control -- Dev-Host - org.projectvoodoo.controlapp-1.apk - The Ultimate Free File Hosting / File Sharing Service
