redbull1
Enthusiast
- 1.293
[KERNEL][Samsung][4.4.2 TW] [20. September] Nadia Kernel r7 by by Emotroid Team
WICHTIGER HINWEIS:
Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg
oder die Haftung für jegliche Beschädigungen an eurem "Note 2 (N7100)".
Wenn ihr nicht sicher seit, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Daher flashen auf eigene Gefahr.
Kernellogo
Changelog und Features
Download
Originalthread
Kernellogo
September- 20 -2014 nightly r7
- Zzmoove updated to V0.9 beta4
- Corrected L1 cache shift
- Increased force_max_zoneorder to 12
- Disabled multicast when is sleeping
- cleaned some files
- sched_fair: reduced latency
- sched_fair: optimized cgroup_pick_next_task_fair()
- sched_fair: implemented smarter wake-affine logic
- cpuidle: removed cross-cpu IPI by new latency request.
- Added extra free kbutes tunable
- Added Xbox controller support as module
- Added NTFS support as module
- Added support to ppp-widget
- Enabled max freq for busfreq opp
- Added early suspend delay to userspace
- Updated mali driver to r3p2 rel4
- Added key disabler for cypress-touchkey
- Enabled negative mode compatibility of newer MDNIE drivers (Synapse)
- Added new page in Synapse for Live Statistics (Time in states, Uptime,etc.)
- /sbin nadia.sh values moved to init.d
Synapse and all available options:
- LIVE STATISTICS: Time in states, Uptime,etc.
- CPU - GOV: current frequency, CPU and Battery temperatures, current CPU cores online, CPU MAX and MIN frequency, CPU Governor, Governor tunables.
- CPU voltage: separate frequency voltage.
- GPU: GPU scaling freqyency and treshold steps.
- I/O: schedulers, internal storage read-ahead, externalSD read-ahead and Dynamic FSYNC.
- CPU DRIVERS: cpu multicore power saving, cpu idle mode, logger mode, touchboost settings.
- ABB settings
- Kernel tweaks: low memory killer, kernel entropy, panic and panic on oops.
- NETWORK: tcp congestion control, hardering the TCP/IP stack to SYN attack,ignore pings,etc.
- VM-FS: dirty radio, swappiness,etc.
- BATTERY: charge control
- SOUND: Wolfson Sound control
- MDNIE: mdnie mode and scenario
- LED: Blinking effect, led intensity and spee led.
- Touchwake: touchwake config
- INFO-reboot: info about kernel,etc.
1 - August - 2014 nightly r6.1.1:
- fixed HDMI Audio issue
July 31 2014 r6.1
- sysfs interface to Enable / Disable CRC
July- 04 -2014 nightly r5
- Based on new Samsung source code XXUFND3
- Kernel compiled with Toolchain GCC 4.7
- Retain only online cpus in manage_policy->cpus
- irq: Set CPU affinity as soon as the irq thread is created
- lowmemorykiller: Changed default debug_level to 1
- Network speed tweaked
- Dynamic Fsync updated to v1.1
- Notification LED controls
- Zzmoove updated to v0.9 beta2
- earysuspend: speedup late resume (faster wakeup of the device)
- sched_fair: Reduced latencies
- CPU OC to 2000MHz and moved sysfs uV to cpufreq.c
- Wolfson Sound Control
- Synapse support
- ABB settings
June- 13 -2014 nightly r4
F2FS support
GPU frequency and sys interface fixed
power: neutered the cpufreq min samsung interface
power: reduce regulator initializations to regulator minima
sched/nohz: Rewrite, fix and add more accurate load-avg computation
Introduce timer slack controller
Zzmove updated to v0.8
Lulzactiveq updated and added sys screen_off_max_step
sched: Ensure cpu_power periodic update
cpupower: update the cpu_power according to cpu load
ARM: 7011/1: Add ARM cpu topology definition
block/blk-core: add support for Linux 3.0.x for urgent request handling
block: Add support for reinsert a dispatched req
Multicore Power Saving 0 by default
For more info check my github
2-June -2014
r3
[changed]GPU OC/uV (Thanks to DerTeufel and Yank555.lu)
Added scripts in init.d for the GPU OC and uV
Proportional Rate Reduction for TCP
Buqfreq: Use cpu_load_slope correctly (Thanks to AndreiLux)
Added zzmoove governor
Allocate boot (MMC) partitions on probe
Increase timeout limits for bad sdcard
Add sysfs interface to Enable / Disable Android Logger (Thanks to AndiP)
Asynchronous I/O latency to a solid-state disk greatly increased between the 2.6.32 and 3.0 kernels
Forced Fast Charge (Thanks to Yank555.lu)
Reduced wakelock
Added cpu-boost driver
Implemented Touchwake v1.1a and Touch boost
Added slide2wake (Thanks to DerTeufel)
Cpufreq & hotplug updates
tmpfs: fix mempolicy object leaks
LOAD_FREQ (4*HZ+61) avoids loadavg Moire
Optimized ARM RWSEM algorithm
reg: Fixed memory leak
Optimized square root algorithm
Added ARM optimized crypto algorithms
mm:backing-dev tweak
Deadline iosched updated and tuning
writeback: fix occasional slow sync
Drecreased time to enter sleep
Softirq: reduced latencies
May 28 nightly beta r3 :
May 24 nightly r2 :
lib/memcopy and lib/string use glib version
Added charger control
Added Boeffla Sound Engine 1.6.5
Added Lulzactiveq governor
Added Sysfs_helpers: Allow negative values
added Advanced TCP: westwood by default
May 22 nightly r1 :
Based on Samsung Source code SEA_KK_Opensource
Overclock to 1920MHz
Default scheduler = Cfq
Default governador = Pegasusq
Cpu = 1600/200
CPU voltage control
Dynamic FSyn control
Reduced battery-monitor wakelock timeouts
Added SIO, ZEN and ROW
Disabled debug kernel
Adaptive Body Bias control
Improved performance
Fixed cpu scaling above max frequency
Increase readahead value to 1024Kb
- ABB settings
July 31 2014 r6.1
- Synapse support
- ABB settings
F2FS support
2-June -2014
r3
Reduced wakelock
May 24 nightly r2 :
May 22 nightly r1 :
Cpu = 1600/200
CPU voltage control
Download
Nadia nightly r7 Mediafire
Nadia nightly r7 MEGA
MALI BLOBS for NG3-NG4:
MALI LIBS
Nadia nightly r6.1.1
r6.1
http://www.mediafire.com/?93gaitqoiw3k6i9
r5 Download
Mediafire
Mega
Nadia nightly r4
Nadia nightly r4 MEGA mirror
Nadia nightly r3
Nadia nightly r3 MEGA mirror
Beta release:
Nadia nightly beta r3
Nadia nightly r2 MEGA mirror
MALI LIBS
r6.1
r5 Download
Mediafire
Mega
Nadia nightly r4
Nadia nightly r3
Beta release:
Originalthread
