[KERNEL][N7100][Samsung]Nadia Kernel [Emotroid Team Htcspain]
  • 10 Antworten
andreas01
andreas01
Nadia Kernel Emotroid Team Htcspain
This kernel works only with all TW/Samsung based JB ROMS 4.1.X
First of all I want to say this that is one project which just started and gradually we will improve it. In this community there are very good developers and we are not traying to compete with them. This is just a hobby and we do it because we like Android. This kernel is only for N7100 and we don't have plans to make it compatible with other versions of Note 2. We have many downloads of our ROMS but a few regarding comments than downloads and that could discourage anyone. We hope that you will not only download the kernel but also you will sent your comment with pros and cons and you should respect our efforts.
Changelogs:
v1.0
-Based from Official Samsung kernel sources Update2
-Overclock to 1800MHz
-Underclock to 50MHz (Thanks to Franlov and Acura)
-Default Scheduler= Cfq
-Default Governor= Pegasusq
-Default boot set to 1600/200
-Stweaks App support (Used Wanam customization of GokhanMoral generic interface, Big thanks to them)
-CPU voltage control for UV trough Stweaks App (Thanks to AndreiLux)
-Boeffla sound App support (Thanks to AndiP)
-Stweaks Configuration is tranlated in Spanish
-Dynamic FSyn control
-Reduce Battery monitor wakelocks (Thanks to AndreiLux)
-Added Governors: HOTPLUG, WHEATLEY and LULZACTIVEQ
-Added IO schedulers: SIO, ZEN and ROW
-exFAT support
-Init.d support
-Unsecured Boot
-Built with Stock UBDMC2 Initramfs
-Built with Stock ARM Toolchain 4.4.3
-And a few things that I don't remember now
Optimale Settings:
Governor: Lulzactiveq
I/O Sheduler: Row or Sio
Maximum Frequency: 1600MHz
Minimum frequency: 50MHz
Voltages CPU:
1800MHz -1300000
1704MHz - 1262500
1600MHz - 1200000
1500MHz - 1162500
1400MHz - 1112500
1300MHz - 1100000
1200MHz - 1050000
1100MHz - 1050000
1000MHz - 1000000
900MHz - 987500
800MHz - 950000
700MHz - 925000
600MHz - 900000
500MHz - 875000
400MHz - 850000
300MHz - 800000
200MHz - 762500
100MHz - 737500
50MHz - 725000
Do not forget to give Set on boot (Set at startup)Well, that's my current setup, the voltages can go lower, but I for the issue that in my area does not carry heat to the limit, but you can go lower, if you do not overdo it. Go down little by little, if you suffer a reset voltages go up because it will have a very low voltage and therefore restarts.
oder​
Download
Download des Kernels (.zip) und speichern auf eurem Note II.
Danach in den CWM Recovery booten (Volume up - Powerknopf - Homebutton gleichzeitig drücken).
Ein Backup des aktuellen ROMs machen und dieses wenn möglich (zur Sicherheit) auf dem PC speichern.
Danach den Kernel von eurem Note II installieren.
Rebooten
Big thanks to:
-Acura
-Franlov
-Wanam
-Andreilux
-GokhanMoral
-AndiP
Originalthread
ACHTUNG: Diese Anleitung soll euch lediglich als Hilfestellung dienen. Jeder Systemeingriff am Gerät, wie zB durch Flashen oder Rooten birgt Gefahren in sich. Es wird in diesem Zusammenhang ausdrücklich darauf hingewiesen, dass weder android-hilfe noch ich Verantwortung für Schäden, die durch Flashen nach dieser Anleitung entstanden sind, übernehmen. Jeder muss selber wissen was er tut und sich zutraut. Weiters wird darauf hingewiesen, dass durch Flashen oder Rooten Garantieansprüche gegenüber dem Hersteller oder Anbieter erlöschen oder sich auch ein Vertragsbruch mit dem Provider ergeben könnte. Daher werden Systemeingriffe immer in eurer Eigenverantwortung durchgeführt.
LG
Andreas
Reaktionen: perog, Woschdi und Xrunner
Teste den seit zwei Tagen und muss sagen, ganz gut, der Kernel... Gute Performance. Keinerlei Probleme mit Wlan, data, bluetooth oder sonstiges. Hab ihn mit der Goa8.5 auf 1,8ghz laufen, absolut stabil ..
Lg Steff
Reaktionen: Xrunner
@atonal
Dann sind wir schon zu zweit :)
Habe im ersten Post die empfohlenen Settings von ivanebdesign mit eingepflegt.
LG
Andreas
Reaktionen: atonal
@atonal,
bis aufs OC kann man das vom Stock-Kernel auch sagen, oder?
.... via App
und wie sieht es mit dem akku aus?
@andreas01 : Optimale settings ist immer so ne Sache....mit 1300mV läuft mein Note 2 bei 1,8Ghz ned stabil, was bei dem setting unrelevant wäre, da es ja nur bis 1,6 geht :) Aber er läuft schon sehr gut.....
@xrunner : wenn dem so wäre, würde ich sicher einen stock kernel verwenden...:) , ne, im Ernst, ich habs immer wieder mal mit nem Stock versucht, aber was Reaktionszeit angeht usw. finde ich einfach Perseus;Redpill oder auch den Nadja einfach um Nasen weiter vorne, gut, dafür hat der Stock ne bessere Akkulaufzeit.....
Wenns jetzt um Sparsamkeit geht würde ich sagen, nimm nen Stock, aber ich zocke viel, und mir ist einfach Performance wichtiger als Akkulaufzeit, denn Dank des echt mächtigen Note 2 Akkus komme ich locker über den Tag.....
Allerdings muss ich auch sagen, daß man bei den oben beschriebenen Custom Kernels nicht mehr viel Unterschied merkt..auch nicht bei den Benchmarks
Aber die Jungs mit dem Nadja sind auf nem guten Weg.....
Greetz
Reaktionen: Xrunner
Ist ja nicht von mir, sondern vom Kernel-Bauer ivanebdesign selbst.
Original heißt die Überschrift Configuración óptima...:tongue:
Ich selbst ändere nur ganz selten etwas an der Ausgangskonfiguration.
LG
Andreas
Reaktionen: atonal
Zur Info:
Thread wurde auf XDA mit dieser Begründung geschlossen:
Thread closed for continued refusal to comply with GPL.
Anmerkung von mir:
Wenn ich mich so an den Thor Kernel erinnere....habe ich ein kleines Déjà-vu :icon_wink
LG
Andreas
Reaktionen: perog
Pffffff, das Ganze nur, weil er von Simone, ohne zu fragen, die boeffla App verwendet hat....dachte aber das haben die geklärt, Simone hat ihn doch sogar noch Support angeboten.....
Wat für ein Kindergarten....
Weiss jemand, ob der Kernel irgendwo nen anderen thread hat...?
_________________________________
Die Apple User waren sehr traurig, als sie auf der Nachruf Seite von Steve Jobs zu lesen bekamen : "Sorry, there is an actually flash player needed, to watch this site!"
Es gibt m.W. nur noch den spanischen Originalthread...es ist aber sehr mühsam zu lesen :)
Wenn sich etwas tun sollte poste ich aber hier.
LG
Andreas
Gesendet von meinem GT-N7100 mit Tapatalk 2
Supa dupa
redbull1
redbull1
redbull1
DirtyKlot
Feuerstern1
Feuerstern1
U
  • Angepinnt
  • uspower98
Feuerstern1
Feuerstern1
