burner8
Ehrenmitglied
- 16.425
Hier könnt ihr euch über die Akku-Leistung des Mate 10 unterhalten
Großen Unterschied heißt welches von beiden schneidet besser ab? Wie LCD und Amoled arbeiten ist mir bewusst. Heißt aber nicht zwangsläufig das Amoled hier gewinnt.M.Dee schrieb:Dazu kommt, dass es wohl tatsächlich einen großen unterschied zwischen Mate 10 Pro und Mate 10 bei der Laufzeit gibt.
Das Display ist immer hungrig und das des Mate 10 hat die höhere Auflösung und ein LCD Panel.
Huawei promised the Mate 10 would have the Mate 9's battery life and our test confirmed that. The Mate 10 did a little bit better in talk time and standby, and thus it scored an extra 5 hours to its total endurance rating.
Our endurance rating indicates how long a single battery charge will last you if you use the Huawei Mate 10 for an hour each of telephony, web browsing and video playback daily. We've established this usage pattern so our battery results are comparable across devices in the most common day-to-day tasks. The battery testing procedure is described in detail in case you're interested in the nitty-gritties. You can also check out our complete battery test table, where you can see how all of the smartphones we've tested will compare under your own typical use.
In real life, we were able to get as much as two days of battery life on a single charge while having all connectivity options such as Wi-FI, location and mobile data always on. Of course, your own mileage will vary based on your usage pattern.
