nnhlinh
Yes, try Cleanbaserom#2, run well for me!
my y200 sold in croatia, with croatian language and with clean_base_rom#2 work better than with stockrom. after flashing with clean_baserom, on first start you may choose your language, if your device doesn't response language automaticly.march00002 schrieb:Hello guys! Does anyone have tried the clean base ROM #2 flashed in their non-German version of Y200?
Installing: /sdcard/CleanBaseRom#2.zip
Finding update package...
Opening update package...
Installing update...
E:Error in /sdcard/CleanBaseRom#2.zip
(status 0)
Installation aborted.
nnhlinh schrieb:Cleanbase#2 don't flash oc kernel - it swaper kernel, the wifi is ok, I saw that wifi problem when use oc kernel!
vBm schrieb:I've tried CleanBaseRom#2 but it didn't work. I was getting this:
Luckily for me CleanBaseRom did work (old one), that did fix my problem with gprs but now i couldn't use WiFi at all.
Thanks to michelkovacic, after flashing some OC kernel boot, wifi started working as well.
Thanks once more Michel.
march00002 schrieb:is the kernel in the clean base rom swappable?
march00002 schrieb:Hi VBM, would you mind sharing the kernel that fixed your wifi? My wifi is broken for about 2 months now.. Still downloading the cleanbase rom..
That is exactly what I've did. Yet it failed.No|Name schrieb:did you do the following steps...
-wipe data/factory reset
-wipe cache partition
-advanced/wipe Dalvik cache
-mounts and storage/format system + cache
-mounts and storage/mount system + mount data
CaseF schrieb:nothing is impossible... but actually we work on a project much better than cyanogenmod 7.2... more details in a few days![]()
