MP2005
Dauer-User
- 277
- Themenstarter
- #41
du mußt sie natürlich entpacken
GCM will usually deliver messages immediately after they are sent. However, this might not always be possible. For example, the device could be turned off, offline, or otherwise unavailable. In other cases, the sender itself might request that messages not be delivered until the device becomes active by using the delay_while_idle flag. Finally, GCM might intentionally delay messages to prevent an application from consuming excessive resources and negatively impacting battery life.
MP2005 schrieb:Mod bräuchte nur den Threadtitel erweitern mit B112/B113
