Fii2i
Hey Community ich habe gerade den HTC Sensation XL bootloader entfernt ( geöffnet )
damit ich den root entfernen kann jedoch kommt andauernd ein Error im CMD wenn ich den RUN ME .exe starten will ..
hilfe..
Easy rooting toolkit (v1.0)
UNROOTING SCRIPT
created by DooMLoRD
based heavily on FlashTool scripts (by Bin4ry and
Credits go to all those involved in making this p
[*] This script will:
(1) unroot ur device using special script
(2) remove Busybox and assocaited symlinks
(3) remove SU files and assocaiated data
[*] Before u begin:
(1) make sure u have installed adb drivers for
(2) enable "USB DEBUGGING"
from (Menu\Settings\Applications\Developm
(3) enable "UNKNOWN SOURCES"
from (Menu\Settings\Applications)
(4) [OPTIONAL] increase screen timeout to 10 mi
(5) connect USB cable to PHONE and then connect
(6) skip "PC Companion Software" prompt on devi
CONFIRM ALL THE ABOVE THEN
MAKE SURE THAT THE SCREEN IS UNLOCKED
and if you get Superuser prompts ACCEPT/ALLOW THEM
ELSE THIS WILL NOT WORK
Drücken Sie eine beliebige Taste . . .
--- STARTING ----
--- WAITING FOR DEVICE
Das System kann den angegebenen Pfad nicht finden.
--- TESTING FOR SU PERMISSIONS
--- cleaning
--- pushing busybox
--- correcting permissions
--- remounting /system
--- pushing unroot script
--- executing unroot
--- cleaning
--- rebooting
ALL DONE!!!
hilfe..
UNROOTING SCRIPT
created by DooMLoRD
[*] Before u begin:
--- STARTING ----
--- cleaning
--- pushing busybox
--- cleaning
--- rebooting
ALL DONE!!!
