Honor Magic6 Pro: Android 15 Beta Programm
  • 11 Antworten
Werd ich gerne testen wenn Wochenende in Sicht 👍👍
@Nikwalter Wenn Du das Honor Magic6 Pro als Daily Driver im Einsatz hast - würde ich Dir davon abraten.
Denn:
"Das aktualisierte neue System erstellt eine brandneue Benutzerpartition, die nicht mit der ursprünglichen geteilt wird, und die Daten der ursprünglichen Benutzerpartition sind auf dem neuen System nicht verfügbar."
Eigentlich benötigt man dafür ein Testgerät...
HONOR Android 15 Beta 1 Developer Preview Program:
https://developer.honor.com/en/docs/11100/guides/android_15_beta_guide
HONOR Android 15 Beta 1 Developer Preview Program​
Careful:
The Beta build is not the final version, and some features might be missing or not working. It is recommended for developers, not for general users.
Hardware-backed​
HONOR Android 15 Beta 1 is available on HONOR Magic 6 Pro/ HONOR Magic V2, while other models are currently not supported.
Need to upgrade to a product version that supports HONOR Android 15 Beta 1:
HONOR Magic 6 Pro: BVL-N49 8.0.0.148(C431E4R2P2) , 8.0.0.152(C636E2R2P2) or higher.
HONOR Magic V2: VER-N49 8.0.0.105(C431E2R2P2), 8.0.0.105(C636E2R2P2) or higher.
HONOR Android 15 Beta1 upgrade package address​
HONOR Magic 6 Pro Android 15 Beta 1: Download
HONOR Magic V2 Android 15 Beta 1: Download
How to upgrade/return:​
1.Please download the corresponding upgrade package based on your device. This upgrade will not erase your data, but a backup beforehand is still recommended. The upgraded new system adopts a brand new user partition, which is not shared with the original one, and the data of the original user partition is unavailable on the new system.
2.Environmental preparation:
(1) Make sure adb, python environment and Honor Suite are available for PC.
(2) Reserve more than 60GB of space for mobile phone. Go to “Settings > About phone”, tap “Build number” 7 times to enable developer mode, then go to “System & updates > Developer options” to enable "USB debugging" and connect the device to PC via USB cable.
3.Please unzip the upgrade package on PC and run the script “python dsu_tool_for_win.py” to install it.
4.Please check the installation progress on the phone: Tap “Restart” to enter the new system after the installation is finished. Once the new system is launched, it is able to return to the previous system by tapping “Rollback”. If you swipes out the “Rollback” notification, you can execute "adb shell gsi_tool disable" and then reboot directly to return to the previous system.
Feedback method:​
1.Open “My HONOR” and tap “AGREE” for Privacy Statement to enter the home page during first access;
2.Tap “Services > Intelligent Diagnosis” at the bottom menu on the home page;
3.On the Intelligent Diagnosis page, tap “Feedback” at the upper right corner to select issue types;
4.Select “issue types”, tap “Enable logs” (if necessary), then tap “NEXT”;
5.Tap "ENABLE LOGS" to enable Diagnostic mode, otherwise it starts feedback with no logs (go directly to STEP7);
6.After recurrence of issue, swipe down the Notifications bar, tap “REPORT ISSUES” to pack the logs;
7.On the Report issues page, fill in “Problem details” and “Happened at”, add question images/audios/videos, then tap “SUBMIT” to upload feedback information and logs. If tapping “SAVE”, the information and logs will be stored on device and can be sent to the server by tapping “SUBMIT” later.
8.Feedback history and status can be checked via “Feedback record” after successful submission, and there will be a Task No. generated.
9.There will also be an “ADD LOG” button added after successful submission. Tap “ADD LOG” to add more information. Enable “Add log feedback” to capture logs again.
Known issues list:​
  • HDR effect probability failure for images within the gallery.
  • Low probability of phone restart in some scenarios.
  • Camera crash issue in some scenarios.
  • Mobile screen mirroring is not available.
  • In dual card mode, the dial only displays Card 1,you can try "Settings > Mobile network > SIM management > Default calling SIM" , select "Not set“.
  • Parallel space and Magic Portal is not available.
Reaktionen: Nikwalter
Bitte weiterlesen und genau lesen. Es wird eine zusätzliche Partition erstellt. Man kann dann später zwischen der Testumgebung und dem normalen System wechseln wie man will. Nur mit seinen Benutzerdaten kann man innerhalb der Testumgebung nicht arbeiten
Steht später, richtig nicht in der Meldung, auch ausführlich in der Readme: (Musst übrigens nirgends Mitglied sein um die Preview zu installieren)
System switching situations:
1. Original System switch to New System:
When the installation is completed in the original system, it will prompt "Dynamic system is ready. To start using it, restart your device" in the dropdown notification bar. Tap "DSICARD" to abandon the installation, or tap "RESTART" to reboot to the new system.
PS: After the installation is completed in the original system, restarting the phone by long pressing the power button or "adb reboot" will still reboot to the original system. To reboot to the new system, you can only tap the corresponding button in the dropdown notification bar.
2. New System switch to Original System:
Method 1: In the new system, a notification will appear in the dropdown notification bar, saying "Your device is running on a dynamic system. Tap RESTART to reboot, or ROLLBACK to revert to the previous system version.", then tap "ROLLBACK" to reboot to the original system.
Method 2: After entering the new system for the first time, reboot the phone directly will return to the original system.
3. New System reboot to New System:
Method 1: In the new system, a notification will appear in the dropdown notification bar, saying "Your device is running on a dynamic system. Tap RESTART to reboot, or ROLLBACK to revert to the previous system version.", then tap "RESTART" to reboot to the new system.
Method 2: If you are not the first time entering the new system, reboot the phone directly will reboot to the new system.
Method 3: In the new system, open the developer option to allow USB debugging, then connect to the computer:
1) Using command "adb shell gsi_tool enable", then reboot the phone directly will reboot to the original system.
2) Using command "adb shell gsi_tool disable",then reboot the phone directly will reboot to the new system.
Note: "Dynamic system" refers to the new system.
Reaktionen: Tecalote
@ekdmx Das weißt Du?
Bist Du Mitglied im Entwickler Programm und hast Du es schon ausprobiert?
Im Text wird das nämlich nicht explizit so beschrieben.
Man könnte es daraus schließen, aber erwähnt ist es nicht, dass man zwischen der Testumgebung und dem normalen System wechseln kann wie man will.
@ekdmx Ja, das habe ich gelesen. Ich verstehe das so, dass erklärt wird, wie man einen Rollback zu seinem eigentlichen System machen kann.
Nicht, dass man zwischen beiden Systemen wechseln kann.
Denn wenn der Rollback gemacht wird, wie willst Du dann wieder auf Android 15?
Vermutlich nur durch erneutes Flashen.
siehe mein bearbeiteten Post
@ekdmx Alles klar! Ich hatte natürlich nur den Text von der Seite gelesen und da stand das nicht so ausführlich beschrieben.
Ist die Readme in der Firmware.zip?
Kannst Du bitte mal die Readme anhängen?
Das ist dann schon wesentlich interessanter, wenn man zwischen den Systemen wechseln kann.
sicher
  • README.txt
Hat jemand die Beta schon drauf ? Kann ich denn meine Apps ganz normal benutzen?
@GoogleNerd Musst mal die vorigen Beiträge lesen. 😉
Also Du hast dann zwei Systeme. Deines mit Android 14 und eines mit Android 15.
Solange Du in Deinem original System bist, kannst Du Deine Apps nutzen.
Wenn Du in die Android 15 Beta willst, musst Du einen Button im Benachrichtigungsbereich klicken und dann startet das Gerät neu und bootet in das A15 Beta System.
Dort kannst Du Deine in Android 14 eingerichteten Apps nicht verwenden und hast keinen Zugriff auf Deine Daten im Android 14 System.
Hier, im Beitrag von @ekdmx ist das Wechseln zwischen den Systemen beschrieben.
Reaktionen: GoogleNerd
@ekdmx
Da wir ein deutschsprachiges Forum sind, übersetze bitte grundsätzlich deine Beiträge in unsere Sprache.
Viele Grüße!
Cris
Reaktionen: käthe1
Tomasz89
ErnstM05
Cris
Cris
Nikwalter
VooDoo7mx
V
laazaruslong
laazaruslong
waldfee123
