Ginryuu
@Celler96
"This is an easy fix and the reason is pretty easy to determine. The reason is that Androids' "Optimize Battery Usage" feature puts Google Play Store or Google Play services to sleep and restricts background activity. This means that when your phone screen turns off, the app is put to sleep so it does not consume battery; or if the phone is charging, it doesn't have any background activity access.
To fix this, you need to go to Settings, Apps, and scroll until you find Google Play Services and Google Play Store. Check Google Play Store first, click it and then click "Battery". If you see that it says "optimized", click the "Optimize Battery Usage" button and it will take you to a list at the top change it from "Apps not optimized" to "All". Scroll down the list until you find Google Play Store and switch the toggle to off; repeat this process for Google Play Services (most likely this will not be optimized, but just in case, check).
Now that you have done this, your phone will update because the app will no longer be put to sleep and it will be allowed to work in the background while your phone is charging or on Wi-Fi and it will update your apps. I have fixed this issue on a few phones and if this does not work for you, there is something else wrong with your device or Android.
This answer was copied from Aaron Johnson over on stackexchange Android Enthusiasts."
Das habe ich als Lösung gefunden, allerdings nicht direkt für das Honor Magic 6 Pro sondern für das Problem als solches welches wohl auch bei anderen Smartphones auftritt. Falls Englisch ein Problem darstellen sollte: Einstellungen --> Apps und runterscrollen bis man auf Google Play Services und den Google Play Store stößt. Dann soll man beide Sachen überprüfen (mit dem Store anfangen), auf Akku gehen und nachschauen ob dort "optimiert" steht. Dann auf "optimiere Akkunutzung" und dort soll man dann "Apps nicht optimiert" auf "Alle" wechseln. Dann die Liste runterscrollen bis man beim Play Store angelangt ist und auf "Aus" klicken. Bei Google Play Services das Gleiche machen.
Dies lässt sich leicht beheben und der Grund dafür ist recht einfach zu ermitteln. Der Grund ist, dass die Funktion „Akkuverbrauch optimieren“ des Androiden den Google Play Store oder die Google Play-Dienste in den Ruhezustand versetzt und die Hintergrundaktivität einschränkt. Das bedeutet, dass die App in den Ruhezustand versetzt wird, wenn sich der Bildschirm Ihres Telefons ausschaltet, damit sie keinen Akku verbraucht; oder wenn das Telefon aufgeladen wird, hat es keinen Zugriff auf Hintergrundaktivitäten.
Um dies zu beheben, gehen Sie zu Einstellungen, Apps und scrollen Sie, bis Sie Google Play Services und Google Play Store finden. Überprüfen Sie zuerst den Google Play Store, klicken Sie darauf und dann auf „Akku“. Wenn Sie sehen, dass dort „optimiert“ steht, klicken Sie auf die Schaltfläche „Akkuverbrauch optimieren“. Sie gelangen dann zu einer Liste am oberen Rand, die Sie von „Nicht optimierte Apps“ auf „Alle“ ändern können. Scrollen Sie in der Liste nach unten, bis Sie den Google Play Store finden, und schalten Sie ihn aus; wiederholen Sie diesen Vorgang für die Google Play Services (höchstwahrscheinlich werden diese nicht optimiert sein, aber überprüfen Sie es vorsichtshalber).
Nachdem Sie dies getan haben, wird Ihr Telefon aktualisiert, da die App nicht mehr in den Ruhezustand versetzt wird und im Hintergrund arbeiten kann, während Ihr Telefon aufgeladen wird oder sich im WLAN befindet, und Ihre Apps aktualisiert. Ich habe dieses Problem bei einigen Handys behoben. Wenn dies bei Ihnen nicht funktioniert, stimmt etwas anderes mit Ihrem Gerät oder Android nicht.
Diese Antwort wurde von Aaron Johnson auf stackexchange Android Enthusiasts kopiert
Übersetzt mit DeepL.com (kostenlose Version)
	Bearbeitet von:
		Julian23
	 - Grund: Deutsche Übersetzung eingefügt, Gruß Julian23
