jagwar
Zu Zooper, UCCW und den bisherigen HomescreenTuning Apps würde ich gerne Kustom hinzufügen.
Play Store / Uservoice
Video
- FAQ: FAQ
- G+ Community: http://goo.gl/XrGxP3
- G+ Gallery: http://goo.gl/bZnEzr
- Feature Requests: Feature Requests: Hot (45 ideas)
- Tutorials: Simple Tutorials
- Translations: kustom Translations - Get Localization
- Videos: Frank Monza - YouTube
- Permissions: Permissions Explained
- APK Skin Howto: http://goo.gl/lyYT2Z
Video
Make your Android device look unique with Kustom the most powerful Live Wallpaper creator ever! Use its awesome WYSIWYG (What You See Is What You Get) editor to create you own designs and display any data you need, at once, and with wonderful animations too! If you were looking for Rainmeter or Conky on Android, this is it!
With Kustom you can create customized Digital and Analog Clocks (with seconds hand), animated patterns, live map backgrounds, material wallpapers, sophisticated CPU/Memory meters, randomly changing images, scrolling images, gyroscopic effects and much much more. Imagination is the limit.
Launcher support
Animations works only on launchers that fully supports the Android standards, so for example Google Now Launcher and Nova Launcher are fully supported. Some others might have problems, the only known launcher with issues right now is GO Launcher (and this cannot be fixed by us).
You get:
- Some skin to start with
- Text with custom fonts, colors, sizes and effects
- Shapes like Ovals, Rects, Arcs, Triangles, Exagons and more
- Gradients, shadows, tiling and color filters
- Photoshop / GIMP like layers with overlay effects (blur, clear, xor, difference, saturation)
- Touch actions / hotspots on any object you create
- PNG / JPG / WEBp Image support
- Animations such as fading, scaling and scrolling based on screen position, touch, events...
- Magnetic sensors / gyroscope support for wallpaper motion or objects animations
- Complex programming with functions, conditionals and global variables
- Change Wallpaper based on time, location, weather, anything!
- Dynamic download of content via HTTP (live maps, weather and so on)
- Native music utilities (current playing song title, album, cover)
- Tasker support
- A huge amount of data to display (like date, time, battery, calendar, weather, astronomy (sunrise, sunset), CPU speed, memory, countdowns, WiFi and cellular status, traffic info, next alarm, location, moving speed and much more)
Pro will:
- Remove the ADS
- Support the dev!
- Unlock import from SD and all external skins
- Allow exporting skins to SD and creation of APK preset packs
- Save the world from alien invasion
- FAQ: FAQ
4wh4YQNaKKaRdY2zCj-iZDkmqzNsMS5mgG0H7lkLY3rRFSQB0jd5oNkqg2kV5Sq9nA=h900.png7 KB · Aufrufe: 911
7JXM9Wen-Mj9PO8c6FIDRI12ZLtdkrl_DBUDJr4UyDgWeNdYgNWUAOF8j-8JmY5MYk0=h900.png27,3 KB · Aufrufe: 930
9eoCfmeHMBHhlP3849CWCqkj5_Dt24GZF5qyCi6R9vjtaMyBMoZIFhK0iDr165pPp8I=h900.png64,1 KB · Aufrufe: 909
gzxq-wfsyP6CIwIkB6Mb18ZsQLK1ktS7TNgtDbTLG530s0JFgYWZZmISHfnZwRz2ougC=h900.png12,2 KB · Aufrufe: 860
JgGLJCyKuIKBiw4KRKqvWhmYIWCpInsonDwYRs04Yg4LKxmN69jvoe_DWN0yfDkkug=h900.png31,4 KB · Aufrufe: 874
jiqETTntCyG2bgZdyVJAVNsn08V459-88f7UfqRd11JEM-YwKfu93Kw1CUPKzPkO8dQ=h900.png14,1 KB · Aufrufe: 891
oj9MnBRs7dWvBmpdtRfv-Fu3ZoGTQlv2xQ5qUOuzOVnPgZ6394ZIGJ7RTtry6JUcEIj6=h900.png123,8 KB · Aufrufe: 818
stntXsyyQtowziT_B84MpllTWvxveicnU11OR0eBbhQ51y_J-X5oMgji-bDLLSMeKg=h900.png13,3 KB · Aufrufe: 825
