HannsTitan Rom (Android 2.2) | Diskussionen, Fragen & Antworten
  • 473 Antworten
heikonet
heikonet
Dauer-User
907
Der macher Alpha (hat auch das TNT Lite 0.1 gebaut) hat eine Mischung aus TnT Lite v0.2 and VEGAn rom gekocht.
Beinhaltet:
- Custom Zeam Launcher mit viel Platz für Icobns
- Stock android taskbar
- Stock android settings (fully working!)
- Android market
- Honeycomb music player
- Duomax's divx ac3 playback fix
- Volume appears considerably louder than TnT Lite
- Rooted
- Schnell und stabil!
Update: Wifi is set to never sleep, if you wish to conserve battery power go to wifi settings and press menu -> advanced and change wifi sleep policy.
Weitere Info:
HannsTitan v0.3
Custom Android 2.2 (Froyo) rom for Hannspree Hannspad
Based on the work done in the following roms:
Tap 'n' Tap
Brilliant Corners
Mountain Laurel
Features
- Zeam launcher
- Hardware acceleration
- Full Android market (After market fix below)
- Volume louder than TnT Lite
- Rooted
- It's quick and stable!
Changelog
0.3.1
Fixed stretched default wallpaper
Updated Zeam to latest version
Zeam has its default file name market updates may work now (need to wait on a new release to test it)
Updated build.prop to walkerx's latest version
Added /sdcard2 and /usbdisk to mount points so all storage shows up in settings
Included Multi Mount SD-Card Lite widget to mount /sdcard2 as usb mass storage (must use its widget)
Internal sdcard nomedia fix - stops files on the internal sdcard from being deleted
Reverted bootanimation
Added gTabWallPaper app
0.3
Minor update to include market fix
0.2d
Initial public release
Known issues
- Status bar could do with being improved
- Google apps accounts can now sign in after signing in with a normal google account, however now sync options will be shown (normal google accounts working fine)
- Wifi light not working
- Some users report issues with the device being unable to wake from sleep while others seem unaffected
Install instructions
Assuming you have CWM already installed, make a backup of any installed apps you don't want to lose.
1. Copy to sdcard root
2. Reboot in CWM
3. Delete data/factory reset is recommended
4. Install zip the usual way
5. Reboot
Market fix
6. Set up wifi, add a google account
7. Go to Settings > Applications > Manage Applications > All > GoogleServicesFramework > Clear data > Force stop > hold power button > reboot
8. If market gives you an error, reboot again
Give it a few minutes to settle after the first boot as the media scanner runs straight away and might make it feel sluggish. It takes a second for Zeam Launcher to pop into life too.
Market Fix Only
0.3.1 includes the latest market fix
After setting up wifi and adding a Google account:
1. Go to "Settings -> Applications -> Manage Applications -> All -> GoogleServicesFramework" and press "Clear data" then "Force close"
2. You can do the same with the Market EXCEPT "Clear cache" NOT "Clear data" - although I never had to do this
3. Reboot straight away
4. Wait for WiFi to connect and open Market, if it gives you a server error, reboot again
Please try and keep this thread clear of honeycomb questions, there are others on the forums and no, I am not currently developing a honeycomb rom!
Special Thanks
roebeet + gojimi for their work on the original roms
Nosferatu Alucard for the honeycomb music player
duomax for the ac3 libs
boot animation from droidpirate.com
walkerx for help with the build.prop for the market fix/gazbert for his original findings
Everyone else who's reported issues or gave compliments, it all helps
Downloads
Full ROM
0.2d: HannsTitan v0.2d - 105,414kb
0.2d HannsTitan v0.2d - 105,414kb
0.3.1 Update
You must have 0.2d installed first!
HannsTitan v0.3.1 Update
Important note if you are using an external SD card
Download and extract the file linked in this post to the root of your external sdcard. By root I mean not in any folders. You do not need to do this to the internal sdcard as the 0.3.1 update installs this automatically.
Quelle: Slatedroid
Reaktionen: Simkou, rookie, Squizzy und 6 andere
Hmm funktioniert den das market auch zu 100% ?
Sent from my Flashback 7.1 using Tapatalk
Nein, leider immer noch nicht.
Aber dafür echt stabil und so schnell wie man es von einem dualcore erwarten kann.
Ich wünschte mir das die honey comb roms so reagieren würden.
Installier dir das mal. Dann tipp mal einen längeren Text und du wirst den unterschied merken. Kein doppeltes tippen mehr. Kein festes drücken mehr.
Kein Vergleich zum tnt rom. Es es diesmal für mich eine ganz andere Liga.
Keine fcs und kein ruckeln. Und eine sensationelle Akku Laufzeit.
Ich bleibe erstmal bei dem rom. Auch wenn mir die tablet optimierten apps fehlen, aber die Stabilität und Geschwindigkeit will ich nicht mehr missen.
Fremde Tastatur geht auch, wie SwiftKey geht auch wieder einwandfrei!
Hm komisch irgend wie bin ich mit dem rom nicht klar gekommen. Und so schnell fand ich es jetzt auch nicht. Ständige abstürze und die Tastatur fängt an zu spinnen und ausserdem kann ich flash nicht ab spielen. Ich hab auch schon den rom Hersteller gefragt und er meinte evtl hat des was mit m modell reihe zu tun
Habs installiert. Auch bei mir bisher stabil und wirklich deutlich performanter als das originale ROM. Lagesensor und Tasten funktionieren. Kann man die Telefon Sachen loswerden?
Wenn es gerootet ist, schau mal im market nach sysremapp remover. Kostet allerdings - gibt aber glaub auch kostenlose.
@androidparanoid
Habe deinen Beitrag im slatedroid forum verfolgt.
Auch wenn es nervt, aber wie immer die frage, hast du 3x full wipe gemacht? Auch cache und dalvik?
Gesendet von meinem HTC Desire mit der Android-Hilfe.de-App
heikonet schrieb:
@androidparanoid
Hm ne 3x full wipe mach ich nie?!? Dachte da reichts auch einmal aus. Cache mach ich immer aber dalvik fast nie. Icj lasse mivh gern eines besseren belehren und probier mal dein Lösungsansatz aus. Werde eh das tablet zurück schicken da die Kopfhörer Anschluss strange behaven. Wenn ich kophö ganz einstecke kriege ich ein missersbles ton und bei halb eingesteckt Ok???? Ist des bei dir uch so?
Kann es sein das der Lichtsensor nicht Funktioniert?
Der HDMI Ausgang Funzt auch net.
Beides nicht getestet ;)
Hdmi Kabel habe ich nicht und licht ist bei mir immer manuell ;)
Heho Leute,
habs auch grad mal draufgemacht. Welche Dateien muss ich mit dem SystemApp Remover alle löschen, damit nicht unnötig Akku gespeist wird?
Es gibt endlich einen Market fix!
Download this file:-
MEGAUPLOAD - The leading online storage and file delivery service
and copy it to /system using a file explorer that allows root access (i use root explorer but there may be free ones in the market)
you will be asked to overwrite the existing build.prop. You can back the original up by copying it to the internal storage first if you want.
once you've copied the new build.prop over go to settings/applications/manage applications/all
select "market" and clear cache then force stop
then select "google services framework" and clear data then force stop
reboot the device and market should be working
Quelle: [ROM] HannsTitan v0.2d - SlateDroid.com - Page 3
evtl ne dumme Frage, aber laufen auch Spiele?
Hallo, es gibt keine dummen Fragen, nur dumme antworten :)
Gibt mal im market "riptide gp demo" ein oder "tegra", dann findest du hoch wertige spiele die laufen ;)
Reaktionen: tectrex
Is echt super das Rom......verdammt schnell und stability!
@Heikonet: wie hast du es geschaft dieTastatur umzustellen? Installieren hat zwar geklappt allerdings wird immer die Android Tastatur angezeigt ganz egal welche ich in den Optionen angehakt hab. Bei der Android Tastatur gibt es keinen Hacken um diese zu deaktivieren. Gibt es noch ein weiteres Menü wo man die Tastatur umstellen muss/kann?
EDIT:habs gefunden
Herzlichen Dank
EDIT:habs gefunden
Herzlichen Dank
Wo hast du die tastatur umgestellt?
@Superboy
wenn du eine alternative Tastatur aus dem Market installiert hast (zum Beispiel Swiftkex x Tablet) dann gehst du einfach auf
Einstellung - Sprache und Tastatur
Dort machst du hinter dem Tastaturnamen den Hacken rein.
Wenn du dann irgendwo bist, wo du Text eingeben kannst, hälst du den Finger gedrückt. Ein Menü öffnet sich. Dann wählst du eingabe Methode aus und dann die gewünschte Tastatur.
Reaktionen: king999
Ich benutze auch das HannsTitan Rom und bin auch begeistert. Allerdings ist mir ein Problem aughefallen. Trotz Marketfix zeigt mir der Market nicht alle Apps an. Der filter steht auf alle anzeigen.
OPERA Mobile und der boat browser werden dort nicht angezeigt. Ist das ein Bug?
Und noch eine Frage hab ich:
Läßt sich irgendwie die Wortvorschläge der Tastatur auf deutsch umstellen?
Hm also ich finde opera im markt. Vll musst du ja die permission vom build.prop datei richtig setzen. Das problem hatte ich auch namlich. Setze permision auf rw x x
sent from my hannstitan using tapatalk
@heikonet
Nachdem ich das hannstitan neu aufgepsielt habe läuft das rom spitze. Alle apps im market too. Ich habe halt noch das dalvik cache gelöscht. Ob das was damit zu tun hatt weis ich nicht. Hab manchmal probleme mit m touch screen aber das ist selten. Da reagiert der touch screen nicht und es erkennt die touchs am falschen Ort.
  • joke248
Captain Awesome
Captain Awesome
Lecter
  • Gesperrt
  • Lecter
3 4 5
hävksitol
hävksitol
  • holgics
Denowa
Denowa
