Reboot Problem
  • 6 Antworten
Z
Zeldafan
Hallo Community,
ich hab geraumer Zeit ein großes Problem mit meinem Galaxy Nexus mit Android 4.3.
Es startet unregelmäßig neu. Auch wenn es einfach nur rumliegt.
Ich glaub, dass es an meinem eMMC-Chip liegt. Ich hab nämlich den V3U00M von der 08/2012 Produktion.
Deshalb hab ich mal die last_kmsg Datei ausgelesen und das hier gefunden:
[ 2770.419097] mmcblk0: not retrying timeout
[ 2770.420166] end_request: I/O error, dev mmcblk0, sector 2553576
[ 2770.420257] end_request: I/O error, dev mmcblk0, sector 2553584
[ 2770.420379] end_request: I/O error, dev mmcblk0, sector 2553592
[ 2770.420440] end_request: I/O error, dev mmcblk0, sector 2553600
[ 2770.420593] end_request: I/O error, dev mmcblk0, sector 2553608
[ 2770.420654] end_request: I/O error, dev mmcblk0, sector 2553616
[ 2770.420776] end_request: I/O error, dev mmcblk0, sector 2553624
[ 2770.420837] end_request: I/O error, dev mmcblk0, sector 2553632
[ 2770.420959] end_request: I/O error, dev mmcblk0, sector 2553640
[ 2770.421051] end_request: I/O error, dev mmcblk0, sector 2553648
[ 2770.421264] Aborting journal on device mmcblk0p12-8.
[ 2771.078338] journal commit I/O error
[ 2771.185058] EXT4-fs error (device mmcblk0p12): ext4_journal_start_sb:296: Detected aborted journal
[ 2771.185424] EXT4-fs (mmcblk0p12): Remounting filesystem read-only
[ 2771.203002] EXT4-fs error (device mmcblk0p12): ext4_journal_start_sb:296: Detected aborted journal
[ 2771.204925] Kernel panic - not syncing: EXT4-fs panic from previous error
[ 2771.204925]
[ 2771.205169] CPU0: stopping
[ 2771.205383] Backtrace:
[ 2771.205627] [<c0066534>] (dump_backtrace+0x0/0x138) from [<c0647bd0>] (dump_stack+0x18/0x1c)
[ 2771.205841] r6:c0827290 r5:c0898e08 r4:00000000 r3:00000000
[ 2771.206420] [<c0647bb8>] (dump_stack+0x0/0x1c) from [<c005bac8>] (do_IPI+0x1e0/0x218)
[ 2771.206634] [<c005b8e8>] (do_IPI+0x0/0x218) from [<c0061908>] (__irq_svc+0x48/0xe4)
[ 2771.206848] Exception stack(0xc0819ec8 to 0xc0819f10)
[ 2771.207000] 9ec0: c0819f10 0008eb10 377a0131 00000285 37789b90 00000285
[ 2771.207214] 9ee0: c1229210 c005b5cc c1229210 c0898c5c c0898c00 c0819f44 00000011 c0819f10
[ 2771.207336] 9f00: c0096090 c007eac8 60070013 ffffffff
[ 2771.207580] [<c007ea84>] (omap4_enter_idle_wfi+0x0/0xd8) from [<c0450968>] (cpuidle_idle_call+0xb0/0x13c)
[ 2771.207794] r8:c0898cd0 r7:c0919780 r6:c1229210 r5:c0818000 r4:c1229220
[ 2771.208465] [<c04508b8>] (cpuidle_idle_call+0x0/0x13c) from [<c00634e0>] (cpu_idle+0xe0/0x120)
[ 2771.208679] r7:c0875f9c r6:c0757118 r5:c083da38 r4:c0818000
[ 2771.209350] [<c0063400>] (cpu_idle+0x0/0x120) from [<c0638ae0>] (rest_init+0xa8/0xc4)
[ 2771.209472] r8:c0826f84 r7:c004de3c r6:00000002 r5:c005b5cc r4:c0818000
[ 2771.210113] r3:00000001
[ 2771.210449] [<c0638a38>] (rest_init+0x0/0xc4) from [<c0008a8c>] (start_kernel+0x304/0x360)
[ 2771.210662] r6:00000000 r5:c0898c80 r4:c0827120 r3:00000000
[ 2771.211212] [<c0008788>] (start_kernel+0x0/0x360) from [<80008040>] (0x80008040)
[ 2771.211456] Rebooting in 5 seconds..
[ 2775.326080] Restarting Linux version 3.0.91-franco.Kernel-nightly (francisco@francisco) (gcc version 4.7 (GCC) ) #392 SMP PREEMPT Wed Oct 9 03:43:04 WEST 2013
[ 2775.326110]
No errors detected
Boot info:
Last reset was warm software reset (PRM_RSTST=0x2)
Ich hatte es erst bei der Reparatur wegen diesem Problem.
Könnt ihr mir vielleicht weiterhelfen?
Ich kann Dir da leider nicht helfen, aber Frage:
Was steht denn im Reparatur-Auftrag, was gemacht wurde?
Meines hatte gleiches Problem, kam zurück mit dem Vermerk: Hauptplatine getauscht ...
Seit dem habe ich 1*im Monat das problem, da bei einem Telefonat ein deutlich hörbares Knacken zu vernehmen ist und das Phone rebootet, dann wars das aber auch erstmal wieder ...
Wenn es bei Dir nicht besser ist, am besten Zeugen hinzuziehen und wieder einschicken ....
Es wurden angeblich defekte mechanische Teile ausgetauscht und ein Software-Update durchgeführt. Als ich es eingeschickt hatte war 4.3 drauf und als ich es wieder bekam war 4.0.4 drauf..
Ich will es ehrlich gesagt nicht wieder wegschicken. Müssten sich defekte Speicherzellen nicht ausschalten lassen? =/
Keinen Schimmer von der Marterie ... frag mal im Werkstatt-Forum ... :winki:
Von wem hast du dein Handy reparieren lassen?
Vielleicht verschiebt ein Mod den Beitrag in einen der vorhandenen Beiträge:
https://www.android-hilfe.de/forum/...eboots-und-eine-erklaerung-dafuer.463414.html
https://www.android-hilfe.de/forum/google-galaxy-nexus.405/absturz-neustart.300935-page-78.html
Du hast keine andere Möglichkeit außer das Handy erneut einzuschicken. Es muss das Mainboard getauscht werden, vorher werden die reboots nicht aufhören.
Wegen der Werkstatt: ich hatte mein Galaxy Nexus wegen eines anderen Problems bei w-support und war mit der Reparatur und der Bearbeitungszeit sehr zufrieden.
Da gokpog ja schon Links zu zwei Threads gepostet hat, mache ich hier mal zu.
I
PJF16
PJF16
Klarooo
Klarooo
  • devotee71
devotee71
