W113
Dauer-User
- 1.601
Hier für Interessierte und Mutige …
Announcements - Fenix 8 AMOLED - Fenix 8 Solar - Enduro 3 - Fenix E - Garmin Forums
Nach der Beta Version 11.81 steht nun die Beta Version 11.82 zur Verfügung
Beta Version 11.82 - 'Check for Updates' Only - Announcements - Fenix 8 AMOLED - Fenix 8 Solar - Enduro 3 - Fenix E - Garmin Forums
Wichtiger Hinweis zu EKG- und Dive-Features:
Die für die Fenix 8-Serie erhältliche Beta-Software wird die EKG-Funktion und Dive-Funktionen deaktiviert.
Change log für Version 11.82 (Änderungen seit v11.64, derzeit live):
Added Ability to Toggle Third Party Maps in Map Layers Menu.
Added Autolap by Position.
Added Data Screen for Ski/Snowboard Difficulty Tracking.
Added Display Brightness Voice Commands.
Added Option to Connect to WiFi in Map Manager.
Added Solar Percentage on the Watch Face (Solar models).
Added Support for Water Ejection Feature.
Added Support for Alarm Volume Settings and fixed an issue where alarms could be muted when Do Not Disturb is enabled.
Added the Location Info Drawer to the Map Page.
Fixed Accidental Touches During Phone Calls.
Fixed Broken Redial Button After a Missed Call.
Fixed Bug affecting pairing with an InReach Device.
Fixed Bug preventing Workout Cancellation.
Fixed Button and Touch Screen Handling of Backlight in Do Not Distub Mode.
Fixed Button Functionality for Transfer Call to Phone Feature.
Fixed CIQ Activities to use the Activity Focus Mode.
Fixed ClimbPro Preview Visibility.
Fixed potential for Battery Drain after saving Activities.
Fixed Golf Map Rendering (Solar models).
Fixed Incorrect Active Timer Count.
Fixed Incorrect Waypoint Elevation in the Saved App.
Fixed Map Cursor in Pan/Zoom Mode.
Fixed Missing Weight Values on Strength Workout Page.
Fixed Potential Crash when Searching for Locations in the Weather App.
Fixed Save Location List Layout in Hunt Activity.
Fixed Saved App Listing Items Out of Order.
Fixed Scrolling in Very Large Lists.
Fixed Ski Run Descent Value Truncation.
Fixed Some Charts Not Displaying Properly when Launched from Recents Menu.
Fixed Workout Scheduling in the Calendar App.
Improved Always-On Watch Face Brightness (AMOLED).
Improved Off/Disabled Images for Power Controls Menu.
Improved Power Consumption on the Map Page.
Improved Processing Time of Large Courses.
Improved Update Rate for the Solar Watch Face Graph.
Improved Waypoint Draw Speed on the Map.
Removed Daily Suggested Workouts from Calendar if Suggestions are Disabled.
- Navigationswarnungen für jede Abbiegung behoben.
- Wasserauswurf, der die Telefonmusik pausieren ließ, behoben.
- Verschiedene Fehlerbehebungen und Verbesserungen für Adventure Racing vorgenommen.
- Standardpositionsformat auf DEG eingestellt.
- Möglichkeit zum Umschalten von Karten von Drittanbietern im Menü „Kartenebenen“ hinzugefügt.
- Autolap nach Position hinzugefügt.
- Datenbildschirm für Ski-/Snowboard-Schwierigkeitsverfolgung hinzugefügt.
- Sprachbefehle für Displayhelligkeit hinzugefügt.
- Option zum Verbinden mit WLAN im Kartenmanager hinzugefügt.
- Solar-Prozentsatz auf dem Zifferblatt hinzugefügt (Solar-Modelle).
- Unterstützung für Wasserauswurffunktion hinzugefügt.
- Unterstützung für Alarmlautstärkeeinstellungen hinzugefügt und Problem behoben, bei dem Alarme stummgeschaltet werden konnten, wenn „Nicht stören“ aktiviert ist.
- Standortinfo-Schublade zur Kartenseite hinzugefügt.
- Versehentliche Berührungen während Telefongesprächen behoben.
- Beschädigte Wahlwiederholungstaste nach verpasstem Anruf behoben.
- Fehler behoben, der die Kopplung mit einem InReach-Gerät beeinträchtigte.
- Fehler behoben, der das Abbrechen des Trainings verhinderte.
- Tasten- und Touchscreen-Handhabung der Hintergrundbeleuchtung im „Nicht stören“-Modus behoben.
- Tastenfunktionalität für Funktion „Anruf an Telefon weiterleiten“ behoben.
- CIQ-Aktivitäten behoben, um den Aktivitätsfokusmodus zu verwenden.
- Sichtbarkeit der ClimbPro-Vorschau behoben.
- Potenzieller Batterieverbrauch nach dem Speichern von Aktivitäten behoben.
- Golfkarten-Rendering behoben (Solar-Modelle). Falsche Anzahl aktiver Timer behoben.
- Falsche Wegpunkthöhe in der gespeicherten App behoben.
- Kartencursor im Schwenk-/Zoommodus behoben.
- Fehlende Gewichtswerte auf der Seite für Krafttraining behoben.
- Potenzieller Absturz beim Suchen nach Standorten in der Wetter-App behoben.
- Layout der Liste „Standort speichern“ in der Jagdaktivität behoben.
- Nicht in der richtigen Reihenfolge aufgelistete Elemente der gespeicherten App behoben.
- Scrollen in sehr großen Listen behoben.
- Abschneiden des Werts für Abfahrten bei Skipisten behoben.
- Einige Diagramme wurden nicht richtig angezeigt, wenn sie über das Menü „Zuletzt verwendet“ gestartet wurden.
- Trainingsplanung in der Kalender-App behoben.
- Helligkeit des Always-On-Zifferblatts verbessert (AMOLED).
- Aus/Deaktivierte Bilder für das Energiesteuerungsmenü verbessert.
- Energieverbrauch auf der Kartenseite verbessert.
- Verbesserte Verarbeitungszeit für große Strecken.
- Verbesserte Aktualisierungsrate für das Solar-Zifferblattdiagramm.
- Verbesserte Geschwindigkeit beim Zeichnen von Wegpunkten auf der Karte.
- Tägliche Trainingsvorschläge aus dem Kalender entfernt, wenn Vorschläge deaktiviert sind.
- Feedback geben
