Fairphone 3 und 3+ bekommen kein Android 12, sondern überspringen es
  • 5 Antworten
Was erlauben Struuuunz, ähm, Fairphone ;) :D
Reaktionen: Wattsolls
Mich freuts für die Fairphone User. :)
Reaktionen: Meerjungfraumann, h0sch180 und RA99
Na da könnte sich selbst Google mit ihren Pixel´s noch ne Scheibe abschneiden. ;)
Das sie es können haben sie schon bewiesen. Respekt.
Reaktionen: ZiegevonNebenan
Die Release Notes sind jetzt online für Android 13.
https://support.fairphone.com/hc/en-us/articles/11351328932497
List of Android 13 releases
Fairphone OS version 018.0
Release date: 10th July 2023
Android version: 13
Software Version: 6.A.018.0
Security Patch Level: 5th June 2023
Changes
Introducing Android™ 13:
  • Themed App Icons
    Customize your phone to your personal style. With expanded themed app icons, you can set more apps - not just Google apps - to match your phone's wallpaper tint and colors.
    *Works with compatible apps.
  • Notification Permissions
    Now, the apps you download need your permission to send notifications, helping you proactively protect your time and attention span.
  • Audio codecs: aptX and aptX HD
    The Bluetooth audio codecs aptX and aptX HD are now available to you. This ensures that you get the very most from your audio.
  • Please note: due to updated Android security requirements, the fingerprint sensor at the back of the device can no longer be used to log into certain apps with higher security requirements, such as some banking apps. The fingerprint sensor can still be used to lock and unlock the device itself and the affected apps can still be accessed using a password or pin code for login.
Reaktionen: 85950 und Wattsolls
Meerjungfraumann
Meerjungfraumann
8
thisismo
thisismo
  • greatbarrier2018
HerrDoctorPhone
HerrDoctorPhone
