Drielander
Ehrenmitglied
- 1.460
@Mode2006
Um einen umfangreichen Changelog darzustellen, gibt es etwas deutlich Platzsparenderes:
Durch die normale Schriftgröße ist es für den Interessierten auch lesbarer!
-FLAC coded file does not play (single metadata block files) --> CyanogenMod/android_frameworks_av -libgui: Bring back support for mHeap-based screenshots --> CyanogenMod/android_frameworks_native -Revert "stagefright: Cleanup ifdefs in pause code" --> CyanogenMod/android_frameworks_av -Camera: revert CodeAurora's panorama angle handling --> CyanogenMod/android_packages_apps_Camera2 -Camera: fix preview for landscape devices --> CyanogenMod/android_packages_apps_Camera2 -Recheck /data for selinux labeling --> CyanogenMod/android_vendor_cm -Fix Dialog Mobile Broadband MMS APN --> CyanogenMod/android_vendor_cm -build: Add QCOM target-specific config --> CyanogenMod/android_build -libstagefright: Add HEVC as a recognized MIME in ExtendedExtractor --> CyanogenMod/android_frameworks_av -audioflinger: Fix for a deadlock --> CyanogenMod/android_frameworks_av -DTS Postpro integration (for frameworks/av) --> CyanogenMod/android_frameworks_av -libmedia: Add support for LCH tones --> CyanogenMod/android_frameworks_av -stagefright: provide a custom key to prefer adaptive playback --> CyanogenMod/android_frameworks_av -av: Additional ifdefs for QCOM DirectTrack --> CyanogenMod/android_frameworks_av -Camera2: More thorough compatibility fixes --> CyanogenMod/android_packages_apps_Camera2 -libhardware: Modify ifdefs for legacy DirectTrack --> CyanogenMod/android_hardware_libhardware -Remove qrngd --> CyanogenMod/android -Camera2: fix FC when switching camera in video mode --> CyanogenMod/android_packages_apps_Camera2 -camera: Actually fix ZSL
 --> CyanogenMod/android_packages_apps_Camera2 -Navbar: Fix MDPI & HDPI landscape layout --> CyanogenMod/android_frameworks_base -Email: Add new check frequency options (2h, 4h & 1 day) --> CyanogenMod/android_packages_apps_Email -SystemUI: Add double tap to sleep gesture --> CyanogenMod/android_frameworks_base -TextSecure: add translatables --> CyanogenMod/android_external_whispersystems_TextSecure -Launcher3: Add AOSP dummy strings to reduce aapt warnings --> CyanogenMod/android_packages_apps_Launcher3 -Revert "Lockscreen: Add checkbox for quick unlock" --> CyanogenMod/android_packages_apps_Settings -SamsungQualcommRIL: Add more validation of Signal Strength --> CyanogenMod/android_frameworks_opt_telephony -AppOps/Privacy Guard: Fix up misaligned switches --> CyanogenMod/android_packages_apps_Settings -qcom_utils: Update list of QCOM_BOARD_PLATFORMS --> CyanogenMod/android_build -dalvik: Use Bionic's memmove on cortex-a15 --> CyanogenMod/android_dalvik -libc: Enable high-performance memmove and bcopy for cortex-a15 --> CyanogenMod/android_bionic -skia: NEON blit optimizations from Samsung --> CyanogenMod/android_external_skia -Fix the icon size in app lists --> CyanogenMod/android_packages_apps_Settings -WhisperPush: fix copyright notice --> CyanogenMod/android_external_whispersystems_WhisperPush -Camera2: Add translatables --> CyanogenMod/android_packages_apps_Camera2
